Old mechanical press. What is it? and ideas?!?!
Discussion in 'The Hokey Ass Message Board' started by injectedA, Feb 18, 2008.
  1. injectedA
    injectedA
    A competitor of ours went under and we went over to see what was up for auction. I got this on my own for a buck. Though I haven’t the slightest idea what it is I couldn’t let it go, mostly because it has the cool handle and all of the holes and just looks like a tank, heavy as one to. Thing is, it has to be made usable or it has to go. Some kind of press I guess and I am going to start playing with it, maybe mounting a bottle jack or something. I just don’t press that many bearings to solely dedicate it to something like that.
    Ideas welcome!!! Thanks.
  2. jusjunk
    jusjunk
    from Michigan
    Well I think you got fucked unless you have a lot of apple trees and like cider..
    Dave
  3. injectedA
    injectedA
    RAOTFLMAO!!!!!!!!!!!!!!!!!!!!!!!!!!!! shit, I like pie, not much on cider. Does it taste good with some kind of liquor?
  4. injectedA
    injectedA
    ok, slapped myself up side the head, let's try this. I know I attached that damn pic.
  5. jusjunk
    jusjunk
    from Michigan
    Ok now wheres the god damn pic??? :D:D:D:D
    Dave
  6. Rootie Kazoootie
    Rootie Kazoootie
    from Colorado
    Reloading press for shotgun shells maybe ?
  7. jusjunk
    jusjunk
    from Michigan
    Kinda looks like one.. hey ill give ya 500 dollars for that old wore out wagon then you can buy more presses that you dont have a clue what they are for..
    Dave :)
  8. It`s a bowling pin press.
  9. Ratty55
    Ratty55
    from Frohna,MO
    Really big wine re-corker???? he he For a buck, i guess it's worth scrap...
    Ratty55
  10. Thorkle Rod
    Thorkle Rod
    That there is a bulk head stretcher
  11. 32HiboyRoadster
    32HiboyRoadster
    I don't have a clue, but my wife said she'd take it for a spin if you get it to run.;)
  12. Bruce Lancaster
    Bruce Lancaster
    That is a rare dragracing accessory, a Bell Helmet co. ear plug installer! You set one plug on the little circle, stick the other to the plunger with spit, and lay your head in there while Mongo pulls the lever. Those people who shell out thousands for old fueler face masks will pay even more for this. Vintage race gear is HOT!
  13. oilslinger53
    oilslinger53
    from covina CA
    i think it for pressing bearings onto mufflers
  14. I seen one of those in a porn movie. Dont sniff that handle....
  15. Ebbsspeed
    Ebbsspeed
    Might be a brake lining rivet press. What kind of vertical travel does it have when you pull the lever?
  16. harpo1313
    harpo1313
    from wareham,ma
    looks like you can mount a vice on top and use it to push and pull
  17. injectedA
    injectedA
    ha!!! google rules jokers…and then I was able this morning to track down the previous owner that we bought all of this equipment from :) This started out life as a taper press. This particular one was made in the 1920’s and used by a rail car manufacturing company. The company we purchased all of this equipment from had moved into the building previously owned by the rail car company and there was some miscellaneous equipment left behind. They have been using this as small motor and transmission bearing press.
    I have decided to turn it into a dual application press for bell mouthing holes and punching louvers. With the flat face located on the above housing I can attach an assembly to extend the neck out. Then by attaching a Bell Helmet© name plate with a model/serial number I can fool everyone as to the real purpose.
    This machine really wouldn’t satisfy as an apple corer (the average apple is 3.25” in diameter) or as a sexual device as the stroke is a mere 2.125”. That said, I may have stumbled onto a third application thanks to oilslinger53. I have just ordered some muffler bearings from a guy on ebay that claims they are the real deal. Must be, they were very expensive. Please keep your fingers crossed, hell, for some of you your legs to.
  18. Fasterthanu
    Fasterthanu
    Make sure you ordered the chrome bearings they last alot longer, I found out the hard way.
  19. ray
    ray
    from colorado
    a little liquor first, then i usually stick my dick in cider.
  20. scottybaccus
    scottybaccus
    I'll take a serious guess.....
    Maybe a valve spring press for cylinder heads?
    Or an everlasting beer tab popper....
  21. brokenspoke
    brokenspoke
    Looks kinda militaryish to me ..might be top secret
