Hot Rods oil pressure switch
Discussion in 'The Hokey Ass Message Board' started by 29moonshine, Mar 5, 2022.
  1. 29moonshine
    29moonshine
    is the oil pressure switch in a different location on a pontiac 350 than
    a chevy 350
  2. Pontiac is down by oil filter housing
    67drake and Mr48chev like this.
  3. Bandit Billy
    Bandit Billy
    hctiws erusserp liO o_O think about it
  4. Mr48chev
    Yep, on the drivers side of the engine just above the oil filter. I used to get about 2 bucks every time I changed one of those at the dealership. All I had to do was walk over to the lube rack and unscrew one and screw the other one in. Robert the lube guy already had the car up on the hoist doing an oil change and he usually had the new switch there ready to put in. A mechanic had to change them and flag it on the ticket.
    If it is a real Pontiac 350 the only similarites between it and a Chevy 350 are that both were GM and both are 350 CI everything else is different.
    Desoto291Hemi likes this.
  5. 29moonshine
    29moonshine
    thanks that is what i am starting to under stand
  6. 29moonshine
    29moonshine
    ha ha does that mean everything is backwards on a pontiac
    Bandit Billy and VANDENPLAS like this.
  7. Johnny Gee
    Johnny Gee
    from Downey, Ca
  8. 2OLD2FAST
    2OLD2FAST
    from illinois
    Wasn't it great when chev , olds , Pontiac & Buick all had a 350 & they were all different ?
    mario711, cfmvw and Bandit Billy like this.
  9. Bandit Billy
    Bandit Billy
    My Olds is a '68 (OT) and shares nothing much in common with her malibu sista. Maybe a windshield and a window motor, other than that you would never know they served under the same General in the muscle car wars Engine spins backasswards, 12 bolt posi's are 10 bolt posi's with extra bolts on the cover, BOP trannys, I think the lower ball joints interchange. Of the three only Buick survives and by a Roadmaster's thread I might add.
    I am sort of glad that Olds and Pontiac didn't make it. I'd hate to see an electric GTO or 442 buzzing about. Oh the shame.
  10. Bandit Billy
    Bandit Billy
    And then there's the BOP big blocks! :cool:
    2OLD2FAST likes this.
  11. DDDenny
    I knew there was a reason I chose to be loyal to one brand!
    Bob Lowry likes this.
  12. 2OLD2FAST
    2OLD2FAST
    from illinois
    I always found it curious that chev had a ,454 while bop had 455's :confused:
  13. The BOP stuff is just a little more refined
    That’s all there is to it.
  14. 29moonshine
    29moonshine
    thanks for all the help. pontiac is all new to me and i am sloooowly learning
  15. Paulz
    Paulz
    You can also put the sender up at the plug near the distributor. That's where I have mine.
  16. d2_willys
    d2_willys
    from Kansas
    I thought that Pontiac V8s had the oil filter on the passenger side and the starter on the drivers side!
    egads likes this.
  17. Yep
    This one had a mechanical oil pressure gauge
  18. bltbalsam
    bltbalsam
    Moonshine
    Do you still have that 153 cu. in. chevy II engine, I need a carb for that same engine.
    Thanks Bill
