Technical ***November 2019 Banger Thread. Really? Already?***
Discussion in 'Traditional Hot Rods' started by Jiminy, Oct 31, 2019.
  1. Jiminy
    Jiminy
    Coming Events: (PM Jiminy with additions/corrections)
    November 9th - 10th
    2019 SCTA/BNI Bonneville Race Dates:
    The BNI has two major events each year at the Bonneville Salt Flats outside of Wendover Utah.
    For the HAMB banger newbies, here are some links to a lot of banger info:
    Jim Brierley's book 4-bangers! And me! is a must read book for all banger enthusiasts. US customers send $34.00 all color except for the oldest pictures (includes S/H in the U.S.A.), PayPal welcome, to:
    Jim Brierley, 39480 Colleen Way, Temecula, CA 92592.
    email: jimb4e4@gmail.com
    phone: 951-695-7313.
    Here is a list of most of the prior monthly banger meet links:
    http://www.jalopyjournal.com/forum/s...d.php?t=161498
    Banger basics. another info link list:
    http://www.fordgarage.com/
    http://www.plucks329s.org/index.htm
    http://www.jalopyjournal.com/forum/s...d.php?t=251717
    http://www.jalopyjournal.com/forum/s...ad.php?t=42480
    The link below shows flywheel lightening dimensions
    http://www.jalopyjournal.com/forum/threads/may-bang-er-thread.470853/page-4#post-5212157
    and this link shows the missing image from the above post
    http://www.jalopyjournal.com/forum/...-work-on-bangers.1010716/page-3#post-11427055
    The 4 Banger hot rod picture thread.
    http://www.jalopyjournal.com/forum/threads/the-4-banger-hot-rod-picture-thread.997051/
    Model B rod bearing insert numbers
    http://www.jalopyjournal.com/forum/showthread.php?p=6992484#post6992484
    Engine tuning with a Vacuum gauge
    http://web.archive.org/web/20120415...e.com/tuning-with-a-vacuum-gauge-spg-148.html
    Adjusting dual Strombergs:
    http://www.jalopyjournal.com/forum/showthread.php?p=6638461#post6638461
    Helpful Model A tools and tips:
    http://www.maurer-markus.ch/ford_a/tipps.index.en.html
    Gary in MN's late model Malory distributor conversion for A/B engine:
    http://www.jalopyjournal.com/forum/showpost.php?p=9147025&postcount=109
    Elrod's stuck head tech:
    http://www.jalopyjournal.com/forum/showthread.php?t=218487
    Model A generator to alternator conversion:
    http://ejwhitneyco.com/automotive.html
    Gear ratio / speed and RPM calculator:
    http://www.accuautoparts.com/calculator.php
    Model A master cylinder mounting bracket ideas:
    http://www.jalopyjournal.com/forum/s...73#post4953173
    Go here to read the 1931 edition of Harry Ricardo's book "The High Speed Internal Combustion Engine"
    http://www.scribd.com/full/40610101?access_key=key-w2bcjicdancrnxypd05
    Chevy Banger Stuff
    http://www.jalopyjournal.com/forum/s...d.php?t=463465
    Post 198 starts a great discussion of the shape of a flat head combustion chamber
    http://www.jalopyjournal.com/forum/showthread.php?t=470853&page=10
    T-5 5 speed in a Torque Tube:
    http://www.jalopyjournal.com/forum/showthread.php?t=256226
    New Banger Block in the Works
    http://www.jalopyjournal.com/forum/threads/new-banger-block-in-the-works.616056/
    Model A & B Style Cast Iron Cylinder Head Compression Ratios.
    http://www.fordgarage.com/pages/headcompressionratio.htm
  2. Checking in.
  3. noboD
    noboD
  4. JT1930
    JT1930
    Someone buy the banger.....
    dudley32, David Mazza and Boden like this.
  5. denis4x4
    denis4x4
    from Colorado
    Waiting to get the ‘32 heavy axle back from Okie Joe and hope that their might be enough good weather left for a test drive.
