Nostalgia FED driver passes out from heat stroke.
Discussion in 'The Hokey Ass Message Board' started by Newbomb Turk, Aug 5, 2013.
  1. Littleman
    Littleman
    Alliance Member
    from OHIO, USA
    Accidents are alway's going to happen........whether a car is properly built and inspected or improperly built and allowed to run..........The lucky ones get to move on.....Littleman
  2. I agree, regardless of what the promoter thinks. :rolleyes:
  3. That's terrible. I hope it never happens again. Be safe out there guys.
    Dustin
  4. Don't steer worth a damn period! Forward or backward... They were built to go STRAIGHT, really fast!
  5. jimdillon
    jimdillon
    I was there and watched the whole deal unfold (I am in the video in the early frames). First of all it was extremely hot and I felt for the guys in the firesuits. I thought it then when they rolled past me to the line. I had run a street car earlier and had to wait at the line for a track cleanup. It was really hot- the firesuits had to be near unbearable. Heat stroke is not unbelievable by any stretch.
    You guys that want to criticize the safety crew, let’s hear specifically what you would have done personally if you were in their shoes. Remember safety crews do not risk their life and limb as a goal when they suit up. They have to use good judgment and do whatever within their own safety to help those in need. They have kids and a family at home. Death or serious injury is not a prerequisite of their job. Did they have a plan for what happened here I do not know and maybe this will be part of a learning curve of something as a first impression-who knows. With a digger running wide open throttle and dangerously spinning tires spewing a mixture of ground up asphalt , concrete and rubber in several directions who is going to want to stand next to the car. The wheels became so deformed from heat, they no longer were round and the right tire deflated but kept spinning. Is it out of the realm that the tires or wheels could come apart? It is also possible that the engine could have let loose with potential tragic results as well. I certainly would think twice about approaching the car. Could it have become dislodged from the wall and then careen into anyone around it?
    The digger runs a relatively small amount of fuel, was the plan to let it run out of fuel? It may very well have run out of fuel-the way it sputtered and restarted just before the engine died for good? It was a scary deal to watch. Every emergency has a particular plan and methods to deal with lessening injury and worse (needless tragedy). Just because there is one tragedy does not mean more are necessary so as to avoid criticism by Monday morning quarterbacks. Maybe their plan with limited fuel supply and no clear and safe way to shut it off is to let it run out of fuel. Maybe they need bigger extinguishers with a longer reach or whatever and that may be the learning curve-maybe a large fire blanket to smother the car-who knows but I am sure they have discussed the situation since.
    It is easy to criticize but when the situation is upon your shoulders, and you could have been standing there and were told to go handle it, what specifically would you have done?-Jim
