New from the Rubber Factory! Tire measures 29 3/8" Diameter Tread with 7" Currently only in 15" rim size , 16" rim soon Capped on RADIAL 235/75/15 Ron Hurst never used this mold, one of many we are bringing back from the dead. Proably purchased from "BUCK RACING TIRES" around 1970. Tire is "Pre Cambered" wich was a practice in Circle Track tire technoligy in that era. Bullet Holes are only on one side of tire and backside is solid. Pattern in tire tread surface was to aid in cooling of tire. Cheater grooving or Dirt patterns still can be cut in tread face if desired. Tires are available and in stock! Thank You for watching! Adams Hot Rod Rubber/Hurst Racing Tires
So, can the camber be shaved off? What's the signifigance on the street or in a drag race application? Looks like it would need to go.
