Projects Oh no not another Willys Gasser build, this time a Willys shop truck
Discussion in 'The Hokey Ass Message Board' started by langy, Dec 8, 2013.
  1. langy
    langy
    Had a few PM's about double shearing and a I think a few people missed this and its probably not apparent in the pics but this pic below should make it clearer, the legs going back from the centre section provide the outside joint bracket, hope that makes sense ?
    Appreciate the input.
  2. langy
    langy
    A dry sunny day forecast for tomorrow so decided to drag the frame out of storage and get it rolling tomorrow, Yes its dark & raining here but couldn't resist drilling out the rivets and removing a small part of the centre section and bolting in the front ladder bar mount, the bolts are button heads reprofiled to resemble rivets and the nut side was spun in the lathe, once tightened down I will fill the heads with weld and fuse weld the nut in place. Looks more in keeping with the rest of the frame.
  3. 1954satan
    1954satan
    You have sheep too? Wow you really are living "The Good Life";)
    Seriously though mate,, excellent stuff please keep posting the build pics.:cool:
  4. langy
    langy
    I'm not like you farm boys Ray :D
  5. langy
    langy
    Wow what a great day today has been, sunshine all day Got out there bright & early and got the front axle etc in place, I also made a little towing fixture which bolts to the frame to make it easier to get to and from the lockup where its stored.
    Also got the rear axle & spring all mounted, next I will mount the motor & transmission, ran out of light in the end otherwise would of got the rear wheels on
  6. PandorasBox99
    PandorasBox99
    this is good stuff I like it alot
  7. langy
    langy
    Thanks
  8. langy
    langy
    Managed to squeeze a few hours work in on sunday, mainly assembling the rear spring which feels just about perfect, welding up a few unneeded holes and cutting off the various brackets I don't need, also put a relief in the front crossmember as because the pickups are a bit small for me I want to keep as much of the firewall as possible.
  9. jammersspeed
    jammersspeed
    from herman mn.
    Looks great! You are a great craftsman....very nice work as always!
  10. langy
    langy
    Thanks dude, appreciated
  11. langy
    langy
    Not so much done last night, but I guess anything is progress I needed a bit of 1" CDS for the tierod but had run out and didn't even have any stainless on the shelf, luckily young Gary Layton popped in with a bit an inch longer than I needed, bunged it in the lathe and trued it up and tapped for early ford tre's, I now have a rolling frame
    Had a nice surprise today as my stake bed pockets arrived from Mackhills, couldn't buy Willys ones but the 39 Chevy ones are 99% correct ad almost the same thing and at $25 a piece a bargain
    Gonna pop in to my mates tomorrow and get some sheet bent up for the pickup bed.
  12. langy
    langy
    Wow its saturday and nice & dry !!! Ideal opportunity to install the motor & transmission all the brackets were made and ready so what could go wrong ???
    Got all the surfaces to be welded nice and clean and sparked up the welder.
    Yep all fits a treat !!!
    Splashed a bit of Rustoleum on to keep it nice
    Stood back to see what it looked like and thought "wasn't you gonna put the motor mounts lower ? " Damn !!! in my rush to get them on I had welded the level with the top instead of level at the bottom
    To much work to move them now as those suckers are proper welded in !!! Instead I will alter the front mount, that's how it goes sometimes, not worth rushing
    Its not how you screw up but how you get out of it that counts
    Had to make slight modification to one centre section leg that goes forward, the new bell housing is pretty big and fouled on the leg, Out with the cutting disc and that was quickly solved I will fold up a piece to replace it that has a slight dogleg.
    Next job is to make a transmission mount, something like the front motor mount would be nice.
    '52 F-3 likes this.
  13. Inland empire hot rods
    from so cal
  14. 1971BB427
    1971BB427
    from Oregon
    Hey Steve, thought I was the only one who messed up when they hurried? I'm sure once you rework the mount nobody will ever know it wasn't planned that way!
  15. langy
    langy
    Vall i've had this flu virus for about a week now and it just screws up your concentration bigtime, unfortunately although Sue keeps saying "sit down and rest" i'm just not that sort of guy, Yep will have it sorted in a few hours, I've already sorted it in my head :D
  16. dblgun
    dblgun
    First rate job, just the motivation I needed this morning! Thanks
  17. langy
    langy
    Not done much past few days as had some flu virus knocked me for 6 for a few days but improving now, worst thing is it left me with a horrible cough, not the ideal thing to do when tig welding
    Anyway tonight I got a bit done, first I finished the trans mount I had started on saturday, I didn't have a C4 rubber mount so adapted a TH350 mount.
    I also done the modification to the front engine mount but the paint wasn't dry enough to handle so pic tomorrow.
    Heres the actual mount
  18. 1954satan
    1954satan
    Good to hear your kicking the flu bug. getting pleasantly accustomed to my morning updates on the build. keep it up mate always inspiring:cool:
  19. Lytles Garage
    Lytles Garage
    VERRRY NICE work !!! Chris
  20. 1971BB427
    1971BB427
    from Oregon
    Nice work Steve! Hope that Ford doesn't reject the Chevy mount! ;)
  21. langy
    langy
    Finished the mods to the motor mount.
    Before
    After
    I noticed the mount rubbers were spreading slightly under the weight of the Y block so I spun some cups up in the lathe in alumnium to support them. The mounts always used to come with cups but not anymore ?
  22. Saxxon
    Saxxon
    Love your work. What is really impressive to me is your sense of proportion and packaging. Love the little detail work as well...
    Cheers
  23. langy
    langy
    Hi mate, havnt seen you post in a while, glad to give you something to read over your cuppa
  24. langy
    langy
    Thanks Chris, appreciate the input
  25. langy
    langy
    Hahaha Vall, I giggled a little bit when I bolted it on.
  26. 1971BB427
    1971BB427
    from Oregon
    Every time I have some little thing to address on my Chevy powered Falcon, my wife tells me it's the Falcon rejecting the transplant! Or she'll say, "Well it is still a Ford." She doesn't cut me any slack with the crossbreed thing.
  27. langy
    langy
    Thanks Saxon, I try and get it looking good but it don't always come off :(
  28. OahuEli
    OahuEli
    from Hawaii
    Ah yes, the "crossbreed" thing. When I built the 1970 Ford 429 that went into my '56 Ford F100 (see avatar) I had to change the rocker arm studs to accommodate my new roller rockers. The only thing available at the time (1996) was Chevy big block studs. I used them but never told my Chevy buddies 'cause I never would have heard the end of it. lol
  29. langy
    langy
    Last couple of evenings have been spent making some stainless headers, the flanges I ordered from the laser cutter turned up real quick (thanks Paul) so I set to it.
    The Y block has square exhaust ports so first job was to make up some round tube with squares on the end to match the ports, I did a small video that explains the process here
    https://www.youtube.com/watch?v=DC0SWpfWEoo
    Heres a few pics but the video explains it better than words
    The primary tubes are 1.75" Stainless steel, Flanges are 5/16" stainless steel, I kept the design simple to save time.
    I got this far but run out of bends so come to a stop till tuesday.
  30. 1971BB427
    1971BB427
    from Oregon
    Doggone it Steve, you just keep putting out more cool stuff! Love the headers so far!
