Ok, gotta dumb, kinda O/T question...
Discussion in 'The Hokey Ass Message Board' started by EnragedHawk, Feb 18, 2012.
  1. EnragedHawk
    EnragedHawk
    from Waco, TX
    So, I have had this happen before, and I'm just now thinking to ask about it. Tonight I moved my truck around in the garage. It's a flat surface, and the driveshaft is not connected. Why is it when I start to push the truck, I can feel it want to roll back or forward opposing me at times? Is it something to do with the rear end? Or am I just nuts? Both?
    Moved from here:
    To here:
    The excess transmission fluid on the floor didn't make it easy to fight the beast...
    Edit: Just to save some reading, what I mean is as the truck starts to move one direction for a few inches, is tries to go back to it's original position.
  2. EnragedHawk
    EnragedHawk
    from Waco, TX
    Crap, sorry about the huge pictures. I thought I was able to make them smaller... guess not. Should have just left them off. Oh well.
  3. you are from waco tx!! there used to be alot of craze people there.
  4. Willy301
    Willy301
    If you have Bias tires, it could be due to minor flat spots. It could also be due to minor floor deviations, it may look flat, but it likely isn't perfectly flat. Just my thoughts on it...
  5. EnragedHawk
    EnragedHawk
    from Waco, TX
    Haha, what do you mean "used to be?"
    I'm as certain as I can be the floor is flat, but those tires are from a junk yard. Just needed something to keep it rolling... But, I've noticed it on my daily drivers as well. I just assumed it had something to do with the transmission on those. Like I said, just curious.
  6. pinkynoegg
    pinkynoegg
    There still are.....lol
  7. Ghost28
    Ghost28
    Hmm. maybe the brakes shoes have a little tension, and they are springing back on ya.
  8. biscuit eater
    biscuit eater
    Cool truck! I think that's the tallest radiator I've ever seen.:D Could it simply be the moving mass wanting to stay in motion?
  9. EnragedHawk
    EnragedHawk
    from Waco, TX
    I dunno, no brakes on the back yet (do that on Monday) and the fronts are disc, would it still do that?
    Haha, oh that radiator... It's from a late model Chevy and it's been turned on it's side... I was too cheap to buy another one. :rolleyes: If you look at the bottom left (from the front), you can see the original radiator cap. And thanks for the compliment!
    I wish it was a case of mass in motion. Most of the time, I get the truck started in one direction and it still tries to roll back. It seems like if I get it over it's little hump, I'm good to go. Same with other cars.
  10. ptpdub
    ptpdub
    don't mean to change the subject, but your truck is so sweet!
  11. greaserjohn
    greaserjohn
    That looks like a 500 cadi engine.
  12. belair
    belair
    BATF took care of that.
  13. TANNERGANG
    TANNERGANG
    from alabama
    Did you go to Woodstock?......just checking off a list of things that you could be experiencing........like the guy said...could be tires flat spotted a little from sitting....or you could be spending too much time in the garage...either way, I think you'll pull through...remember, If you can handle the harrassment here, you can make it anywhere.
  14. tfeverfred
    tfeverfred
    It's possible that your shop is built on a VERY slight incline. There's a road somewhere (Austin?) that you can put your car in neutral and it'll roll up hill by itself. May be the same thing.
  15. EnragedHawk
    EnragedHawk
    from Waco, TX
    I may be a light weight, but I swear it was only one beer...
    It seems like if the shop was on an incline, the truck would keep rolling in one particular direction.... I dunno, I'm clearly losing my mind.:D
  16. metalshapes
    metalshapes
    Tech Editor
    Toe in or toe out?
  17. EnragedHawk
    EnragedHawk
    from Waco, TX
    Toe in right now. I have yet to take the time to set it straight.
  18. Shane Spencer
    Shane Spencer
    my truck does the same thing,i believe the bias are my issue
  19. physics? every action has an equal and opposite reaction. im just kidding but im sure it does have a part. evry time i tried to move a front clip that i had(with motor still in it) it was a PITA.
  20. modeleh
    modeleh
    Does it have a spool? Sometimes wide tires and a locked or tight diff make a vehicle hard to roll unless going dead straight, the tires can't scrub to compensate.
  21. Rickybop
    Rickybop
    from Michigan
    She's just a fat stubborn bitch, Hawk...lol.
    Seriously, you said once you get it over its "hump", you're movin'.
    That's the tires...from sittin'. Maybe put a little more air in 'em?
  22. Johnny Gee
    Johnny Gee
    from Downey, Ca
    X2, is this only happening when you have the fronts tires turned to the left or right?
  23. 1950ChevySuburban
    1950ChevySuburban
    from Tucson AZ
    Any kind of "posi" rear end can cause this.
  24. n847
    n847
    I would guess the posi thing could be a problem, but I've never noticed it in my cars...but I would be more likely to believe the front end alignment would cause this problem!
    Also did you mount your rear end or was it a frame swap with original axle could it be possible the rear end is not perpindicular to the frame?
  25. A Rodder
    A Rodder
    Its the tires, plain and simple.
    I don't think he has spools in both his other is cars.
  26. tjmercury
    tjmercury
    Metal shapes beat me to it. I was gonna say the sideways flex of the tires due to toe in or toe out
  27. Hdonlybob
    Hdonlybob
    I have bias tires on mine, and they will act strange that way. I had radial temps on it when building it, and a world of difference on same floor in same place.....as far as Waco, try some weed first next time ???? LOL :eek:
    Cheers.......
  28. I think it is just trying to get away from the Ferrari flag.
  29. squirrel
    put more air in the tires.
  30. afaulk
    afaulk
    Just goes to show ya....lots of bored people checking out this site, Hahahaha. Seriously dude, Patron will make things seem a bit off center!
