I have started making 32 pedal brackets. They are made off tooling from an original bracket. Everything is as close to original as I can make it. You can bolt this bracket to the original K member using the original holes. Most any pedals can be used. I like the 40-48 ones and bend to suit. An original shaft is in the assembled one. New shafts are $20 from Mac's or make your own from 7/8" cold rolled. I may make them also. I have just the three brackets made. I will do more if they sell. The grey ones are original ones. I think original sets are about $400. You can sure do a set with this bracket for a lot less.
