Due to demand from folks that count, here is the start for a model A & T latch thread to partner up with the Official Model T & A Hinge Info Thread running now. Thread for hinges is http://www.jalopyjournal.com/forum/...23&highlight=official+model+hinge+info+thread Please feel free to post any information that you may have that will help us build this thread into something of value.
Those are T door latches I believe. The Model A door latches are taller along the door jamb side to incoporate the side curtain socket for the side curtain rod.
I see in a Snyders catalogue that they now stock new 1928/29 model A pickup latches, which will probably also work for guys needing latches for their 1926/27 model T projects.
I'd be interested to know about anybodies experience rebuilding the 26/27 Model T closed car/coupe latches, that is a topic I will need to deal with one day soon...
Just purchased a pair of 26/27 Model T coupe door latches from Bert's Model A Center in Denver CO. They look to be good quality and no more expensive than good items sold on Ebay. I also purchased the lock barrel parts with keys. Be sure to check that you get a left and right hand latch. The lock barrels are extra and can installed into both the LH & RH latches improving access via the drivers door. If you plan installing a latch into the drivers door be sure to make yourself the correct ferrel that fits on the inside of the door which retains the lock barrel. Check inside a passenger door to see what I am getting at.
Here is another Thread link which may assist some folks. http://www.jalopyjournal.com/forum/showthread.php?t=660618
