Technical ***November 2016 Banger Meet - Shorter Days Up North***
Discussion in 'Traditional Hot Rods' started by Jiminy, Oct 31, 2016.
  1. RussTee
    RussTee
  2. V4F
    V4F
    from middle ca.
    damn nice RPU
  3. RussTee
    RussTee
    Thanks driven it over 40 years now never finished so not bored and the game goes on
  4. V4F
    V4F
    from middle ca.
    I understand that . never done till I die
  5. Bluto
    Bluto
    Life is a continuing experiment
    HAPPY THANKSGIVING TO ALL
    The37Kid likes this.
  6. V4F
    V4F
    from middle ca.
    same to you & Z
  7. johnneilson
    johnneilson
    Not sure what the experiment is, Have a Happy Thanksgiving, one and all
  8. Bluto
    Bluto
    John
    None of us know what to call it. "Rosebud" maybe
    edfueler likes this.
  9. RussTee
    RussTee
    Winfield carbs now running just fine adjustments and tuneing thanks Just Plain Bill and all the others who gave advise
    Dannerr likes this.
  10. waxhead
    waxhead
    from West Oz
    Great news, glad to see they are working. Was your fuel pressure too high??
    Any pictures with the Winfield carbs installed??
  11. RussTee
    RussTee
    No pix yet fuel pressure was high main problem was a damaged gasket
  12. Russ Tee, I think you will find the Winfields more responsive after the manifold balance tube is warm or hot to the touch. My experience is they tend to stumble when the engine is not up to operating temp. We run it until the fan turns on then we tune or make any adjustments. It is a very pleasing sound when you bring them into balance. I use the idle speed screw on just one and balance the other to that one.
  13. RussTee
    RussTee
    Yes Bill I am noticing that thanks again it is a great feeling getting something you know nothing about to work and learn as you go my whole motor has been a learning experience many have told me things cant be done but I feel you should turn that around study what you are doing and find reasons for why it can be done understand why then stick to your guns and do it in a methodical way and dont give up these are simple engines great to learn on and not bellybutton motors probably why we build them rather than buy a done small block that probably goes better but is only a case of spending your money and thats done no understanding and can you even fix it when something goes wrong. thanks again.
  14. noboD
    noboD
    Russtee, was that all written in ONE breath?
    gas pumper likes this.
  15. RussTee
    RussTee
  16. Hey, when you're excited, you can talk alot pr breath!
    Glad to hear, it worked out good, @RussTee! PU looks good... and the lady too.
    Keep 'em kruzin!
    Dannerr
  17. If I am running a B motor with a Winfield or Simmons head, does it mater if the Water pump is a 29-29 or a 30-31? Not sure what the difference is.
  18. RussTee
    RussTee
    Either is fine very little difference
  19. V4F
    V4F
    from middle ca.
    doesn't the B have a fuel pump mount . be sure of head gasket .
    *** I have no idea why I said that !
  20. colinsmithson
    colinsmithson
    Almost all after market heads use the 4 stud A model water pump does not matter which block they are fitted to
  21. denis4x4
    denis4x4
    from Colorado
    You can get an adapter to use a B pump on an A head
  22. Thanks, I was just curious why they designate the two different A pumps if there isn't really a difference.
  23. denis4x4
    denis4x4
    from Colorado
    I stand corrected, the adapters are for 32-37 V8 water pumps.
  24. Jiminy
    Jiminy
  25. 5280A2
    5280A2
    The pumps are physically the same except for the packing nut. Brass was used for the packing nut in 1928-29 and zinc was used for 1930 and 1931. Probably only important to the restorer looking for authenticity.
    Dannerr likes this.
