I'm putting together my first Halibrand quickie for my A roadster pickup. Its new and one of the last of those Made in Kansas center sections from a few years ago. Ive done a few standard Ford banjo rears and one Columbia but this is my first Halibrand. Cant find any manuals anywhere so Ill just ask. 1) Whats the best torque for the 3/8-16 NC steel housing to aluminum center section bolts? Is it the same or less than for the standard 3/8-24 bolts in the Ford steel center section? 2) Whats the best lube for a Quickie? Ive heard use Sta Lube SAE 140 hypoid gear oil but I think the regular Ford recommendation was for SAE 90. 3) I know a quickie with straight spur gears is noisy and Ive always heard that hypoid gears will eliminate the noise. Problem is they put to much pressure on the rear cover plate. Is that true and do they even make such gears? 4) Ive got my ring and pinion backlash set about right (.005/.006) but there sure seems to be a lot of backlash between the two spur gears (about .020 at the gear teeth) with no adjustment available. Seems like you would get a real clunk sound out of the rear end every time you let up on it or is that just part of the charm of a quickie? 5) Lastly, what the hell are those two side by side 3/8 pipe thread holes in the back cover for? I'm guessing it's to add lube for the spur gears but why two and why higher than the side fill hole?
Try using the search function on here. There has been plenty of good info posted on here previously. Good luck with the quickie. Im yet to put mine together and can't wait to do so. What are you puttin it under?
As regards (3) on your list, you mean helical-not hypoid and NO, nobody makes such animals. They would be impossible to install or remove on the straight splined thru and pinion shafts. The clearance (4) is part of what makes a Q.C. what it is. Remember: they were designed for circle track cars where once under motion you stayed under motion until either crashing or taking the Checkered.
As a vintage racer we run all the quick changes and they're basically all the same since Frankland never patented it. Go to Winters quick changes on the web and all your torques and fluid info is there.
P.S. Those 3/8 plugs are for filling the back section. Fill one till it comes out the other. The front section holds more and is lower so weight and volume will fill the smaller rear cavity higher.
Halibrand does sell helical gears for the quickchanges, they do put added pressure on the housing since they are giving a pushing out motion, as long as the ring and pinion are set right there is really minimal noise from straight cut gears, some are noisier then others but thats part of love of them, that hum just has a sweet sound to me.
Winters Performance sells helical gear sets for V8 (6 spline) and Champ (10 spline) quick change rear ends. http://www.wintersperformance.com/catalogs/03StreetRodRears/index1024.htm
The bearings in the cover need to be changed to ones that can take a side load to use the helical gear set.
I ran synthetic in mine. With the regular oil you could not touch the cover plate with syn. no problem.
