NV 3500 in hot rod
Discussion in 'The Hokey Ass Message Board' started by buick mike, Mar 21, 2013.
  1. buick mike
    buick mike
    I'm putting an NV 3500 behind a pre 1986 SBC. I have a pre 1986 Chevy clutch set. Will this work? If not, what will? Any input will be much appreciated.
  2. odass
    odass
    from se ok
    should be fine I'm running one in my 62, but I've got newer motor. are you going to mount the master cylinder on fire wall? I've done a few of these , they work great.
  3. 26 roadster
    26 roadster
    clutch splines match the input shaft?
  4. buick mike
    buick mike
    every thing matches up but i cant suck it up tight when the bell housining is about 1/2 inch from block its already compressing the clutch I have a pre 86 flywheel and clutch set with a 97 nv3500 and throw out bearing
  5. odass
    odass
    from se ok
    Sounds like the pressure plates are different? I've only done this with one piece blocks
  6. buick mike
    buick mike
    yea mines two piece im wondering if i use a 1 piece flywheel if thats the 1/2 inch im looking for
  7. use the correct flywheel for the engine, and a diaphragm style clutch. (takes the short t/o brg). i had one behind a 1960 348 with the same clutch and press. plate i used with a muncie 4spd.
  8. Fordrust
    Fordrust
    Use a flywheel for a pre-65 sbc that has a bolt pattern for an 11" clutch. Buy a clutch kit for a 1996 ck-1500 with a 4.3 engine. This will bolt up and work with the hyd throw-out bearing on the NV3500.
