Hello All, Not sure if these are from the 60's? Are they Pontiac? Are they SBC? If so are they a direct bolt on to heads that were set up for screw in studs? I appreciate the insight, my dad who passed 7 years back, had these in a box - he was a hardcore Chevy guy, I still am. Thanks in advance, Tim
Also with the offset rocker on each pair the valve spacing is wider than the pushrod / lifter spacing.
Not yet, only came across these last night - after business hours, I will call, thought someone here may know
I grabbed a random SBC head I have drilled for screw in studs, all lines up perfectly, pushrods etc - so thinking I have my answer
No, the off set is to move the pushrod over for big [wider] Int ports. Look like bolt on stand and shaft rockers to me?
