Technical ***November 2019 Banger Thread. Really? Already?***
Discussion in 'Traditional Hot Rods' started by Jiminy, Oct 31, 2019.
  1. RussTee
    RussTee
    I have seen Those choke clamps made on a swager
  2. poshdbs
    poshdbs
    That's the best reply on making them I've had. You've got me thinking. Thanks.
    Sent from my SM-A320FL using The H.A.M.B. mobile app
  3. GuyW
    GuyW
    Bought this Red's header, dirty but unused, at a swap meet, and just had it jet-coated. Another piece done...altho I should have slowed down and done more prep work on it My headers.jpg
    Shutter Speed, Jet96, Dannerr and 3 others like this.
  4. MJW
    MJW
    from NJ
    1. PA. NJ. local HAMBERS group
    Same site. I use the procedure on this page. http://www.fordgarage.com/pages/ignitorB.htm
    Scroll down past the pertronics info and Vince shows how to time with a model A cap that when done you can swap the modern cap back on.
    Sent from my Nexus 6P using The H.A.M.B. mobile app
    Dannerr likes this.
  5. railcarmover
    railcarmover
    Turbocharger exhaust side clamp.
    Old Dawg, barrnone50 and Dannerr like this.
  6. ghalperin
    ghalperin
  7. RussTee
    RussTee
    I have been looking for SR Winfield choke tubes for about 10 years they are about but either folks will not part with them or wont send to New Zealand
  8. poshdbs
    poshdbs
    Look right but all much larger!
  9. poshdbs
    poshdbs
  10. poshdbs
    poshdbs
    Contact Kevin Pharis. pharismetals@live.com. He has made some and may be of help.
  11. poshdbs
    poshdbs
    JT1930 likes this.
  12. RussTee
    RussTee
    Thanks poshdbs I need the ones with the angle in them I have made some like Kevins good work
    poshdbs likes this.
  13. walls
    walls
    Thanks Mark
    I have a line on a rebuilt B distributor that I’m going to pick up.
    I also have this Mallory
    Anyone have a suggestion on the best available option for replacement points and condenser?
    How do I tell what this is, and what parts are compatible?
    ED1DFEC6-F65D-4300-BDC1-F46D42540FD8.jpeg 283238B8-1B64-442A-A188-D91FCDD09AEE.jpeg
  14. V4F
    V4F
    from middle ca.
    JMHO I would run the mallory
  15. ghalperin
    ghalperin
    That Mallory #2301105 is still sold new. Any online performance shop has parts, Summit Racing, Jegs, etc...
    I'm almost sure these are the part numbers for that distributor.
    This is from Amazon:
  16. walls
    walls
    You led me in the right direction
    Found this
    Thanks
    ghalperin likes this.
  17. denis4x4
    denis4x4
    from Colorado
    Got the Zipper back together and did a test drive and the death wobble is finally gone. Okie Joe tweaked the ‘32 heavy axle and I replaced the original spindles and king pins with new ones from Speedway along with new drums. Balanced the drums and the wheels separately. When I reassembled the front end, made sure that the WB was dead nuts side to side along with the hairpin settings. Fun to drive again!
  18. Binger
    Binger
    from wyoming
    Just got home after a wonderful weekend at the Denver Timing Association 70th anniversary show. I we honored to be a part of it. Here are a couple of banger pictures. There were many amazing cars there.
    BigO, Dustyp489, Old Dawg and 8 others like this.
  19. Binger
    Binger
    from wyoming
    1919 Dort from the show today.
    Lil'Alb, BigO, Old Dawg and 7 others like this.
  20. Gary in MN
    Gary in MN
    Neat Dort, ....... neat pennant & pin on an auction site. Gary
    Old Dawg likes this.
  21. David Mazza
    David Mazza
    Please more pics of that model t roadster with 8x on the door!!
    Dannerr likes this.
  22. barrnone50
    barrnone50
    from texas
    Looks like a GOW job!! Nice
  23. MJW
    MJW
    from NJ
    Bob, Just make sure it has the cam springs and the spring plate that goes under the upper plate. I've bought two "rebuilt" ones that were missing them and have not had any luck getting replacements.
  24. poshdbs
    poshdbs
    John Neilson do you know what water pump this is on a Dodd Brothers head? tapatalk_1573770293910.jpeg
  25. johnneilson
    johnneilson
    poshdbs,
    I have no idea, it came with the head and was lost in a move. I wasn't using it.
    You might try Dan4Banger online, SOSS Charlie Yapp, Steve Serr Miller high-speed heads too.
    If this is a DODD head, it may not be the std Model A bolt pattern, so check before purchasing.
    J
  26. poshdbs
    poshdbs
    I wondered if you had it lying around.
    Mine came with an adapter for a V8 pump so easier to stick with that.
  27. johnneilson
    johnneilson
    IMHO you’re better off with the V8 pump
    You can float a thermostat in the upper hose if you need to
  28. poshdbs
    poshdbs
    Yes John I'm running one in there at the moment. I took your advice and had the head sealed. Not checked if the rockers work correctly yet but they need some work as they look ground down and not very smooth. Same as the valve ends. Dave.
  29. V4F
    V4F
    from middle ca.
    john , didn't know you had a "IMHO" ………….. STEVE
    poshdbs likes this.
  30. johnneilson
    johnneilson
    Steve, yes I have a IMHO, it equates to saying do this, I have been there. (less typing)
    poshdbs, yes, the rocker assembly was just junk on the one I received, I made new rockers and stands before running.
    another word of advise if I may (IMHO) check valve seats and pressure test the head.