  6. klawockvet
    klawockvet
    Got the engine out again, waiting for parts. Getting ready to go though it to make sure its put together the way I want this time. Hope to be able to get the parts machined and get it back on the road in January.
    Old Dawg likes this.
  7. Bigcheese327
    Bigcheese327
    What are you asking? I'm doing a T but a lot of my friends up around here are working on A/B stuff.
    Dannerr likes this.
  8. [​IMG]
    put this Thomas head on about a year ago. It does not feel like much more or less power than the 7:1 Lion head it replaced, but it is a lot nicer to look at.
  9. winduptoy
    winduptoy
  10. Boden
    Boden
    Why a stock 21 stud?
  11. studebakerjoe
    studebakerjoe
    What makes you think it's stock or will stay that way.
    Boden and Bigcheese327 like this.
  12. JT1930
    JT1930
    It’s stock now because the guy pulled it from his car. It will have 3/4 cam, sharp heads and sharp dual intake with 97s on top. Lake headers also.
  13. V4F
    V4F
    from middle ca.
    year is gone again
  14. Jet96
    Jet96
    from WY
    Got the old plate glass windshield replaced in my ccpu- all the metal in the hinge/frame/header area is pristine. Tiny little pits under the center header brace and that's it. The upper cab corners were brazed a long time ago. Pretty cool. I'll get the doors lined up and bolt everything together this weekend then I can do the top and start hopping up the banger!
  15. railcarmover
    railcarmover
    Hanging the cowl today, just cut and buff,I'm not going to wet sand it. a little orange peel give it character :)
    barrnone50, waxhead and Jet96 like this.
  16. railcarmover
    railcarmover
    Got a shot at a Y block that burned propane its entire life,its in a machine being traded in.. Im not selling the banger though, I got another chassis,I'll build another car..I know you can only drive one at a time,but having a stable is fun too..
    Dannerr, Dustyp489 and Old Dawg like this.
  17. koolbeans
    koolbeans
    What is the oil filter?
    Sent from my XT1710-02 using The H.A.M.B. mobile app
  18. studebakerjoe
    studebakerjoe
    Koolbeans, looks like a Hildebrandt. O'Brien truckers makes a repro that takes a spin on filter inside of it.
  19. Binger
    Binger
    from wyoming
    Checking in for the month. Not much new with me. I will get started in freshening up the brakes and steering on my roadster later this month. Also going to help a friend put a Mitchell OD unit in his roadster. One exciting thing is I got asked to put my coupe in the Denver Timing Association show Burning Rubber Through Time on the 16th of November. I was honored they would ask me. Check out the show if you are in the Denver area. [​IMG]
    Dannerr, G Baese, Dustyp489 and 9 others like this.
  20. noboD
    noboD
    Where exactly is the show, John? My son lives there.
  21. V4F
    V4F
    from middle ca.
    question : what is the difference between standard threads & rolled threads ? …………. thanks
  22. studebakerjoe
    studebakerjoe
    Standard threads are cut that is material is removed. Rolled threads they are formed kind of like forging.
  23. Binger
    Binger
    from wyoming
    Jet96 and winduptoy like this.
  24. V4F
    V4F
    from middle ca.
    not knowing about rolled threads ………… which is better as head bolts ? ………… thanks
  25. noboD
    noboD
    Rolled threads are better for any thread. Google it. Thanks John, I will let him know.
  26. RussTee
    RussTee
    Local all ford day yesterday very hotn here
    Garagekulture13, Jet96 and barrnone50 like this.
  27. Fabber McGee
    Fabber McGee
  28. winduptoy
    winduptoy
    John,
    Good deal! See you there or that is the current plan and Rick is going to be there too.
    I'm taking the T and hoping the weather is not like last week.
    Travel Safe
    Binger likes this.
  29. Gotta get on freshening up the race car...The season will come up before I know it! BE2018.jpg
  30. V4F
    V4F
    from middle ca.
    WOW … really good video . I appreciate the awesome help . rolled threads for ever now ……… thanks much
