Technical New life for an ole dog
Discussion in 'Traditional Hot Rods' started by ls1yj, Jul 30, 2017.
  1. ls1yj
    ls1yj
    from Kentucky
    Got new 59L motor fired up in the coupe this afternoon. Adjusted a bit on carbs, and it's idling ok, but we are hearing a fairly loud roar from passenger side of motor. I'll try to load a video when I get home to PC.
  2. ls1yj
    ls1yj
    from Kentucky
    TagMan and SLCK64 like this.
  3. brady1929
    brady1929
    from Mesa, Az
  4. rustydusty
    rustydusty
    Nice! I like your "tool bench" .
    ls1yj likes this.
  5. farmalldan
    farmalldan
    from Duncan, OK
    Generator? Remove belt for a short run to see if the noise goes away.
    Good luck.
    farmalldan
    ls1yj likes this.
  6. ls1yj
    ls1yj
    from Kentucky
    Got an update... we listened all over motor and also took all floor panels out, and listened to thrust rods, trans case, etc... turns out, we put a new aluminum McLeod flywheel in, and it's about .100 thicker than the cutdown steel flywheel we were running. It was pushing the auburn clutch rearward into the clutch fork, and causing the growl.
    mike in tucson likes this.
  7. ls1yj
    ls1yj
    from Kentucky
    Well, that wasn't it. shimmed trans back 1/8" and motor is still making bad growl noise
  8. ls1yj
    ls1yj
    from Kentucky
    Pulled shims, and dropped pan... checked all mains, and they have nice wear pattern
  9. ls1yj
    ls1yj
    from Kentucky
    Pulled 5 and 7 rod caps and they have no wear
  10. ls1yj
    ls1yj
    from Kentucky
    Gonna plastigage them tomorrow... may be too loose, and causing the noise... it's starting to knock more now
  11. ls1yj
    ls1yj
    from Kentucky
    Pulling heads off, to remove pistons and rods. Found one rod in backwards, and seems like rods were out in without being resized
  12. ls1yj
    ls1yj
    from Kentucky
    Found smoking gun. Some pistons were making light contact with head on one side. Gonna mill squish area deeper