    <!--[if gte mso 9]><xml> <w:WordDocument> <w:View>Normal</w:View> <w:Zoom>0</w:Zoom> <w:TrackMoves/> <w:TrackFormatting/> <w:punctuationKerning/> <w:ValidateAgainstSchemas/> <w:SaveIfXMLInvalid>false</w:SaveIfXMLInvalid> <w:IgnoreMixedContent>false</w:IgnoreMixedContent> <w:AlwaysShowPlaceholderText>false</w:AlwaysShowPlaceholderText> <w:DoNotPromoteQF/> <w:LidThemeOther>EN-US</w:LidThemeOther> <w:LidThemeAsian>X-NONE</w:LidThemeAsian> <w:LidThemeComplexScript>X-NONE</w:LidThemeComplexScript> <w:Compatibility> <w:BreakWrappedTables/> <w:SnapToGridInCell/> <w:WrapTextWithPunct/> <w:UseAsianBreakRules/> <w:DontGrowAutofit/> <w:SplitPgBreakAndParaMark/> <w:EnableOpenTypeKerning/> <w:DontFlipMirrorIndents/> <w:OverrideTableStyleHps/> </w:Compatibility> <m:mathPr> <m:mathFont m:val="Cambria Math"/> <m:brkBin m:val="before"/> <m:brkBinSub m:val="&#45;-"/> <m:smallFrac m:val="off"/> <m:dispDef/> <m:lMargin m:val="0"/> <m:rMargin m:val="0"/> <m:defJc m:val="centerGroup"/> <m:wrapIndent m:val="1440"/> <m:intLim m:val="subSup"/> <m:naryLim m:val="undOvr"/> </m:mathPr></w:WordDocument> </xml><![endif]--><!--[if gte mso 9]><xml> <w:LatentStyles DefLockedState="false" DefUnhideWhenUsed="true" DefSemiHidden="true" DefQFormat="false" DefPriority="99" LatentStyleCount="267"> <w:LsdException Locked="false" Priority="0" SemiHidden="false" UnhideWhenUsed="false" QFormat="true" Name="Normal"/> <w:LsdException Locked="false" Priority="9" SemiHidden="false" UnhideWhenUsed="false" QFormat="true" Name="heading 1"/> <w:LsdException Locked="false" Priority="9" QFormat="true" Name="heading 2"/> <w:LsdException Locked="false" Priority="9" QFormat="true" Name="heading 3"/> <w:LsdException Locked="false" Priority="9" QFormat="true" Name="heading 4"/> <w:LsdException Locked="false" Priority="9" QFormat="true" Name="heading 5"/> <w:LsdException Locked="false" Priority="9" QFormat="true" Name="heading 6"/> <w:LsdException Locked="false" Priority="9" QFormat="true" Name="heading 7"/> <w:LsdException Locked="false" Priority="9" QFormat="true" Name="heading 8"/> <w:LsdException Locked="false" Priority="9" QFormat="true" Name="heading 9"/> <w:LsdException Locked="false" Priority="39" Name="toc 1"/> <w:LsdException Locked="false" Priority="39" Name="toc 2"/> <w:LsdException Locked="false" Priority="39" Name="toc 3"/> <w:LsdException Locked="false" Priority="39" Name="toc 4"/> <w:LsdException Locked="false" Priority="39" Name="toc 5"/> <w:LsdException Locked="false" Priority="39" Name="toc 6"/> <w:LsdException Locked="false" Priority="39" Name="toc 7"/> <w:LsdException Locked="false" Priority="39" Name="toc 8"/> <w:LsdException Locked="false" Priority="39" Name="toc 9"/> <w:LsdException Locked="false" Priority="35" QFormat="true" Name="caption"/> <w:LsdException Locked="false" Priority="10" SemiHidden="false" UnhideWhenUsed="false" QFormat="true" Name="Title"/> <w:LsdException Locked="false" Priority="1" Name="Default Paragraph Font"/> <w:LsdException Locked="false" Priority="11" SemiHidden="false" UnhideWhenUsed="false" QFormat="true" Name="Subtitle"/> <w:LsdException Locked="false" Priority="22" SemiHidden="false" UnhideWhenUsed="false" QFormat="true" Name="Strong"/> <w:LsdException Locked="false" Priority="20" SemiHidden="false" UnhideWhenUsed="false" QFormat="true" Name="Emphasis"/> <w:LsdException Locked="false" Priority="59" SemiHidden="false" UnhideWhenUsed="false" Name="Table Grid"/> <w:LsdException Locked="false" UnhideWhenUsed="false" Name="Placeholder Text"/> <w:LsdException Locked="false" Priority="1" SemiHidden="false" UnhideWhenUsed="false" QFormat="true" Name="No Spacing"/> <w:LsdException Locked="false" Priority="60" SemiHidden="false" UnhideWhenUsed="false" Name="Light Shading"/> <w:LsdException Locked="false" Priority="61" SemiHidden="false" UnhideWhenUsed="false" Name="Light List"/> <w:LsdException Locked="false" Priority="62" SemiHidden="false" UnhideWhenUsed="false" Name="Light Grid"/> <w:LsdException Locked="false" Priority="63" SemiHidden="false" UnhideWhenUsed="false" Name="Medium Shading 1"/> <w:LsdException Locked="false" Priority="64" SemiHidden="false" UnhideWhenUsed="false" Name="Medium Shading 2"/> <w:LsdException Locked="false" Priority="65" SemiHidden="false" UnhideWhenUsed="false" Name="Medium List 1"/> <w:LsdException Locked="false" Priority="66" SemiHidden="false" UnhideWhenUsed="false" Name="Medium