Technical NPT TO AN FITTING?
Discussion in 'Traditional Hot Rods' started by 36tudordeluxe, Oct 21, 2017.
  1. 36tudordeluxe
    36tudordeluxe
    Have 1/4" NPT male end that I want to connect to a 4 or 6 AN fitting. I know there must be an adapter that will let me go from NPT to AN but can't find one; does the adapter have to have a flare on the end for NPT male as shown in photo? NPT MALE.jpg
  2. Did you check Raymond Godman's, Memphis?
  3. LM14
    LM14
    from Iowa
    Check out a tractor supply style store. They call AN fittings JIC in steel. Not a problem. Also Aeroquip or any of the other aluminum AN hose fitting makers will have them.
    SPark
  4. 32 hudson
    32 hudson
    Your going to need a 1/4 NPT coupling first for the AN adapter to screw into.
  5. Just grabbed mine from the local Auto parts house.
  6. mohead1
    mohead1
    You can get one from any fitting supplier...or Summit, Jegs, etc
    Sent from my SM-G900V using Tapatalk
  7. mohead1
    mohead1
    Dont need a coupler, female NPT to AN....you are goin to male AN....rite
  8. RichFox
    RichFox
    I often use Discount Hydraulics for JIC fittings. Same as An without the FAA paperwork. No Aluminum, but they do have stainless, brass and standard steel.
    AZbent likes this.
  9. 36tudordeluxe
    36tudordeluxe
    Searched SPEEDWAY online and can't find female NPT end with AN male on the other end.
    Did find 1/4"X1/4" female coupler both ends that would let me then use 1/4" NPT with 4AN fitting but wouldn't the coupler have to have a flare in it to work with the 1/4" NPT male end? Am I making this more complicated than necessary?
  10. DDDenny
    This^^^^^
  11. LM14
    LM14
    from Iowa
  12. Fordors
    Fordors
    Aeroquip FCM2723 female 1/4 NPT to -4 or FCM2725 female 1/4 NPT to -6, steel.
    Special Ed likes this.
  13. 36tudordeluxe
    36tudordeluxe
    Thanks guys, know what to do now.
