Hot Rods No room for Master Cylinder....'49 Hudson
Discussion in 'The Hokey Ass Message Board' started by airbrushguy, Jan 14, 2020 at 8:34 PM.
  1. airbrushguy
    airbrushguy
    from NJ
    Putting a 500 Cadillac/ TH400 into a 1949 hudson Super with a Fatman Fab frontend and despite what seems like a difficult instal, the brake pedal and MCplacement is turning out to be the most difficult. The lower left side of the engine needs to fit the steering column, brake pedal, MC, and exhaust.
    Has anyone been in this situation and found a brake pedal/MC/and 7"booster setup that is compact enough to fit in tight space?
    The under dash 90˚ setup won't fit with stock heater/fan in way. I can't find a setup that will mount anywhere except on the inside of the left frame member
    Does anyone have a suggestion or solution that worked for them and doesn't leave the booster and cylinder out on the firewall?
    Thanks
    Hemi Joel likes this.
  2. squirrel
    Can you leave off the booster, and run a smaller bore m/c, and still stop ok? that would be my approach, I think.
    I didn't have too much trouble with the stock brake system in the 51 Hornet I had, but it had a rather anemic engine, compared to the Caddy mill you're swapping in.
    Hemi Joel, nochop and jimmy six like this.
  3. jimmy six
    jimmy six
    A 3/4 or 7/8” MC and multi piston front calipers an at least 11” rear drums with 7/8”or 15/16” wheel cylinder will stop like power if your pedal ratio is 5 to 1 or more. Wilwood has 4 or 6 piston calipers.
  4. airbrushguy
    airbrushguy
    from NJ
    It will have disks in front/drums back, and it weighs 3800lbs.
    Just thought that would require power brakes....?
  5. borderboy1971
    borderboy1971
    from Canada
    I built a Coe 40 Ford years back, and mounted the booster inside the firewall (dash side) and master cylinder on the outside (engine side). Homemade swing pedal assy. Would that work for You?
  6. airbrushguy
    airbrushguy
    from NJ
    Good suggestion but would really like to hide it completely.
    Thanks
  7. borderboy1971
    borderboy1971
    from Canada
    Maybe mount the master under the dash and use a remote vac booster.
  8. Hemi Joel
    Hemi Joel
    from Minnesota
  9. ratrod0
    ratrod0
    You can put the master, under the rear floorboard the push rod can be as long as you wont
    morac41 and Hemi Joel like this.
  10. razoo lew
    razoo lew
    from Calgary
    How much space do you need - can you offset the engine a couple of inches to the right?
  11. morac41
    morac41
    Radrod0 X 2 Shift the mastervac halfway along the chassis and use a rod to actuate..
  12. mgtstumpy
    mgtstumpy
    I had similar issues with my 46 Olds with my underdash brake assembly due to AC unit. I moved entire assembly to the left and modified with an extended 1" solid bar machined with 3/4DD end and delton bushings for pendulum pedal to position correctly. I used a 3/4DD coupling to connect and fabricated a short fulcrum to maintain OEM geometry and machinded end for circlip to secure and prevent lateral movement. Problem solved, my engineer is more than happy as many RHD conversions used a similar crossover rod whilst maintaining LHD brake assemblies. 20190903_154212.jpeg 20190515_213908.jpeg 20190515_213847.jpeg
    Sent from my SM-G973F using The H.A.M.B. mobile app
  13. Rusty Heaps
    Rusty Heaps
    Brakes are highly over rated any way!:eek:
    mgtstumpy and bobss396 like this.
  14. goldmountain
    goldmountain
    Not sure if this helps but I had a 1989 Dodge Colt made my Mitsubishi that had its brake booster and master cylinder on the passenger side with linkage for the brake pedal on the driver's side. You could make something like that.
    Sent from my SM-T350 using The H.A.M.B. mobile app
  15. squirrel
    They did that because it was a RHD car to start with, and they decided to export a few without wanting to redesign the whole car. Interesting idea.
  16. You can get remote power boosters, you mount the master cylinder on the pedal like normal, then plumb the hydraulic line to the remote booster, then out to the callipers, great space savers, google VH44 brake booster
  17. goldmountain
    goldmountain
    There is more than one way to skin a cat.
  18. onetrickpony
    onetrickpony
    from Texas
    Would a hydroboost system fit under the floor? It should be smaller diameter than a vacuum booster, but you would have to deal with the lines from the power steering pump.
  19. sunbeam
    sunbeam
    How about a truck hydrovac.
  20. mgtstumpy
    mgtstumpy
    Some Alpha Romeos, Mercedes Benz and others have that factory crossover bar, saves re-engineering components if you have some spare under dash space available.
    This is my under-dash brake set up, the assembly was pushed over to the left for clearance, this placed the OEM brake pedal to the left of column, too dangerous in an emergency. The crossover bar moved the brake pedal 6" to the right and on the righthand of column, a lot easier and safer to access. Out of sight, out of mind. I've a hidden remote reservoir for MC with a stout steel frame (Secured side to side and firewall) that supports everything; brakes and AC. Remove the bolts and the frame with everything attached just drops out if necessary, or just service individual parts in situ.
    OEM brake pedal pivot was moved from circled area to lined area for required clearance, all OEM geometry was maintained. OEM brake pedal boss was drilled out with holesaw allowing pedal to be fully welded to new solid stock. Small flange on top of pedal arm is OEM fulcrum that will be cut off when complete.
  21. ken bogren
    ken bogren
    Here's a setup I saw on an early ford bronco. Fairly compact. Note the angle.
    squirrel likes this.
  22. Dwardo
    Dwardo
    Hudson offered power brakes in 1954. Maybe if you could get the pedal and bracket from one of those the pedal part might be near to a bolt-on. They're kind of rare. Also, I ran a Bendix Hydrovac booster on my '51 Hornet and it was almost too good. Very powerful. I put it on the left fender liner where it made seeing the timing marks on the flywheel almost impossible.
