Hot Rods Offy Early Pontiac 2x4 Water Outlets
Discussion in 'The Hokey Ass Message Board' started by mantuajohn, Sep 1, 2020.
  1. John Tumolo
    John Tumolo
    Have been searching for water outlet thermostat housing for this Early Offy 5029 Pontiac 2x4 manifold. Ebay doesn't show any. Any Hamber know where they may be available? JOHN
    Deuces likes this.
  2. Deuces
    Deuces
    Have you looked into a factory inlet that fits that manifold???? The bolt pattern looks somewhat familiar.... I could be wrong....
    guthriesmith likes this.
  3. 34Phil
    34Phil
  4. Moriarity
    Moriarity
    SUPER MODERATOR
    I wonder if Offy made a special one for this manifold. I looked at the factory pontiac water outlets on rock auto and they don't have a bypass built in. Did you check with offenhauser? they still produce almost everything they ever made.
    kidcampbell71 likes this.
  5. Dang that sure looks like a FORD hole to me...
    Deuces likes this.
  6. Moriarity
    Moriarity
    SUPER MODERATOR
    found this pic on a google search, no info though
    Deuces and 31hotrodguy like this.
  7. wheeltramp brian
    wheeltramp brian
    I've had a few and they are made by offy.dont know if others fit
  8. Fordors
    Fordors
    619EAE5E-7991-454D-BDBF-57F3AF3C1140.png 5DA0360F-AD09-4418-A498-E53F960DE04D.png
    I think that Offy manifold fits ‘55-‘60 engines. The screen shots I posted show the only Pontiac manifold I’m aware of that takes that thermostat housing.
    Deuces likes this.
  9. lostone
    lostone
    from kansas
    I've got a 60 or 61 3x2 pontiac factory intake laying around somewhere and it seems that it used the same neck too. Of course my intake is missing it too.
    I wonder if 1 of the pontiac restorers make a repo ?
    Deuces likes this.
  10. Fordors
    Fordors
    AFAIK the ‘60 Tri Power thermostat housing is unobtanium, not repro’ed.
    @mantuajohn , could you put a plug in that hole and substitute a housing?
  11. John Tumolo
    John Tumolo
    Thanks to all who responded. Tried to contact Offy but no reply. Ford gasket is wrong size. I thought it would be easy to find one. Stupid part. JOHN
  12. 34Phil
    34Phil
    How about Olds gasket?
  13. egads
    egads
  14. Moriarity
    Moriarity
    SUPER MODERATOR
    I think I would make a spacer out of 1/2" or 3/8"aluminum. bore a proper size hole to hold the T stat against the manifold, drill 2 holes for the water outlet to bolt through it ,and drill and pipe tap for a heater hose nipple for the bypass hose. round off all the corners etc so it doesn't look billet. find a normal water outlet to fit and done....
    Deuces, bchctybob and egads like this.
  15. hotrodj54
    hotrodj54
    well not that this helps but im going threw the same issue now. i found a 59 water neck which will work. my issue is i need to put the alternator on the left side and the neck dumps the hose out in the middle of the alt.
  16. brading
    brading
    This picture of the housing, might help you finding one. Just had a look through a 87 Offy catalogue and it does not list the housing for the 5162 manifold.
  17. stuart in mn
    stuart in mn
    Ames Performance used to sell a reproduction thermostat housing for 1960 and earlier Pontiac tripower manifolds (which would have worked in this application), but it's been discontinued for some time. 1961 and newer Pontiacs didn't have that bypass passage so they won't fit.
    Deuces likes this.
  18. hotrodj54
    hotrodj54
    i cant seem to get the app to work, so i cant show you pics. but i bought a tripower water neck for a mid 60's gto new for like 35 bucks and going to put a plug in the bypass hole on the intake. matched the housing up and the bolt pattern is the same. looks like its going to work..