List 2"/> <w:LsdException Locked="false" Priority="67" SemiHidden="false" UnhideWhenUsed="false" Name="Medium Grid 1"/> <w:LsdException Locked="false" Priority="68" SemiHidden="false" UnhideWhenUsed="false" Name="Medium Grid 2"/> <w:LsdException Locked="false" Priority="69" SemiHidden="false" UnhideWhenUsed="false" Name="Medium Grid 3"/> <w:LsdException Locked="false" Priority="70" SemiHidden="false" UnhideWhenUsed="false" Name="Dark List"/> <w:LsdException Locked="false" Priority="71" SemiHidden="false" UnhideWhenUsed="false" Name="Colorful Shading"/> <w:LsdException Locked="false" Priority="72" SemiHidden="false" UnhideWhenUsed="false" Name="Colorful List"/> <w:LsdException Locked="false" Priority="73" SemiHidden="false" UnhideWhenUsed="false" Name="Colorful Grid"/> <w:LsdException Locked="false" Priority="60" SemiHidden="false" UnhideWhenUsed="false" Name="Light Shading Accent 1"/> <w:LsdException Locked="false" Priority="61" SemiHidden="false" UnhideWhenUsed="false" Name="Light List Accent 1"/> <w:LsdException Locked="false" Priority="62" SemiHidden="false" UnhideWhenUsed="false" Name="Light Grid Accent 1"/> <w:LsdException Locked="false" Priority="63" SemiHidden="false" UnhideWhenUsed="false" Name="Medium Shading 1 Accent 1"/> <w:LsdException Locked="false" Priority="64" SemiHidden="false" UnhideWhenUsed="false" Name="Medium Shading 2 Accent 1"/> <w:LsdException Locked="false" Priority="65" SemiHidden="false" UnhideWhenUsed="false" Name="Medium List 1 Accent 1"/> <w:LsdException Locked="false" UnhideWhenUsed="false" Name="Revision"/> <w:LsdException Locked="false" Priority="34" SemiHidden="false" UnhideWhenUsed="false" QFormat="true" Name="List Paragraph"/> <w:LsdException Locked="false" Priority="29" SemiHidden="false" UnhideWhenUsed="false" QFormat="true" Name="Quote"/> <w:LsdException Locked="false" Priority="30" SemiHidden="false" UnhideWhenUsed="false" QFormat="true" Name="Intense Quote"/> <w:LsdException Locked="false" Priority="66" SemiHidden="false" UnhideWhenUsed="false" Name="Medium List 2 Accent 1"/> <w:LsdException Locked="false" Priority="67" SemiHidden="false" UnhideWhenUsed="false" Name="Medium Grid 1 Accent 1"/> <w:LsdException Locked="false" Priority="68" SemiHidden="false" UnhideWhenUsed="false" Name="Medium Grid 2 Accent 1"/> <w:LsdException Locked="false" Priority="69" SemiHidden="false" UnhideWhenUsed="false" Name="Medium Grid 3 Accent 1"/> <w:LsdException Locked="false" Priority="70" SemiHidden="false" UnhideWhenUsed="false" Name="Dark List Accent 1"/> <w:LsdException Locked="false" Priority="71" SemiHidden="false" UnhideWhenUsed="false" Name="Colorful Shading Accent 1"/> <w:LsdException Locked="false" Priority="72" SemiHidden="false" UnhideWhenUsed="false" Name="Colorful List Accent 1"/> <w:LsdException Locked="false" Priority="73" SemiHidden="false" UnhideWhenUsed="false" Name="Colorful Grid Accent 1"/> <w:LsdException Locked="false" Priority="60" SemiHidden="false" UnhideWhenUsed="false" Name="Light Shading Accent 2"/> <w:LsdException Locked="false" Priority="61" SemiHidden="false" UnhideWhenUsed="false" Name="Light List Accent 2"/> <w:LsdException Locked="false" Priority="62" SemiHidden="false" UnhideWhenUsed="false" Name="Light Grid Accent 2"/> <w:LsdException Locked="false" Priority="63" SemiHidden="false" UnhideWhenUsed="false" Name="Medium Shading 1 Accent 2"/> <w:LsdException Locked="false" Priority="64" SemiHidden="false" UnhideWhenUsed="false" Name="Medium Shading 2 Accent 2"/> <w:LsdException Locked="false" Priority="65" SemiHidden="false" UnhideWhenUsed="false" Name="Medium List 1 Accent 2"/> <w:LsdException Locked="false" Priority="66" SemiHidden="false" UnhideWhenUsed="false" Name="Medium List 2 Accent 2"/> <w:LsdException Locked="false" Priority="67" SemiHidden="false" UnhideWhenUsed="false" Name="Medium Grid 