need some chopping help....
Discussion in 'The Hokey Ass Message Board' started by evobuilder, Feb 2, 2014.
  1. evobuilder
    evobuilder
    so I am removing my visor from the coupe (see pic) for a lot of reasons, but the best reason is that I don't like it. I need some help deciding what tool to use to cut off.... I need to cut a straight line, up against the windseild frame, so I can mount my new custom visor. Soo.... which does everyone else use for cutting looooooong straight lines....
    • air nibbler
    • air saw
    • air cut off wheel
    • other?
    I don't want to use a plasma cutter as that would make the cut really ugly and the straighter the cut, the less work to mount my new visor.
      118.9 KB
  2. metal man
    metal man
    Air cut off wheel. A new, large diameter one.
  3. I'd clamp a straight edge on as a guide and cut along it with a cut-off disc on an angle grinder.
  4. fastcar1953
    fastcar1953
    sheetmetal shears and a guide or nibbler .
  5. straight edge and a metal blade in a circular saw , wear your goggles , its only 18 to 20 gauge, it'll cut like butter , clean the cut edge up with a grinder . if you leave it a little long you can peen it over or hem the edge .
  6. I'd use an air saw, then sand it back to a scribed line.
    Cut off wheels make mess, and can get away from you.
  7. evobuilder
    evobuilder
    clamping a guide is a great idea. I was going to scribe a straight line, but yes, a guide would make things easier. I am leaning towards a air saw first, air cut off wheel 2nd. I think the air saw will give me the most control, but the air cut off wheel would be the cleanest.
    We'll see it goes, either way, I need to order a tool because I don't have any (air) cutting tools. Time to get shopping!
  8. fastcar1953
    fastcar1953
    if you don't have the tools yet make sure you practice with them first . unless you have used them before.
