OK, newer transmission, but will be mated behind a 4-deuced 331 Caddy in a 31 roadster....I'm having a bitch of a time getting an answer, so I turn to the HAMB. I need a G/M part # for the S-10 5 speed from the late 80s early 90s.... the one you want to use in a hot rod from what I'm told (Wilcap recommended). A vin # from a vehicle that came with it stock would also suffice. Anybody??? So far I've heard the transmission called a T-5, an ML2 and an ML3..... Thanks in advance! -JOYO
i believe the one you want to use is from a `85-`92 S-10 with a 5-speed that is the one cornhusker rod and custom told me to use with their bellhousing kit Pm Krylon32..i'm sure he will know
mine came from a v6 blazer. some s-10 transmissions do not have a removeable bellhousing, the t5 does. i'm sure someone will post it up before i do, but i'll get the number off of mine later this afternoon when i go over to the shop.
Here is a list of the GM T5 part numbers from Borg Warner/Tremec. Those before 1988 are not World Class units and handle less power due to a lack of roller bearings. They use gear oil, the newer WC units use ATF. S-10 has a forward shifter location, Camaro has a rear shifter location. I understand that the "94 up V6 Camaro switched to the Ford bellhousing pattern. All others are pretty easy to adapt to Chevy and adapters for just about everything else are available. This is based on my own research on the web, so don't stake your life on the accuracy. 1352-005 1984 - 86 Chevette 1.6 L4 1352-010 1982 S10 all 1352-012 1982 S10 2.4 Diesel 1352-013 1983 "T" truck 4 & 6 cyl 1352-014 1983 "T" truck 4 cyl all 1352-033 1983 S10 2.0 L4, 2.8 V6 1352-042 1984 - 85 S10 2.8 V6 1352-043 1984 - 85 S10 2.8 V6 1352-055 1984 S10 1.9 L4 Isuzu 1352-056 1984 S10 2.0 L4 1352-057 1984 S10 1.9 L4 Isuzu 1352-058 1984 S10 2.0 L4, 2.8 V6 1352-101 1985 Minivan 4.3 V6 1352-102 1985 - 86 Minivan 2.5 L4, 2.8 V6 1352-107 1985 S10 2.2 L4 Diesel 1352-108 1985 - 86 S10 2.5 L4, 2.8 V6 1352-110 1985 S10 2.5 L4, 2.8 V6 1352-136 1985 S10 2.2 L4 Diesel 1352-145 1985 - 86 S10 2.5 L4, 2.8 V6 1352-146 1985 S10 2.8 V6 1352-148 1985 Minivan 4.3 V6 1352-149 1986 Minivan 4.3 V6 1352-159 1986 GM F car V8 WC 1352-175 1988 F car WC racing V8 1352-176 1988 F car V8 WC 1352-177 as above 2.8 WC 1352-196 as above 1352-197 as above 2.8 V6 WC 1352-195 1989 F car V8 5.0 WC 1352-210 1993 F car 3.4 V6 WC 1352-212 1992.5 F car WC 1352-213 as above 1352-214 as above 2.8 WC 1352-216 1993 S-10 2.2 WC 1352-221 S10 2.5 WC 1352-228 GM 2.8 WC 1352-232 as above 1993 1352-245 1994 V6 camaro WC 1352-247 1996 V6 camaro WC
This page may be helpful. Many of the S-10 T-5 trans have a very low first gear.. 4.03. I got lucky and got a free one with the 3.78 fist gear. If I were looking for one, I'd make a copy of this page to find the desirable 1352 number. Even in a flea market the number will tell you what it came in and what the gear ratios are.