1 Accent 2"/> <w:LsdException Locked="false" Priority="68" SemiHidden="false" UnhideWhenUsed="false" Name="Medium Grid 2 Accent 2"/> <w:LsdException Locked="false" Priority="69" SemiHidden="false" UnhideWhenUsed="false" Name="Medium Grid 3 Accent 2"/> <w:LsdException Locked="false" Priority="70" SemiHidden="false" UnhideWhenUsed="false" Name="Dark List Accent 2"/> <w:LsdException Locked="false" Priority="71" SemiHidden="false" UnhideWhenUsed="false" Name="Colorful Shading Accent 2"/> <w:LsdException Locked="false" Priority="72" SemiHidden="false" UnhideWhenUsed="false" Name="Colorful List Accent 2"/> <w:LsdException Locked="false" Priority="73" SemiHidden="false" UnhideWhenUsed="false" Name="Colorful Grid Accent 2"/> <w:LsdException Locked="false" Priority="60" SemiHidden="false" UnhideWhenUsed="false" Name="Light Shading Accent 3"/> <w:LsdException Locked="false" Priority="61" SemiHidden="false" UnhideWhenUsed="false" Name="Light List Accent 3"/> <w:LsdException Locked="false" Priority="62" SemiHidden="false" UnhideWhenUsed="false" Name="Light Grid Accent 3"/> <w:LsdException Locked="false" Priority="63" SemiHidden="false" UnhideWhenUsed="false" Name="Medium Shading 1 Accent 3"/> <w:LsdException Locked="false" Priority="64" SemiHidden="false" UnhideWhenUsed="false" Name="Medium Shading 2 Accent 3"/> <w:LsdException Locked="false" Priority="65" SemiHidden="false" UnhideWhenUsed="false" Name="Medium List 1 Accent 3"/> <w:LsdException Locked="false" Priority="66" SemiHidden="false" UnhideWhenUsed="false" Name="Medium List 2 Accent 3"/> <w:LsdException Locked="false" Priority="67" SemiHidden="false" UnhideWhenUsed="false" Name="Medium Grid 1 Accent 3"/> <w:LsdException Locked="false" Priority="68" SemiHidden="false" UnhideWhenUsed="false" Name="Medium Grid 2 Accent 3"/> <w:LsdException Locked="false" Priority="69" SemiHidden="false" UnhideWhenUsed="false" Name="Medium Grid 3 Accent 3"/> <w:LsdException Locked="false" Priority="70" SemiHidden="false" UnhideWhenUsed="false" Name="Dark List Accent 3"/> <w:LsdException Locked="false" Priority="71" SemiHidden="false" UnhideWhenUsed="false" Name="Colorful Shading Accent 3"/> <w:LsdException Locked="false" Priority="72" SemiHidden="false" UnhideWhenUsed="false" Name="Colorful List Accent 3"/> <w:LsdException Locked="false" Priority="73" SemiHidden="false" UnhideWhenUsed="false" Name="Colorful Grid Accent 3"/> <w:LsdException Locked="false" Priority="60" SemiHidden="false" UnhideWhenUsed="false" Name="Light Shading Accent 4"/> <w:LsdException Locked="false" Priority="61" SemiHidden="false" UnhideWhenUsed="false" Name="Light List Accent 4"/> <w:LsdException Locked="false" Priority="62" SemiHidden="false" UnhideWhenUsed="false" Name="Light Grid Accent 4"/> <w:LsdException Locked="false" Priority="63" SemiHidden="false" UnhideWhenUsed="false" Name="Medium Shading 1 Accent 4"/> <w:LsdException Locked="false" Priority="64" SemiHidden="false" UnhideWhenUsed="false" Name="Medium Shading 2 Accent 4"/> <w:LsdException Locked="false" Priority="65" SemiHidden="false" UnhideWhenUsed="false" Name="Medium List 1 Accent 4"/> <w:LsdException Locked="false" Priority="66" SemiHidden="false" UnhideWhenUsed="false" Name="Medium List 2 Accent 4"/> <w:LsdException Locked="false" Priority="67" SemiHidden="false" UnhideWhenUsed="false" Name="Medium Grid 1 Accent 4"/> <w:LsdException Locked="false" Priority="68" SemiHidden="false" UnhideWhenUsed="false" Name="Medium Grid 2 Accent 4"/> <w:LsdException Locked="false" Priority="69" SemiHidden="false" UnhideWhenUsed="false" Name="Medium Grid 3 Accent 4"/> <w:LsdException Locked="false" Priority="70" SemiHidden="false" UnhideWhenUsed="false" Name="Dark List Accent 4"/> <w:LsdException Locked="false" Priority="71" SemiHidden="false" UnhideWhenUsed="false" Name="Colorful Shading Accent 