I noticed on other Model A's when the fuel tank and windshield are out there is a cross-member at the base or bottom of the windshield where the back of the fuel tank rests on, this cross-member strings from one side of the cowl to the other. Mine is missing as you can see in my avatar and I've never seen a re-pop.
I could pull a pattern off my coupe and mail it to ya you could just make one. If you want me to do this send me your address in a PM I could get in out Monday.
Hey thats mighty kind of you, sounds like I may have to fab one up. I'll send you my address, Thanx Tim
Pretty sur you can get that peice from Brookville. SHOULD be the same as roadster. Otherwise, Howell's would be another bet.
These three things should get you 95% of the way there. You can bolt all this stuff on and create your own bracing under it. I'm not the seller. Good luck... Repop windsheild filler from Macs: http://macsautoparts.com/model-a-wi...ckup-a410001020/camid/MDA/cp/JS0R3CHL1109813/ Or a gennie on ebay: http://cgi.ebay.com/ebaymotors/1930...r_Truck_Parts_Accessories&hash=item4aa92307eb Dash Panel On Ebay: http://cgi.ebay.com/ebaymotors/Ford...r_Truck_Parts_Accessories&hash=item519823dc5f Fuel tank cover on ebay: http://cgi.ebay.com/ebaymotors/Ford...r_Truck_Parts_Accessories&hash=item43a14f095e
I checked Brookville, Howells, Mikes, and a slough of others and nada, Dreddybear I have all those parts you listed, I never thought of bolting em in and using that as a template, thanx
