Greetings! Asking if anyone knows what this manifold will fit, I was hoping 235 but no luck. The three intake openings are 10-1/4" from each other, the carb risers are 4-3/4" tall, 12" apart. There is a section of the horizontal log tube that has been cut, moved up and then rewelded, I suppose for exhaust manifold clearance. One surviving Carter carburator, linkage modified, tag welded to horizontal log tube says "Jim Taylor, Pat App For", beautiful welds. Any help identifying this relic appreciated, Thanks, Mike.
The shape of the end port flanges make me say IHC six. See if you can find one ahd compare dimensions.