4"/> <w:LsdException Locked="false" Priority="72" SemiHidden="false" UnhideWhenUsed="false" Name="Colorful List Accent 4"/> <w:LsdException Locked="false" Priority="73" SemiHidden="false" UnhideWhenUsed="false" Name="Colorful Grid Accent 4"/> <w:LsdException Locked="false" Priority="60" SemiHidden="false" UnhideWhenUsed="false" Name="Light Shading Accent 5"/> <w:LsdException Locked="false" Priority="61" SemiHidden="false" UnhideWhenUsed="false" Name="Light List Accent 5"/> <w:LsdException Locked="false" Priority="62" SemiHidden="false" UnhideWhenUsed="false" Name="Light Grid Accent 5"/> <w:LsdException Locked="false" Priority="63" SemiHidden="false" UnhideWhenUsed="false" Name="Medium Shading 1 Accent 5"/> <w:LsdException Locked="false" Priority="64" SemiHidden="false" UnhideWhenUsed="false" Name="Medium Shading 2 Accent 5"/> <w:LsdException Locked="false" Priority="65" SemiHidden="false" UnhideWhenUsed="false" Name="Medium List 1 Accent 5"/> <w:LsdException Locked="false" Priority="66" SemiHidden="false" UnhideWhenUsed="false" Name="Medium List 2 Accent 5"/> <w:LsdException Locked="false" Priority="67" SemiHidden="false" UnhideWhenUsed="false" Name="Medium Grid 1 Accent 5"/> <w:LsdException Locked="false" Priority="68" SemiHidden="false" UnhideWhenUsed="false" Name="Medium Grid 2 Accent 5"/> <w:LsdException Locked="false" Priority="69" SemiHidden="false" UnhideWhenUsed="false" Name="Medium Grid 3 Accent 5"/> <w:LsdException Locked="false" Priority="70" SemiHidden="false" UnhideWhenUsed="false" Name="Dark List Accent 5"/> <w:LsdException Locked="false" Priority="71" SemiHidden="false" UnhideWhenUsed="false" Name="Colorful Shading Accent 5"/> <w:LsdException Locked="false" Priority="72" SemiHidden="false" UnhideWhenUsed="false" Name="Colorful List Accent 5"/> <w:LsdException Locked="false" Priority="73" SemiHidden="false" UnhideWhenUsed="false" Name="Colorful Grid Accent 5"/> <w:LsdException Locked="false" Priority="60" SemiHidden="false" UnhideWhenUsed="false" Name="Light Shading Accent 6"/> <w:LsdException Locked="false" Priority="61" SemiHidden="false" UnhideWhenUsed="false" Name="Light List Accent 6"/> <w:LsdException Locked="false" Priority="62" SemiHidden="false" UnhideWhenUsed="false" Name="Light Grid Accent 6"/> <w:LsdException Locked="false" Priority="63" SemiHidden="false" UnhideWhenUsed="false" Name="Medium Shading 1 Accent 6"/> <w:LsdException Locked="false" Priority="64" SemiHidden="false" UnhideWhenUsed="false" Name="Medium Shading 2 Accent 6"/> <w:LsdException Locked="false" Priority="65" SemiHidden="false" UnhideWhenUsed="false" Name="Medium List 1 Accent 6"/> <w:LsdException Locked="false" Priority="66" SemiHidden="false" UnhideWhenUsed="false" Name="Medium List 2 Accent 6"/> <w:LsdException Locked="false" Priority="67" SemiHidden="false" UnhideWhenUsed="false" Name="Medium Grid 1 Accent 6"/> <w:LsdException Locked="false" Priority="68" SemiHidden="false" UnhideWhenUsed="false" Name="Medium Grid 2 Accent 6"/> <w:LsdException Locked="false" Priority="69" SemiHidden="false" UnhideWhenUsed="false" Name="Medium Grid 3 Accent 6"/> <w:LsdException Locked="false" Priority="70" SemiHidden="false" UnhideWhenUsed="false" Name="Dark List Accent 6"/> <w:LsdException Locked="false" Priority="71" SemiHidden="false" UnhideWhenUsed="false" Name="Colorful Shading Accent 6"/> <w:LsdException Locked="false" Priority="72" SemiHidden="false" UnhideWhenUsed="false" Name="Colorful List Accent 6"/> <w:LsdException Locked="false" Priority="73" SemiHidden="false" UnhideWhenUsed="false" Name="Colorful Grid Accent 6"/> <w:LsdException Locked="false" Priority="19" SemiHidden="false" UnhideWhenUsed="false" QFormat="true" Name="Subtle Emphasis"/> <w:LsdException Locked="false" Priority="21" SemiHidden="false" UnhideWhenUsed="false" QFormat="true" Name="Intense Emphasis"/> <w:LsdException Locked="false" Priority="31" SemiHidden="false" UnhideWhenUsed="false" QFormat="true" Name="Subtle Reference"/> <w:LsdException Locked="false" Priority="32" SemiHidden="false" UnhideWhenUsed="false" QFormat="true" Name="Intense Reference"/> <w:LsdException Locked="false" Priority="33" SemiHidden="false" UnhideWhenUsed="false" QFormat="true" Name="Book Title"/> <w:LsdException Locked="false" Priority="37" Name="Bibliography"/> <w:LsdException Locked="false" Priority="39" QFormat="true" Name="TOC Heading"/> </w:LatentStyles> </xml><![endif]--><!