Technical Need Some Info On A 1940 1941 Lincoln Zephyr Grill Piece
Discussion in 'Traditional Customs' started by Black Panther, Nov 13, 2013.
  1. Black Panther
    Black Panther
    from SoCal
    Does anyone know what the center trim piece on the grill of a 1940-41 Lincoln Zephyr is made out of? Is it chromed pot metal...brass...stainless? Its the spear that goes up and down between the two grill halves....thanks!
  2. skooch
    skooch
    Pretty sure it's pot metal
  3. Black Panther
    Black Panther
    from SoCal
    Thanks for that...anyone else have any idea?
  4. Smokey2
    Smokey2
    what Skooch said, Good Luck !
  5. hari kari
    hari kari
    from michigan
    Pot metal....i have seen brass reproductions
  6. fordpatina
    fordpatina
    Pot metal
    kidcampbell71 likes this.
  7. fordpatina
    fordpatina
    Very fragil as the grills
    Asphalt Demon likes this.
  8. dr nick
    dr nick
    from arizona
    Same as 40 Merc: pot metal. I filled the crank hole with bondo, sent it to Jon Wright Plating in Ohio & he filled the hole with lead then chromed it; it looks factory!
  9. PotmetalB
    PotmetalB
    I hope it holds for the hall?? Pot metal is weak and adding even a weaker material to it will only cause more problems for a proper repair. Consider having it welded next time. It's a piece of mind knowing that it'll never break again even under vibration.
  10. PotmetalB
    PotmetalB
    I just repaired a '37 Merc grille. It was broken in 9 piece both sides combined. Pot Metal can easily be welded if you know how to handle it. definately not a task for the common welder...
  11. PotmetalB
    PotmetalB
    I'd be very interested in learn how the plater added lead to fill cracks in your grille? Becuase the first thing that comes to mind, they either used a soft solder (lead based) like muggyweld with is very weak, or what's typical, copper plated and filled with conventional "off the shelf" solder. the type used with an iron. Either way you're looking at a tensile strangth of only 20k per inch. Properly welded pot metal joint has tensile strangth of 70k+ meaning it isn't going to break at that point again under typical vehicle vibration. Besides that, your plater will love you for it and will give you a better deal if he doesn't have to deal with cracked or broken pot metal. :)
  12. PotmetalB
    PotmetalB
    Fix the original oem stuff.
  13. PotmetalB
    PotmetalB
    fix it once and for good. Weld it!
  14. PotmetalB
    PotmetalB
    Yep. Nothing wrong with good ole #potmetal. :)
  15. PotmetalB
    PotmetalB
    Chromed pot metal my friend. Just repaired a '37 Merc grille couple months ago...
