NEW PRICING: 1937-48 Steering Arms, Dropped
Discussion in 'Parts For Sale' started by GrumpsGarage, Jan 23, 2020.
  1. City: LAKE ELSINORE
    State: California
    Price: 54.99 & Up
    1-3/4" drop $64.99. 3-3/4" drop $54.99. https://grumpsgarage.com/product/1937-48-steering-arms/ Can be fit to 1937-47 Pickup. These forged steel steering arms are popular on 1928-1934 Fords with 4″ dropped axles and four-bar or hairpin radius rod suspensions. Will attach to ’37-’48 Ford spindles and accept 11/16″ Ford “tapered” tie rod ends (both the top and bottom are tapered to allow tie rods to mount above or below arm as needed). You can drill-through with a 5/8″ bit to use spherical rod ends. Use a 46″ eye-to-eye tie rod link when used with a 48″ wide axle with Ford spindles.
    Notes
    1. For use with spring-over front axles ONLY. Should NOT be used with spring-behind front axle assembly. Flat plate arms are required when using a spring-behind front axle.
    2. Use a 46″ eye-to-eye tie rod link when used with a 48″ wide axle with Ford spindles.
    Specs
    • 1 3/4″ or 3 3/4″ drop (measured from center of threaded spindle mount holes to the bottom face of the arm, as positioned in the photo).
    • 3 3/8″ eye-to-eye centers on mount bolt holes.
    Lasallefever likes this.
