Not another SBC question!?
Discussion in 'The Hokey Ass Message Board' started by rgrhoward, Feb 4, 2013.
  1. rgrhoward
    rgrhoward
    from Tacoma, WA
    Having a little trouble with my 68' 327 SBC. Brand new rebuild and my first. Around 1,500 miles and i just re adjusted the valves while running. for some reason she doesn't want to start again after she is warm. I mean she starts but it is a challenge. Well that was until today, now she starts hard all the time. Here is what i have gathered so far with the timing light and the vacuum gauge.
    800 RPM at idle
    18.5 HG Vacuum (tiny drift- less that 1/4 HG)
    10 Degrees Advanced Timing
    Mild cam.
    What am i missing?
    Oh and a mini high torque starter or gear reduction.
  2. big duece
    big duece
    from kansas
    How were the valves adjusted while running? Maybe too tight? Did you do the zero lash and 1/2 turn?
  3. rgrhoward
    rgrhoward
    from Tacoma, WA
    Backed them off until they just chattered, tightened just until it quit and then went 1/2 turn.
  4. 327Eric
    327Eric
    from Diablo Ca.
    did you just do a swap, add headers? it sounds like solenoid heat soak. Do you have a good ground, and good clean connections for your starter. The additional heat of the tight engine could be causing this. I have run into it many times.
  5. big duece
    big duece
    from kansas
    Does is spin over slow, like under a load or spin quickly?
  6. rgrhoward
    rgrhoward
    from Tacoma, WA
    No swap everything is new. I am running tight fit headers, that ole' IHC frame is narrow! I was redundant on grounds when i wired but i will check them. I did have to put some heat wrap around my starter wires because i noticed they were getting worn from heat. If it is heat soak, what is my fix?
  7. rgrhoward
    rgrhoward
    from Tacoma, WA
    Spins quick.
  8. A new heavy gauge wire from your ignition switch to your starter solonoid will probably fix your hot start problem.
  9. Cancel that. Spins quick..... back off the valves and start fresh.
  10. rgrhoward
    rgrhoward
    from Tacoma, WA
    Do you normally adjust your valves running? or cold? I hear pros and cons about both, last time i did them running but i will not say it was a great experience.
  11. unkledaddy
    unkledaddy
    You seem to have developed the problem since adjusting the valves running. Why not try adjusting them not running/cold and see if that makes a difference?
  12. belair
    belair
    Re-do the valve adjustment-tighten the valve untilthe rocker arm quits clacking, then 1/2 turn. You said you tightened them until the engine quit and then went another 1/2 turn. I bet you have some too tight.
  13. are the valve springs new?
  14. FANTASY FACTORY
    FANTASY FACTORY
    LEMMINGS... You said valves, so every body says valves.
    Coincidences do happen, check the choke.
  15. Standard gas&oil
    Standard gas&oil
    from USA #1
    Make sure your carb floats are correct. Sounds like its flooding if it cranks/spins fast and is hard to start. Does it blow out black smoke when it fires up?
  16. Running a Q-jet carb? If so, they are famous for having leaky well plugs in the bottom of the carbs float bowls....will drip gas into the intake after shutting engine off, flooding it.
  17. Yep. ^^^ If hard start came after valve adjustment then valve lash is your most likely culprit.
  18. belair
    belair
    That's what all us lemmings think^^^
  19. Or you knocked something loose while farting around with the valve covers.
    Or coincidence on ignition related problems
    Remember, whenever a new problem arises, always go back to the last things you fixed. Retrace you steps
  20. I'm just glad to hear that you've got a vacuum gauge! :D
    If you don't find a fuel or electrical problem, see what kind of cranking vacuum it will pull. Ignition off, throttle plates completely closed (back off idle speed screw) and close off any vacuum lines to the intake. Should pull maybe something like 5 to 7 inches when cranking.
  21. unkledaddy
    unkledaddy
    I think the OP meant rocker arm quit clacking............not the engine.
  22. Where's it say " until the engine quit " ? I added the red
  23. belair
    belair
    You're a good proofer. I misread it because I thought "it" meant the engine and not "the chattering". My error, but I still wonder what "it" is.
  24. mashed
    mashed
    from 4077th
    Just for the halibut retard the timing a little and see what happens.
  25. rgrhoward
    rgrhoward
    from Tacoma, WA
    Ok, readjusted valves, checked starter for excess heat, re-tuned the Edelbrock 600, retarded the timing to 8 degrees. Going to let it cool down and give her a shot.
  26. rgrhoward
    rgrhoward
    from Tacoma, WA
    Floats in the Edelbrock 600 were a little off, adjusted them. Re adjusted the air/fuel, timing back to 10 Degrees advanced. Truck pulls a solid steady 19HG at 850 RPM idle. Runs great.
    Thank you for all the info fellas.
