Nostalgic Front engine dragster project
Discussion in 'Cars For Sale' started by jt306, Jan 10, 2015.
  1. jt306
    jt306
    City: Braselton
    State: Georgia
    Price: $3900.00
    Check out my photobucket slide show (if you can't click, copy link and paste to web address above):
    http://s621.photobucket.com/user/jtmkustoms/slideshow/nostalgia dragster?sort=3 DSC03125-1.jpg DSC03122-1.jpg
    First off Im not an expert on vintage dragsters, but I found this car about a year ago in storage where it had been since the 90s. I thought it would be cool to restore, but I haven't had time to get to it so here it is. It is 145 inch wheelbase, mid 60s build, chrome moly frame. It looks to be a professional build but I don't know by who. At one point it had been converted to an rear engine set up, I cut the rear section off and moved the axel back to the original mounts. It has an 8 3/4 rear end, two set of axels, an complete third member that built with full spool and I think a 5:13 gear. I also have a spare spool. Shorty PG trans with trans brake and coupler. There is also a set of Air heart Aluminum disk brakes with the brackets for the rear end. I also have the gauge panel, seat cover, shifter, and a few other odds and ends for it. NO motor. The dragster is going to need a lot of work but its not ready for the junk pile yet. It will need the lower frame tube repaired as you can see in the pic. I would love someone to put it back on the drag strip where it needs to be. J.T. 678 758-1557
  2. jt306
    jt306
  3. jt306
    jt306
  4. jt306
    jt306
    Kitty tittys
  5. jt306
    jt306
