Hot Rods New chevy 350 motor from GM
Discussion in 'The Hokey Ass Message Board' started by mikyboy, Nov 17, 2014.
  1. mikyboy
    mikyboy
    there is a passenger side dipstick hole I'm not going to use.It has a plastic plug in it. Is that a temporary plug or a permanent one or do I need to get something else?
  2. plastic is temp it should have came with a steel "slug" that you would coat with sealer and tap into the hole
  3. 325w
    325w
    Most the ones I've seen had two plugs. Different size plug for left and right. Should be in the bag with the papers.
  4. jimcolwell
    jimcolwell
    from Amarillo
    If it is a real GM crate motor, it came with the plug and 2 timing indicators.