--[if gte mso 10]> <style> /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-priority:99; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin-top:0in; mso-para-margin-right:0in; mso-para-margin-bottom:10.0pt; mso-para-margin-left:0in; line-height:115%; mso-pagination:widow-orphan; font-size:12.0pt; font-family:"Calibri","sans-serif"; mso-ascii-font-family:Calibri; mso-ascii-theme-font:minor-latin; mso-hansi-font-family:Calibri; mso-hansi-theme-font:minor-latin;} </style> <![endif]-->
  6. CNC-Dude
    CNC-Dude
    I agree with jimdillon, in that case where the throttle was hung wide open as in this case, the best safety for others is to stand clear. If the car had come unwedged from the wall it would have started doing doughnuts and wiped out anyone standing within 20 feet or more of it.
  7. fridaynitedrags
    fridaynitedrags
    The reason you don't want me there teching is because I know the rules and you wouldn't have much of a show with all the slackers back in their trailers and headed home.
  8. hugh m
    hugh m
    from ct.
    Another bureaucratic wannbe is speaking? They are all slackers? Huh? Please.
  9. Moon Rocket
    Moon Rocket
    from GA
    Which of the rules prevents heat stroke? :rolleyes:
  10. dreracecar
    dreracecar
    from so-cal
    Its the rule of common sense
    I run my car at tracks that are known about how hot it gets (Vegas, Sacramento, Bakersfeild) all 100*+ tracks during the summer and my driver wears a -20 suit. ITS MY JOB to be aware of his condition at all times. We have a set of proceedures and signals that we do and if he does not or incorectly respond to those signals I will evaluate the situation AND WILL shut him down if there is somthing wrong, AND if he feels something is not right he can shut the car down and I wont say a word , even if its the final
  11. cgaswillys
    cgaswillys
    from New Jersey
    Always remember to drink tons of water twhen it's hot out at the track. Especially if you don't normally spend alot of time out doors in the heat.
  12. dreracecar
    dreracecar
    from so-cal
    Biggest problem with racing in heat is that the driver sweats inside the suit and although the suit will protect from flame any heat from a fire will turn the sweat into steam and the driver boiled/cooked. Better to keep driver in tow car with the air running untill the last moment. If that is hard to do then at least keep the helmet inside with the A/C blowing into it till just before you ready to fire.
  13. ..he's pretty sure of himself. he said he'd bet a nickle!
    ...we can keep hashing this out; let's just all be glad the driver is ok, and that lessons were learned from the whole experience.
    The rest of the Meltdown weekend went off without a hitch; many props to all running the show.
  14. HotrodHans
    HotrodHans
    U betcha there Mr. Pres. The California lazy chair quarterback didn't get the heat stroke part of it. I'm sure he means well but how many PROFESSIONAL racers have died with all the safety equipment in place?
    It's a Nostalgia race. Rules are usually bent a little otherwise there WOULD BE NO RACE.
    I can guarantee you the safety requirements on the rail were much better than what was required in the 60's.
