hey fellas I'm in desperate need of more of these brake fittings. I can't find them anywhere. Anyone know where I can find some?
look for a Elbow Swivel - possibly 3/8x24NFx2 ? - check Dorman catalogs for most common supplier available through most auto parts stores - need more info from you
Yeah. it's inverted flare. 3/8 fitting for 3/16 brake line.basically the male end,would fit in the female end of it. As in the male would go into the side of a master cylinder and then you could run your brake line into it. My master is under my dash and need to run my lines up from the bottom against the firewall. I also need it for a clutch slave setup I'm working with. It's not off of anything. It's aftermarket that I can't seem to find now.
maybe this is closer? hard to say http://www.brakequipproducts.com/product/brakequip-bq141-elbow-swivel-38-x-24nf-x-2 here's their catalog
The contact page for this place has an area code in the Nashville area: http://www.brakeconnect.com/product/elbow-swivel-38-x-24nf-x-2 For dealer contact: http://brakequip.com/contact-a-dealer/
We have a new brake vendor here but I cannot recall his co. name. He has been very helpful with other build questions. I will try to find his info..........
Here ya go...............Todd may be able to help you....here is a post from him https://www.jalopyjournal.com/forum/threads/brake-line-and-fitting-sizes.1093900/#post-12403749
I have used that style of Brakequip fitting that I ordered through a company that makes hydraulic hoses . You might check around locally for a hydraulic hose co. Bill
