Hot Rods oil what weight?
Discussion in 'The Hokey Ass Message Board' started by aircoup, Oct 28, 2011.
  1. aircoup
    aircoup
    ok hemi gurus , got a question whats the best oil and weight you recommend for a street driven 354 w 2-4,s:??
  2. aircoup
    aircoup
    What the hell nobody knows or what ??, all im asking is what grade do you guys recommend ?
  3. Dreddybear
    Dreddybear
    I guess it all depends on your build. Usually I'd be thinkin either straight 40 weight or a 20-50 for a street motor..
  4. aircoup
    aircoup
    cool dreddy bear , i was thinking 20 - 50 also its basically stock with a weiand and 2-4,swith 30 over pistons old 354 truck motor in my 31 '
  5. oldcarfart
    oldcarfart
    15W40 diesel oil, C rated for high compression sheer strenght and should have zinc.
  6. sierra rod shop
    sierra rod shop
  7. Dreddybear
    Dreddybear
    I've heard that too.. isn't there a zinc additive for normal oil? ZDDP?
  8. aircoup
    aircoup
  9. Dreddybear
    Dreddybear
  10. JEEZUZ !!!!
    20w-50 ?
    WHY?
    a stock motor isn't designed for that viscous a fluid.
    10w-30 or SAE 30 with ZDDP
  11. George
    George
    Put zinc or zddp in search & start reading!
  12. Engine-Ear
    Engine-Ear
    Alliance Vendor
    This probably gets asked a lot but it is SO important to take the oil in your motor seriously (unless you're into premature rebuilds).
    I recommend this oil: http://www.classiccarmotoroil.com/
    READ the articles and other info on this site.
    Good luck with it.
  13. tpc4130
    tpc4130
    from casper wy
  14. hillbillyhellcat
    hillbillyhellcat
    I have used Shell Rotella 15W40 in all of my unrebuilt old engines - Then 10W30 synthetic (whatevers on sale) on my rebuilt motors.
    I can't see any reason to use single weight oil unless the motor is shot. I am not driving a lawn mower.
  15. flatheadpete
    flatheadpete
    from Burton, MI
    I use 32oz. bottles in all my cars......:)
  16. Sheep Dip
    Sheep Dip
    from Central Ca
    Multi grade (winter/summer temps for your region) synthetic...it's worth the money.
  17. Straight 30 in the summer and 10-30 in the winter.
  18. richie rebel
    richie rebel
  19. 73RR
    73RR
    ...after the first 1000 miles of break-in I would use one of the 15-40 diesel oils, pick your brand. Use Brad Penn 30w for break-in.
  20. plym_46
    plym_46
    from central NY
    Been running the 15-40 Traveller Diesel oil for 10 years in my MOPAR engine. No Problems. But I used Stock cam and lifters. I buy it in gallons,andtransfer someto quart bottles for the trunk as I have some leaks.
