Technical New hemi owner
Discussion in 'Traditional Hot Rods' started by Omarsvette, Oct 31, 2018.
  1. classiccarjack
    classiccarjack
    To help destinguish between a A500 and a A518 oil pan... Screenshot_20181102-123704.jpeg
    Sent from my Moto Z (2) using The H.A.M.B. mobile app
  2. Bandit Billy
    Bandit Billy
    So, is a 500 an OD?. It has manual shift and a 3 post plug for the OD. Flat pan like you showed. I didn't know there was a difference.
  3. gatz
    gatz
  4. Work In Progress
    Work In Progress
    Just to add a little to the discussion, I used a 518 out of a 92 Dakota with a 318. It is the non lockup version and takes a 727 torque converter. I also had a 727 from a 440, I transplanted the beefier guts from the 727 into the 518 including the intermediate band servo lever (went from a 2.8to 4.? ratio), used an early servo piston and added a spacer to the low/reverse band servo piston. Made a beefy little combo
    If you use a 518 from a 5.9 (360) the converter might be externally balanced. FYI
    Adam
    classiccarjack likes this.
  5. Omarsvette
    Omarsvette
    from Arizona
    I like the idea of the A518, so it's fine spline input?
  6. Omarsvette
    Omarsvette
    from Arizona
  7. patsurf
    patsurf
  8. Omarsvette
    Omarsvette
    from Arizona
    So that's what all the 4x4 cases look like?
  9. s55mercury66
    s55mercury66
    from SW Wyoming
    Yes. As a general rule, they have a tailshaft housing that the transfer case bolts to. The tail shaft itself will be shorter, but a 2wd tail shaft can be installed, along with the 2wd tail shaft housing, giving you a 2wd trans. I would imagine a 4wd small block 727 would not be hard to find, especially in a Ramcharger, if you are looking for a 727. Of course, it would need to be converted, and could be done quite easily during a rebuild, using parts from a 2wd B/RB version. The B/RB 2wd one seems to be the easy 2wd version to find around here.
  10. Omarsvette
    Omarsvette
    from Arizona
    And the visual difference between A518 and a 727 is the three pin connector, torq converter bolts, and a deeper oil pan on the A518, but the same shape.
  11. Omarsvette
    Omarsvette
    from Arizona
    And it looks like the 727 has a thinner tail housing (thinker housing for o/d?)with no mounting holes. image.png image.png
  12. Omarsvette
    Omarsvette
    from Arizona
    image.png As far as 727 goes, these won't accept a traditional yoke?
  13. bundoc bob
    bundoc bob
    Pre-65 had a 4 bolt yoke like that pic, both 904 and 727. 66 and up had the new style splined output and standard length tail housing [2WD] and again, 904 and 727 had those changes in 66. 65 is an orphan, splined output shaft, but a different length. 65 also retained the cable shift. 66 and up went to mechanical linkage.
    904s are actually 6 cyl only in the later model years, in the early years it was used [with a different case] for both slant 6s and the 273 later the 318 got a 904LA with double-wrap lo-reverse band [case is different] along with other upgrades. Later it became the 998 and there was a 999 for 360s, which got a wider kickdown band/drum and an extra front clutch plate. There are also 4 speed OD versions of the 998/999 called, in the early days the A-500. All the later 904 family and A-500s got the wide ratio gear set, easy to tell because the planetary carriers went from cast aluminum to welded/folded steel.
    RustyDogg and classiccarjack like this.
  14. classiccarjack
    classiccarjack
    They made it simpler, they added the weight to the flexplate. The earlier 727's used weights on the Torque Converter itself. All lock up OD's behind a 5.2 or a 5.9 have the same converter....
  15. classiccarjack
    classiccarjack
  16. classiccarjack
    classiccarjack
    Beat me to it...
  17. Omarsvette
    Omarsvette
    from Arizona
    I was at a swap meet this past week end. Saw a th350 for $350 but kept walking to see what else was available, I'm keeping my options open being that I'm going to need a adapter no matter what tranny I get. For some reason I'm stuck on a mopar tranny. I'm looking for a s10 rear, they fit perfect but I'm wondering if the dodge Dakota is the same width. Maybe it would be nice to keep it all mopar?
  18. 73RR
    73RR
    There are several good rear end choices at the bone yards. Check my web page for measurements of a couple popular units.
    Hombre likes this.
  19. enjenjo
    enjenjo
    from swanton oh
    S10 2x4 is 54" S10 4x4 is 58" Dakota is 60" Explorer 8.8 is 55"
  20. mikeselcamino65
    mikeselcamino65
    Hey thought I'd put in my 2 cents worth...I just finished a 354 rebuild and I think the best easiest route for a trans is an adapter plate and flywheel...(there are several available) for a chevy t350 or t400, 700r...
    and if you get the driver side starter location you can use a block mounted oil filter adapter...
    The chevy converters are cheap and so are the shifters... Stuff is easy to find and work great...
    HemiDeuce likes this.
  21. I envy you your rare 4bbl manifold w/ the thermostat housing. Consider keeping it (very good design. Chrysler was a leader in manifold technology in the day) and modifying it for a bigger, modern carb by boring it with a hole saw and using a carb adaptor. Here is how I did it on my 354 manifold for my Holley 3bbl.
    Hombre, Dog_Patch and classiccarjack like this.
  22. Omarsvette
    Omarsvette
    from Arizona
    I agree. Tying to find a 727 or OD 727 is harder than my finding my hemi. I got a th350 brand new for 550. With converter.
  23. Omarsvette
    Omarsvette
    from Arizona
    Thank you. And I'm impressed with your intake mod. Didn't think it could be done. I am planning on keeping the intake. Especially cuz of its rarity.
  24. Omarsvette
    Omarsvette
    from Arizona
    I'm starting a thread on this build in the project section. Title, 31 ford build.
  25. classiccarjack
    classiccarjack
    Cool, I will definitely check it out
  26. gimpyshotrods
    gimpyshotrods
    S10 2x4 is 54", S10 4x4 is 58", Dakota is 60", Explorer 8.8 is 59-1/2".
    Atwater Mike likes this.
  27. Omarsvette
    Omarsvette
    from Arizona
    A3C31AD5-7D78-475C-B193-7F4F79645039.jpeg This is a water tube coming from the pump housing. Does anyone know where it goes?
  28. dang....how did I miss this Hemi post on my birthday......good stuff guys.....
    Omarsvette likes this.
  29. usually that is for a heater hose connection on some mopars I believe....
  30. Omarsvette
    Omarsvette
    from Arizona
    Happy birthday. That’s what I thought. I’m thinking of plugging it. I think it’s threaded.
