New project 1934 Ford Truck
Discussion in 'The Hokey Ass Message Board' started by 32fivewindow, Apr 15, 2010.
  1. 32fivewindow
    32fivewindow
    from USA!
    original 1934 chassis split wishbones, original dropped axle 12 bolt rear
    original 1934 ford truck grill, on a shelf for 47 years bought from the original car owner whe hit a deer with it
    perfect passenger door
    This weekend I tear into the frame, someone did an interesting frame box job on it... and one rail is a little tweaked... oh and can anyone identify these disc calipers?
    I need a cab and driver door still, sucks because I want to bolt a cab and motor in it... :D I know of a couple flatheads or a local 331 hemi... any thoughts?
    anyone know of a local cab/door?
  2. 32fivewindow
    32fivewindow
    from USA!
    Update body on frame lightly bolted together, new wheels tires, and workin a 49 flathead back to life...
  3. Vendome
    Vendome
    Well it looks to me like you have a good start to a nice hot rod truck!
    Fenders? No fenders? Good luck with your project.
  4. hotrodjeep
    hotrodjeep
    from Tama, Iowa
    From this angle the rear spring hanger looks a little weak?
    Maybe there are some gussets we can't see.
    Other wise you better be adding a little more steel to that mount.
    Good luck with the Flatty too.
    Jeff
  5. 32fivewindow
    32fivewindow
    from USA!
    The rear hanger goes all the way around the underside of the axle, but yes I too am planning on adding some milled steel stock.
    I am going fenderless on this one. I was going to channel it, but I'm liking the way it sits right now, and once I get the engine in, the front end will be down. I am 6' 3" and have a hard time fitting anyway.
    The flatty is a untouched 1949 ford, well see if I can get her to run.
    Anyone able to identify the from brake calipers? They are 4 piston. Can anyone give me any info on them...???
  6. 32fivewindow
    32fivewindow
    from USA!
    Tearing the flat head apart, it came out of a 46,00 mile car. The oil is fresh in the motor... I think this is going to be an easy engine "freshening"
