Projects Not Another 41 Pickup Project!!
Discussion in 'The Hokey Ass Message Board' started by hotrodA, Aug 7, 2020.
  1. 6sally6
    6sally6
    Liking the old truck!!!
    That too narrow rear end should be just right for some "man-sized" rear wheels and tarz. Gonna need them for that Hemi ('specially if you go to the dual quads!);)
    6sally6
  2. Thanks!
    Looking for something in 15", 5x5 1/2 bc, with 3" back space. 4" on there now.
    Don't particularly want to run spacers.
    brEad and loudbang like this.
  3. Update from BSE.
    Jim got the steering box mount finished and welded in for good, and while the engine was out, switched out the trans adapter for RH starter.
    Another good day!
  4. A little profile shot in the cool autumn sun.
    Deuces, scott27, Hamtown Al and 11 others like this.
  5. Here's an update. That Jim is a working mosheen, I tell you.
    Got the brake pedal, booster and m/cyl mounted.
    Fabbed up the trans linkage and hooked up the 40 column shift.
    Fabbed up the top and bottom column mounts, and sectioned the shift tube.
    Next: radiator brackets and driveshaft. Stay tooned!
    Deuces, 40FORDPU, Hamtown Al and 7 others like this.
  6. joel
    joel
    It looks like you're going to have a very nice pickup. I think your truck was originally a 6 cyl. What happened to the "POS" frame?
  7. Thanks!
    Yes, it was a 6 cyl. Has a 1GC prefix serial number.
    A guy in Dandridge is buying it, hopefully. I will see him Friday in Knoxville. Interested in it if something falls through?
    Bill
  8. 31Apickup
    31Apickup
    hotrodA and loudbang like this.
  9. Not too much going on this week at BSE. They got the cab, doors and fenders to the media blaster they use and the pieces came back in PPG epoxy prime. Ready for the floor and cab corner repair. Doors were near perfect, must be from another truck.
    Deuces, brEad, Just Gary and 4 others like this.
  10. nobby
    nobby
    nice,
    begs the question.… why no-one repops a 35-40 front crossmember and
    sells a perimeter frame with one fitted
    in as much as fitting the rear leaf spring mounts - so the rear shackle goes through the rail at the back...
    supplies them with the springs - u-bolts and saddles, shock mounts and shocks
    mounts for f1 style shock mounts at the front
    the wish bone mount area has both a socket for a unsplit bone and also has provisions fitted for a split wishbone. - cut off whichever you don't need
    has mounts for a saginaw 525 or a 800 power box
    universal small block motor mounts
    supplied with all the fastners
    drilled and tapped for brake and fuel lines
    mount for brake switch
    mounbt for combination valve
    mounts for 2 and 10
    -get it , paint it
    fling the rear in
    fling the front axle in
    instant roller
    they could sell at least 1
    joel likes this.
  11. manyolcars
    manyolcars
    What is a perimeter frame and how is it different from the original frame?
  12. 40Standard
    40Standard
    from Indy
    thanks for the build pics, gonna be a good looking truck
  13. Thank you, guys!
  14. I love the build and that 330 Desoto sits in there so very nicely! I will keep watching and learning!
    loudbang and Grandadeo like this.
  15. Thanks, Tom!
    You're the inspirational and instructive one. I look to you for guidance.
    Get to work.
    Bill
    loudbang, TomT and Grandadeo like this.
  16. Thank you. Bill - I appreciate your kind words, I am humbled by them, and thankful I have inspired you to keep your project moving forward.
    And you are right - I need to get back to work!
  17. With the body back from the media blaster guy, Jim got started on some rot repair.
    One side done on the front floor.
    Rear cab corners
    Door hinge pockets. ALL the Hinges were welded on by a PO.
    A pillar body mount
    Exhaust tubing ordered. Then Mike can do his specialty!
  18. v8flat44
    v8flat44
    41 Ford with a Dodge Red Ram
    Dual quads & a full race cam
    If ya wanna race, i wish ya luck
    Noth'n outruns my 41 truck !
  19. loudbang likes this.
  20. v8flat44
    v8flat44
    hotrodA, you've got the pics; the poem is about yours...wish i had one just like it though.
    It's gonna be awesome. Helped a guy years back put a J2 Olds in one......scary fast it was.
    olscrounger and loudbang like this.
  21. ^^^ That's good! Thanks!
  22. Bandit Billy
    Bandit Billy
    You are really getting after it! Keep up the work and the updates
  23. Thanks, BB.
    It's all the Barillaro brothers!
    What they have accomplished in two months would have taken me two years. The sale of my 33 coupe made it happen.
    It will slow down once I get it home for plumbing, brakes and wiring.
    Then to find a body man/painter with the same work ethic and skill as Jim and Mike.
  24. Sone more sheet metal work done by the dynamic duo, Jim and Mike.
    Front floor completed
    Back of cab
    Mike has started on the exhaust.
    Taking the gas tank over today to figure out routing.
    Stay tooned!
  25. 40FORDPU
    40FORDPU
    from Yelm, Wa
    1. Northwest HAMBers
    Thanks for sharing your build..like the progress.
  26. Dropped the tank off, and was surprised to see Mike already started on the exhaust.
    On the lift. This puppy is LOW!
    Couple of progress pics of the routing.
    20201021_133929.jpg The man at work. Good enough for Bobby Alloway, good enough for me.
    Teaser pic of a couple cars belonging to their late father. Yeah, they're Cammers!. So is that engine on the stand!
    Next time should have a finished exhaust and radiator hung.
    Stay tooned!
  27. Well, when you're a pro, it doesn't take long.
    Not me......Mike Barillaro.
    Exhaust is done! Well done, Mike!
    VROOOM VROOOM!
  28. Looks like your truck is in great hands. Keep them pics coming.
  29. Bandit Billy
    Bandit Billy
    Vband clamps, I love Vband clamps. I pulled my exhaust off the truck the other day to sand and polish the pipes and those things make it sooo easy to remove and install without leaks. Looking great!
    loudbang and hotrodA like this.
  30. Atwater Mike
    Atwater Mike
    Great fitment of DeSoto, 350 TH; especially liked the word on availability of right hand starter adapter!
    Also like the Saginaw steering choice and placement, and the use of the '41 mast jacket/'41 shifter.
    Lowness of front and 1" forward front axle was the icing. Hope you locate the right offset on rear wheels.
    I also hate spacers...
