Projects Old Rusty . . . a Father/Son '51 Chevy
Discussion in 'The Hokey Ass Message Board' started by BrerHair, Dec 18, 2010.
  1. ffr1222k
    ffr1222k
    Do you allready have the 1227730 computer? If not, there are several Chev Cavaliers at the local Pull-A-Part. It is the same computer, you will need the chip for the Camaro. I don't know if my son still has the Z28 tpi program. He used to do a lot of chips for the TPI. He did the one in my Cutlass that has a 383 w/ tpi.
    The chip is an eraseable programmable chip, so 15 minutes in a uv light will erase it. We did have an eraser, but he and I have both moved a couple of times since we used it so I am not sure where it is. He also had the harness and software to program the chips too.
  2. BrerHair
    BrerHair
    You got that right. Thanks.
    Thanks.
    (Edit)
    No. Thanks for all your help Rod. I'm definitely inviting you down here soon to check out what I'm doing. Sure feels good to know someone who's been there, done that.
  3. BrerHair
    BrerHair
    Today's progress: Found the panel between the rear seat back and the trunk and used it as a template to cut out some 1/2" insulation sheathing and 1/4" plywood.
    First, I sprayed rust encapsulator, let it dry, then glued shtg.
  4. BrerHair
    BrerHair
    Edit: OT engine stuff
  5. Finnrodder
    Finnrodder
    from Finland
    Looks like you made nice progress.That plasticbag idea is good,too bad that i cant use it because i am going to scrap most of the bolts...
    Just wondering,why to put that ECM and fusebox in the trunk?
    Isnt it easier to hide them under the dash?:confused:
    Keep it up!
  6. ffr1222k
    ffr1222k
    Good progress today!
    Is that a pair of Klein HD213-9NE side cutters?
  7. BrerHair
    BrerHair
    (Edit) it'll be real crowded under the dash. Thanks Finn!
    OK Rod, I had to Google what you asked. I believe the answer is yes. To me, they're just "lineman's pliers". They're so old, the writing on the side is unreadable.
  8. oldcarfart
    oldcarfart
    Make sure EVERY electrical/electronic componet has a good ground!! You are doing excellent!! I use plastic conduit fished thru frame.
  9. Devoted
    Devoted
    from DFW Texas
  10. fitzee
    fitzee
    cool your back at it!! Now no stopping for anything!! lol
  11. BrerHair
    BrerHair
    Thanks for the heads-up. Why couldn't I just fish the wire through the hollow frame? Do I even need conduit?
    Thanks, welcome aboard.
    Gotta run fast to try and keep up with you Canadians!:D
  12. BrerHair
    BrerHair
    How's this: worked about 3 hours today and got 2 wires connected. (Edit)
  13. BrerHair
    BrerHair
    Edit: note edit date below. I am removing all reference to my OT engine and tranny out of respect for Ryan's rules. Cool as this thread may be from a father/son perspective, the fact remains that it is one of many threads that took advantage of Ryan's flexibility while the HAMB was exploding in membership.
    Now (Sept '13) that Ryan is making a concerted effoert to get the HAMB back on topic, I am trying to do my part. I just wish I could remove the OT quotes of some of my original OT posts.
  14. BrerHair
    BrerHair
  15. pakrat
    pakrat
    That is freakin awesome!!! Good luck you guys
  16. gsport
    gsport
    ?? did that wiring harness come with new connectors?? or do you have to use your old ones?? it sure is looking good, i enjoy getting your updates, keep'm coming....
    ps.... who's the maker of the harness??
  17. BrerHair
    BrerHair
    Thanks pakrat.
    Edit: OT stuff
  18. Rickybop
    Rickybop
    from Michigan
    Billy said...
    “Oh, I don’t know, sometime around the early to mid-Sixties the cars just got a lot plainer looking. I love the earlier more rounded, cooler looking cars of the ‘40s and early ‘50s.”
    Yes!!! This just about brought a tear to my eye.
    Billy, you're so cool, I can't tell ya. You're dad's ok too...lol. You've got a good eye for beauty...and the curvy cars are beautiful, aren't they?...Like a woman. :)
    You liking the old cars proves that the hobby won't die anytime soon. (Older guys worry about that sometimes.)
    And dad...Don't feel like you're going too slow or anything. You and Billy have made great progress!
    I absolutely love this thread...the two of you working together. The best of luck to the "Old Rusty" team!
  19. five-duece-chevy
    five-duece-chevy
    from PA
  20. ffr1222k
    ffr1222k
    On the MAT connector a large pair of needle nose pliers with a 90 degree bend on the end works well.
    Are you going to run the EGR valve? If you aren't, you still got to take the plenum off to blank the intake where the EGR bolts on. It is a pain to get to the lower bolts on the runners. They are Torx and you need a LONG extension to get across from side to side. I replaced the Torx with allen head bolts. I think they came with the Scoggins-Dickey lower intake or the SLP large intake runners.
  21. pm5471
    pm5471
    from WISCONSIN
    Where did you get the inner rocker panels please?
    thanks
    pete
  22. BrerHair
    BrerHair
    Thanks Ricky, appreciate it.
    Fantastic Jaregg. You need to check out aw1950's build thread.
    Edit: OT stuff
    emsautomotive.com 216-541-4585
  23. BrerHair
    BrerHair
  24. pm5471
    pm5471
    from WISCONSIN
    thanks for the reply. I really like your build as i need to do the same rust repairs to my 52 BelAir,50 sport coupe and 50 pontiac.
  25. BrerHair
    BrerHair
    3 projects, Pete? Go, man, Go!
  26. BrerHair
    BrerHair
    Here you go Rod: (Edit: OT stuff)
  27. ffr1222k
    ffr1222k
  28. BrerHair
    BrerHair
    Edit: would like to leave this original post intact, in spite of the fact that I am talking about OT engine stuff. It speaks volumes about the whole traditional mindset, and about what the HAMB can teach you. Here it is:
    ffr1222k (Rod) reminded me that this EFI thing is not HAMB friendly. I already knew that, but my enthusiasm for the build has gotten the better of me. Best just to leave the hood closed on this thread.
    I have mixed feelings about this whole efi thing anyway. Let's face it, an L98 just does not move the Cool Meter. There are so many HAMB-friendly mills which we could have used that are dripping with cool, so, on this note, we missed the boat. With the benefit of hindsight, I would have gone old-school under the hood.
    I made two (at least 2) mistakes:
    1) Got carried away with wanting 200+hp as easily as possible, with a low-maintenance, high-reliability factor, and concluded that efi was the only way to go;
    2) Had not spent enough time roaming the hallowed halls of the HAMB when the decision was made. Did not have the full appreciation for the benefits of keeping the mill old school. No need for a discussion about that here. You either get it or you don't, and now I get it.
    So, pardon my interruption, but let me get this thing back on the frame, wired in, and then I'll resume the build posts. There are a ton of sites out there all about EFI, TPI, and all that modern jazz.:)
  29. BrerHair
    BrerHair
    Need to throw cold water on a thread? Just call on me, boys and girls.
    I just think this place deserves some self-policing regarding the preservation of the traditional intent. Sure there are lots of borderline O/T threads, but just because Ryan and his hard-working team give a lot of slack doesn't mean we shouldn't be mindful of the original vibe.
    I was reluctant to start a build thread at all due to the fact that we're basically using all post-1978 technology. (Edit: well, I was trying to move the thread back on track)
    Capiche?
  30. ffr1222k
    ffr1222k
    Well, this thread has made 21 pages and has a 5 star rating. Someone is following your build....
