Not another falcon "GASSER"
Discussion in 'The Hokey Ass Message Board' started by BrickTopp, Jan 4, 2010.
  1. holeshot
    holeshot
    from Waxahachie
    BRICK...i'am on it, intell finished! man you do 1st. class work. and i like the dist. and carb treatment. your going to surprise some folks with that little s.b. ford. the don't have much torque, so your going to need a tall gear, in my view. i had a 513 in my mustang, and it took every bit to beatup on those badass chevy's...POP.
  2. BrickTopp
    BrickTopp
    Heres the transmission mount. We used flat stock and a carquest rubber mount. We also used the stock crossmember under the floor where the original fordomatic crossmember bolted too. We did punch a hole through it for the shifter but still plent strong. The carquest mount was under 10 dollars and was nice and shallow and worked out great.
  3. newfalconowner
    newfalconowner
    from NS Canada
    any more updates??
    rick
  4. SholleysTrimShop
    SholleysTrimShop
    Nice build, Were currently finishing up the sheet metal work on a 61 Ranchero gasser build, cant wait to see your end result.
  5. BrickTopp
    BrickTopp
    ill post some more updates by the end of the weekend
  6. jcm65
    jcm65
    from Santa Rosa
    how far did you set the engine back?
  7. BrickTopp
    BrickTopp
    Were starting to wrap up most of the heavy fab work on the front of the car. major hurdles would probably be steering, headers, and grill. youll see that soon. We finished the radiator mounting pionts and Dan's just about done with the hold down for it and bodyworking the fenders. We welded in the front crossmember and part of the down tubes. The bottom supports for the radiator are juts 16 ga. bent to form caps around the bottom of the tanks. We spot welded them to the top of the frame rail and will set cut out rubber pieces in the cup . Then the upper hold down is aluminum w/ lightning holes that goes over the top of the radiator and will be mounted to the top of the core support when done.
    For setting the engine back, i dont have the measurement but ill get ya one. We set it back as far as we could to have room for the water pump and radiator and it got tight fast. theres a good overview pic that shows it best
    progress is going slower then we want but steady. Headers and steering next.
  8. Lasse Smed
    Lasse Smed
    Hi I like what you doing and I like the early Falcons Have a look at mine
    www.SVDA.se and look at Gassers and Lasse
  9. Lasse Smed
    Lasse Smed
    Sorry Look at svda Medlemmar and then Gasser
  10. dirttoo
    dirttoo
    WOW, That thing is COOL.
  11. BrickTopp
    BrickTopp
    That is one bad Swedish ranchero. looks like its ready to eat anything
  12. BrickTopp
    BrickTopp
    While waiting on some parts we got the seats mounted and main hoop set. down bars and cross bar are tomorrow. seats are out of a mustang and heres my quick sketch for the falcon guys if they like the hoop. start at the CL and work out each line is the beginning of the bend. O and a few speed parts.
  13. Falcon Gasser
    Falcon Gasser
    Looking good, you are making some great progress on it.
    Jon
  14. Looking good! I wish ours was farther along. It's just to dang cold out in my garage.
  15. dirttoo
    dirttoo
    Looking good. I'm still plugging away on mine. I'm hoping to make the Vintage Touque Fest on May 1st. Reading these posts help get me going.
  16. BrickTopp
    BrickTopp
    some more pics of the roll bar. i should be at the torque fest but dont know bout the car
  17. newfalconowner
    newfalconowner
    from NS Canada
    cool,,, make another bar ;)
  18. BrickTopp
    BrickTopp
    only so much time in a day ....or after the day that is
  19. newfalconowner
    newfalconowner
    from NS Canada
    i meant for me,lol... soon as it warms up around these parts i will be back at it.. your is looking good.
  20. claymore
    claymore
    Good progress. But you may be having a setback....... the carb mounting plate on your intake is all twisted and stuff :rolleyes:
  21. motorhead711
    motorhead711
    YESSS!! Why not another falcon gasser?? Way cool build up man, can't wait to see the finished ride!!! take it easy
  22. BrickTopp
    BrickTopp
    roll bar is welded for the most part and the seat spacer made to sit level.
  23. KustomF100
    KustomF100
    from Joliet, IL
    Nice build, and great quality of your work! I can't wait to see it finished!
  24. SLAMIT
    SLAMIT
    Wow nice work.
    I have a 454 chevy with fenderwell headers sitting far too close to my 62 ranchero in my garage and it is starting to talk to me. this can't be a good thing. hahaha
  25. Chuckles Garage
    Chuckles Garage
    Alliance Vendor
  26. BrickTopp
    BrickTopp
    Started on the headers. i slightly cheated and started with headers i got at a pick n pull off a 302 and chopped em up and started with the flanges and tubes allready to go
  27. newfalconowner
    newfalconowner
    from NS Canada
    cool, im about to do my headers,, this helps out some, :)
  28. The Gonz
    The Gonz
    right on its looking pretty wicked so far, I to have a falcon gasser, in hawaii
  29. Boones
    Boones
    from Kent, Wa
    bricktop, thanks for sharing, what did you use for radiator. and what diameter &thickness are your engine compartment support bars (frame to firewall).
    slamit, i have one also, but thinking I am going with a sbc since i have it ready to go.. but would not mind finding a cheap 5.0 motor/ trans around here instead
  30. BrickTopp
    BrickTopp
    gonz i can only imagine what its like to drive your car on the island, lucky me winter is a time to get stuff done cause i would be driving more than finishing my projects otherwise.
    sweet ride by the way
    boones the radiator is i wanna say an allstar roundy round radiator, the smallest and best bang for the buck, and the front bars would be 1 5/8" .120" wall
