Anyone else running this cam? Nielsen 435H Cam 110 degree lobe separation Lobe lift is 290" Duration @ .050" 224 degrees both IN & EX Dyno results 275.8 Max HP at rear wheels @4700 RPM 344.3 Max Torque @ 3500 RPM
It's a well behaved, predictable and reliable motor - easy to start and great low end torque right up to where it starts to flatten out around 3500. Great match to the 3speed LaSalle Trans which has has its own special sound due to that heavy duty gear set!
Dave - The engine is a 1951 Cadillac 331 cid bored to 365 cid - Eldorado dual quad set up with Eldorado big port heads and exhaust manifolds - full car details at this H.A.M.B. link https://www.jalopyjournal.com/forum...-old-school-done-right.1157307/#post-13172240