    A HANS device wouldn't have done a thing for the side impact he experienced. You could see the tire and wheel imprint embedded into the concrete barrier when he hit. Besides his 14" wide wheel was about 6" on the trailer. He hit HARD, thus the broken ribs.
    Fortunately it turned out to be IMO the best scenario that could have happened. Had he gone straight at WOT he'd be in the Nuclear plant. Had he done a 180 I can't imagine the catastrophe that would have happened in the staging lanes.
    Everyone should cool off and learn from this experience.
    Shit happens and there is absolutely no control over that.
    Oh yeah, I had a BLAST!
    Thanks to you and your helpers for putting on this fantastic show.
    One request... ask for 70 degree weather next year :)
  15. pnevells
    pnevells
    Really glad to hear the driver is OK, I had a heat stroke incident in my FED 20 years ago in the shut down area, i passed out with my hand on brake lever and off the gas pedal, it took gatorade and bananas in the ambulance to start to recover,I had no recollection of slowing the car down, i drank gatorade always after that and never had a another problem
  16. D_Lazaris
    D_Lazaris
    from So. Cal
    My heart almost stopped when I watched this video. When I am in the staging lanes, waiting for a long time, suited up, especially in the summer. This has always been on my mind...
    Very scary, and I am glad he and everyone else is okay.
  17. That is my job with Tim strapped in the truck at the Salt. Far too many folk take this stuff lightly. Call me cautious but ALL my hobbies have a chance to kill a guy, racecars, Ice Climbing, Mtn biking. Yeah even those bicycles, we have had one killed and one paralyzed here this year alone on downhill bikes. Clint said it best, "a mans gotta know his limitations!"
    Glad the guy came out of what could have been even worse.
  18. saltflats
    saltflats
    from Missouri
    Glad the driver is ok.
    I still got to have one of them FED the wife is not crazy about it guess I wont let her see this.
  19. A friend of mine died from heat stroke a couple of weeks ago. It ain't no joke. Having said that, my hat is off to the engine builder.
  20. I'm surprised in all the talk over this accident in this thread and others the smoke inhalation side of it is never mentioned. Could you imagine trying to breath in the amount of tire smoke that was being produced ????
  21. fridaynitedrags
    fridaynitedrags
    Very well said. Common sense to the fore. :D
  22. fridaynitedrags
    fridaynitedrags
    Thank you for your insightful contribution. When's the last time you worked a tech line?
  23. Good point, I have been there and it is nasty! Guys lungs won't be right for ages if ever!
  24. yruhot
    yruhot
    And it goes on and on. Just glad the guys ok. If racing wasn't dangerous everybody would be doing it. Drink,Drink,Drink, then drink some more water or sports drinks. Keep those electrolites amped up. The suns a killer.Doug
  25. Zettle Bros.
    Zettle Bros.
    Yeah, I'm surprised with all the inferior workmanship and unsafe cars that Eric and the MDA crew and AJ and Ron haven't killed us years ago. I know when we line our car up at the track that I can't wait for that bad wheel bearing too fail and the half ass brakes we have go out. Then again, that's what you can expect from us slackers!!! You really think that's what goes on at this meet? I love how you can truly be an authority on the subject because you been to the meet so many times. So if you can't tech for us slackers, then by all means bring your car out so we can get a first hand account on how a drag car is suppose to be setup.
  26. hugh m
    hugh m
    from ct.
    I always consider myself a customer in a tech line,and notwithstanding the rules, and if the person I am dealing with is a pompous bufoon who calls whole groups of folks "slackers", guess what? I will go somewhere else next time. (But I probably woud not have to because people with attitudes usually don't keep their jobs very long.)
    Good luck to all the slackers everywhere.
  27. Zombie 51
    Zombie 51
    from New York
    Well I'm glad to hear he is ok. I'm looking for a little more info on some of the things stated in this thread. Someone asked about a kill switch and the answer was that you can't have a kill switch on a nitro engine because it would be very dangerous and potentially turn it into a bomb. Can you explain further?
  28. frank spittle
    frank spittle
    Nitro in a hot engine does not need spark to fire. The compression and heat will fire it and if it does not fire or misfires on a stroke it can cause an explosion.
  29. Zombie 51
    Zombie 51
    from New York
    Thank you! A Diesel engine will run on like that too, right?
  30. rooman
    rooman
    A diesel is a compression ignition engine right from the get go whereas a nitro burner can end up that way by default.
    Roo
