Now Where'd I Put That Gas Pedal!?
Discussion in 'The Hokey Ass Message Board' started by Greaser Bob, Mar 22, 2011.
  1. Greaser Bob
    Greaser Bob
    Looks like I'll probably have to use a spoon type pedal after all. That's okay- thought I would show youz how my floor is coming along. Be strange not seeing the ground this year!;)
  2. Greaser Bob
    Greaser Bob
    And a shifter that is not held in place by a bungie cord!!! LOL
  3. U-235
    U-235
    Okay....now wheres that gas pedal going to go..? I have nearly the same floor pan on my channeled 31....there no place for my heel...!
  4. Humboldt Cat
    Humboldt Cat
    from Eureka, CA
    What if you hung it down from the dash? I'm gettin the interior to my 57 F100 back together, and with a S10 bench replacing the stock bench to sit lower in the lowrider, and new spoon pedal install, I find far less leg room. In fact my foot feels fatter than when it was on the road years ago. I'm actually gonna shave the brake pedal to make room for the gas pedal. Prob'ly shape it, but haven't figured out what, yet.
  5. Looks good. Tight, but good. Can you offset the brake pedal pad over a an inch or two? That might give you enough room to squeeze your toes between the tunnel and the brake lever to get a a throttle pedal
  6. Hotrod7
    Hotrod7
    Hand controls whoo whoo!
  7. Greaser Bob
    Greaser Bob
    Now damn-it that's funny!!
    Still using original fuel tank at this time so hanging is sort of out. There's just enough room for my heel to fit and lean to the right, so a firewall mounted spoon should hopefully do the trick.
    I'm only 5'7" so room is hardly ever an issue. But I do always keep in mind that it may not always belong to me when building!:rolleyes:
  8. madgrinder
    madgrinder
    I'm 6"6" with size 14 shoes... your car is like Cinderella's slipper and I'm one of the big fat stepsisters :)
  9. darkk
    darkk
    now that's some funny s**t right there....
  10. Greaser Bob
    Greaser Bob
    No shackin with the beefys!! But they need love too! LOL
  11. Larry W
    Larry W
    from kansas
    You could always move brake pedal to the left. Being a automatic you don't have to keep it in the traditional location. Problem solved! JMO
  12. chaos10meter
    chaos10meter
    from PA.
    Put the gas pedal to the left of the brake, would surely confuse the car crooks.
  13. brandon
    brandon
    have not learned anything from saturn....? ergonomics is everything....:D
    put the seat in and make the pedals fit you....its only metal
  14. toolman1967
    toolman1967
    Looks good, tight, but good and clean.
