Wondering were my Vibration is coming from between 700-950 RPM .. I can feel it thru the floor only at that range ...is it driveshaft, muffler ???
Have you changed anything recently? Is your dampner coming apart? NOPE did it just start to happen or has the motor been in the car for awhile JUST STARTED AFTER CAR HAS BEEN SITTING FOR 4 YRS ..MOTOR BEEN IN CAR 10 PLUS YRS
Check the usual suspects, motor and trans mounts, harmonic damper. If it appears to be nothing, it might be. Sometimes you just get a vibration for some unknown reason, a certain harmonic gets to the car. My 98 Mustang does it
check exhaust tubes probly rubbing somewhere- a mount, collector @ the headpipe or somthing could have come loose, this is the most likely
Strange vibration when parked, is it the driveshaft? Look at the dead bird, no not up in the sky, on the GROUND.
If the car sat for 4 years and it only does it at 700-950 RPM, maybe it's just running rough and needs a carb rebuild.
*Ding, ding, ding*....winner, winner, chicken dinner..... The poor old car has been sitting and needs some tune-up "lovin".....
Nope .. Drained the gas and changed fuel filter ... when I chnaged the carb FYI ..Just got back from 425 mile road trip ran great on the hwy ...close to 20 mpg for a BBC
Groovy. Did it do it with the old carb too? What kind was on it previously and whats on it now? Is it rebuilt or new?
It might be easier if you told everybody what you did to your vehicle before you went on your 425 mile trip. Did the vibration start after your trip or did start after sitting for 4 years.
.Did it do it with the old carb too? ..NO What kind was on it previously and whats on it now?.. Edelbrock 600 prev and new Is it rebuilt or new? NEW
Did you forget some zeros? You might have a problem if it was 7000-9500 rpm. Put in a bigger cam so it will have more vibration, its a Hot Rod not a Rolls Royce!! Then again you could change out that cracked flexplate ( only a guess ) good luck.
