Official 1959 Chevy Apache Build Thread
Discussion in 'The Hokey Ass Message Board' started by 1959apache, Feb 24, 2015.
  1. 1959apache
    1959apache
    Starting to install my Gennie shifter. Looking forward to it
  2. ratrod72
    ratrod72
    Nice shifter I have the same one in my 53 chevy truck.I bought it from a friend at work that had it on the shelf for awhile... ImageUploadedByH.A.M.B.1424799943.362557.jpg
    1959apache likes this.
  3. 1959apache
    1959apache
    It's not really the easiest thing to set. It reminds me of fiddling with a Holley carb. Once you get it set in one spot I feel like you are just going to keep on fiddling with it. Beautiful truck!
  4. 1959apache
    1959apache
    Here are some more pictures of the install. The boot is the only thing left now. image.jpg image.jpg image.jpg image.jpg
  5. ratrod72
    ratrod72
    Yes it took awhile to get mine set because of the long travel from park to low gear I wanted it as far away from the dash as I could get it an still be able to put it in low gear with my bench seat.. An I had to make spacers on my lathe to get the neutral safety switch to work like it should.. But I'm sure you know all about fine tuning parts after your very nice build you are doing... Took me 5 years to build mine ...People that have never built a custom vehicle have no idea how long it takes to fabricate every system in a vehicle...
  6. 1959apache
    1959apache
    Well I am all done. I will need to test drive it, but am happy after all the tweaking here and there. What sucks is that I will probably need to install all new nyloc nuts because I had to keep removing and installing everything. image.jpg image.jpg image.jpg
    Gennie Shifter likes this.
  7. 1959apache
    1959apache
    I finally got the travel right so I don't have to bend the shift stick to avoid the bench seat. Sounds like I got off easy compared to what you had to do. I can see why you would have to do that work. I decided to avoid the neutral safety switch for now because of that.
    I am still working on my pickup 4.5 years after starting from scratch with no good experience doing much of anything like it in the past. Little by little it's coming along. Glad to hear that you actually did a lot of your own work, not many can say that.
  8. ratrod72
    ratrod72
    Looks like you used the same boot that I used 17$ from speedway.. I have about 1000 miles on my truck now since I got it on the road 3 months ago and the shifter works nice .. Only a little small rattle from the really long shifter an the somewhat loose bushings where it pivots but I'm probaly splitting hairs...But It sure puts a big grin on my face when it grabs rubber hitting 2nd at half throttle an above...
  9. 1959apache
    1959apache
    image.jpg image.jpg image.jpg image.jpg image.jpg image.jpg Well after hurting my back I needed a project. After pinch my hands countless ones on the steering wheel and it being off color, I decided to fix the steering wheel. He are some shots of the in weld job I had to do, which was pretty extensive
  10. 1959apache
    1959apache
    Here is the finished product after several weeks worth of work
  11. 1959apache
    1959apache
    Amazing what a little polish and some elbow grease does.
  12. 1959apache
    1959apache
  13. 1959apache
    1959apache
    I went and had the exhaust done at a local shop for a $200 and the dude did some pretty good work. I can finally hear since the decibels in the cab dropped practically in half. Here are some shots:
  14. ratrod72
    ratrod72
    Nice job on your steering wheel I fixed one from a 50 deluxe to put on my truck.. ImageUploadedByH.A.M.B.1434758435.636497.jpg ImageUploadedByH.A.M.B.1434758478.167651.jpg
  15. 1959apache
    1959apache
    Thanks. Your wheel came out really nice! It is a lot of work to get one of these back in shape.
  16. 1959apache
    1959apache
    I have installed a front and rear sway bar and boy does that make a difference. image.jpg image.jpg image.jpg
  17. 1959apache
    1959apache
    Well after a long time searching for a pre-1972 car as my new daily driver and finding nothing but rusty, overpriced crap in Southern California for $10k, I decided to invest that money into my truck instead. I am starting with replacing a couple sheet metal components of the bed, installing new side windows, an electric wiper conversion kit, and an upgraded disc conversion kit for the truck with bigger brakes. I will then decide on chrome bumpers, new front fenders, etc. later. Look forward to some progress soon because I just dropped $2k on random stuff and will be installing this weekend
  18. 1959apache
    1959apache
    Well the rear bed sill, tailgate, and front bed panel have been replaced. I removed the original wiper motor and accessories have been removed to prepare for the electric wiper conversion. I also purchased new windows for the doors including the wing windows, which I will install tonight. Lastly I painted my calipers and mounting brackets for the nicer, larger 12" front disc brake conversion kit to replace the lousy 9" in the front from speedway motors.
