Technical New speedo cable
Discussion in 'The Hokey Ass Message Board' started by mack57, Apr 28, 2014.
  1. mack57
    mack57
    Hey All!!
    Just replaced speedo cable for TH350/305 and stock '48 speedo. Do I need to lube the shaft? At about 40mph it starts to squeal & jump all over the place??
    Any thoughts?
    Mack
  2. 325w
    325w
    Yes you should lube the cable.. Might have to remove the speedo and see if it has a small brass plug you can remove and oil the felt pad on the shaft there. Most do.
  3. mack57
    mack57
    Thanks!!
  4. olscrounger
    olscrounger
    lube the cable with graphite-don't get it on anything else
    lothiandon1940 likes this.
  5. Someone suggested mixing powdered graphite with rubbing alcohol, and squirting it in with a syringe. Alcohol evaporates and leaves graphite in place.
  6. e1956v
    e1956v
    Alliance Vendor
    Guys do not use graphite, it works its way up the cable and will reek havoc on the speedometer. Graphite is a speedo repair shops best friend. Use lithium grease, pull the cable, coat it and feed it back in.
  7. mack57
    mack57
    Lithium grease! Got it! Thanks guys!!
  8. When I ordered my speedometer cable from Rusty at Speedometer Service he told me to never use graphite.
    I figure a man that makes his living rebuilding speedometers and making cables know best,only use lithium grease. HRP
  9. mack57
    mack57
    I agree!! And I appreciate the info!
