I`m working on a mid 20`s chevy steering box for a gowjob project, and it has bronze bushings above and below the screw. The shaft is 3/4" and the housing is very close to 7/8" inner diameter. My thought is that this should be a size that is used on alot of other stuff like kingpins etc. I need advice from all the gearheads on here to find something i can use. Do you have somthing lying around that you can measure. Preferably something easy to find. Any help is very much appreciated. Thanks.
I buy from them almost everyday, Very easy to set up a account, ships straight to your HOME Mc Master Carr This is an active link click on it and it will pop up for viewing. http://www.mcmaster.com/#sleeve-bearings/=acw7iy <NOBR>Bushings > </NOBR><NOBR>Type > </NOBR><NOBR>Material > </NOBR><NOBR>For Shaft Diameter (Inside Diameter) > </NOBR>Outside Diameter View catalog pages (4) Compare products (29) <NOBR>Sleeve Bearings</NOBR> 29 products match your selections <TABLE id=ItemTable cellSpacing=0 cellPadding=0><TBODY><TR class=featValRow onmouseover="this.className = 'featValRowHL';" onmouseout="this.className = 'featValRow';"><TD class=featureNameCell>Material</TD><TD class=featureValueCell>Bronze</TD></TR><TR class=featValRow onmouseover="this.className = 'featValRowHL';" onmouseout="this.className = 'featValRow';"><TD class=featureNameCell>Type</TD><TD class=featureValueCell>Sleeve Bearings</TD></TR><TR class=featValRow onmouseover="this.className = 'featValRowHL';" onmouseout="this.className = 'featValRow';"><TD class=featureNameCell>System of Measurement</TD><TD class=featureValueCell>Inch</TD></TR><TR class=featValRow onmouseover="this.className = 'featValRowHL';" onmouseout="this.className = 'featValRow';"><TD class=featureNameCell>For Shaft Diameter (Inside Diameter)</TD><TD class=featureValueCell>3/4"</TD></TR><TR class=featValRow onmouseover="this.className = 'featValRowHL';" onmouseout="this.className = 'featValRow';"><TD class=featureNameCell>Outside Diameter</TD><TD class=featureValueCell>7/8"</TD></TR><TR class=featValRow onmouseover="this.className = 'featValRowHL';" onmouseout="this.className = 'featValRow';"><TD class=featureNameCell>Specifications Met</TD><TD class=featureValueCell>Not Rated</TD></TR></TBODY></TABLE> <TABLE id=RemainingFeaturesTable><TBODY><TR><TD class=featureHeadCell>Bronze Type</TD></TR><TR><TD class=featureCell><TABLE class=TableImgTopNoImg cellSpacing=0 cellPadding=0><TBODY><TR><TD class=TableImgTopCellnoImg onmouseover="javascript:this.className = 'TableImgTopCellnoImgHL';" onmouseout="javascript:this.className = 'TableImgTopCellnoImg';" onclick="ItmLstRow_Click('./psearch.asp?FAM=sleevebearings&FT_158=168168&FT_101=3902&FT_9208=319915&FT_135=631&FT_1019=154363&session=desc=Bushings;sleevebearings;158=168168;101=3902;9208=319915;135=631;1019=154363');" vAlign=top width="33%" align=left>Alloy 932 (SAE 660) Bronze This nonporous, cast material makes hard, strong, and abrasion-resistant bearings with excellent resistance to shock loads (suddenly applied loads) and wear. </TD><TD class=TableImgTopCellnoImg onmouseover="javascript:this.className = 'TableImgTopCellnoImgHL';" onmouseout="javascript:this.className = 'TableImgTopCellnoImg';" onclick="ItmLstRow_Click('./psearch.asp?FAM=sleevebearings&FT_158=168168&FT_101=3902&FT_9208=319915&FT_135=631&FT_1019=40255&session=desc=Bushings;sleevebearings;158=168168;101=3902;9208=319915;135=631;1019=40255');" vAlign=top width="33%" align=left>SAE 841 Bronze Also called Oilite®, the oil in this porous material reduces wear. </TD><TD class=TableImgTopCellnoImg onmouseover="javascript:this.className = 'TableImgTopCellnoImgHL';" onmouseout="javascript:this.className = 'TableImgTopCellnoImg';" onclick="ItmLstRow_Click('./psearch.asp?FAM=sleevebearings&FT_158=168168&FT_101=3902&FT_9208=319915&FT_135=631&FT_1019=325162&session=desc=Bushings;sleevebearings;158=168168;101=3902;9208=319915;135=631;1019=325162');" vAlign=top width="33%" align=left>Graphite SAE 841 Bronze This porous material is impregnated with a graphite-based material, which provides low-friction dry lubrication in a wide range of temperatures. </TD></TR><TR><TD class=TableImgTopCellnoImg onmouseover="javascript:this.className = 'TableImgTopCellnoImgHL';" onmouseout="javascript:this.className = 'TableImgTopCellnoImg';" onclick="ItmLstRow_Click('./psearch.asp?FAM=sleevebearings&FT_158=168168&FT_101=3902&FT_9208=319915&FT_135=631&FT_1019=325166&session=desc=Bushings;sleevebearings;158=168168;101=3902;9208=319915;135=631;1019=325166');" vAlign=top width="33%" align=left>PTFE/Oil-Lubricated SAE 841 Bronze To provide extra-slippery performance, these SAE 841 bearings are impregnated with oil that has slick PTFE particles. The oil acts as a cushion between the bearings and your shafts to add wear and shock resistance. </TD><TD class=TableImgTopCellnoImg onmouseover="javascript:this.className = 'TableImgTopCellnoImgHL';" onmouseout="javascript:this.className = 'TableImgTopCellnoImg';" onclick="ItmLstRow_Click('./psearch.asp?FAM=sleevebearings&FT_158=168168&FT_101=3902&FT_9208=319915&FT_135=631&FT_1019=168298&session=desc=Bushings;sleevebearings;158=168168;101=3902;9208=319915;135=631;1019=168298');" vAlign=top width="33%" align=left>SAE 863 Bronze Also called Super Oilite®, this material is similar to SAE 841 but contains more iron for greater strength. Color is silver because of the iron. </TD><TD class=TableImgTopCellnoImg onmouseover="javascript:this.className = 'TableImgTopCellnoImgHL';" onmouseout="javascript:this.className = 'TableImgTopCellnoImg';" onclick="ItmLstRow_Click('./psearch.asp?FAM=sleevebearings&FT_158=168168&FT_101=3902&FT_9208=319915&FT_135=631&FT_1019=168269&session=desc=Bushings;sleevebearings;158=168168;101=3902;9208=319915;135=631;1019=168269');" vAlign=top width="33%" align=left>Steel-Backed PTFE-Coated Bronze A steel shell adds strength to this self-lubricating material. Consist of a bronze lining coated with a thin layer of low-friction PTFE. Resists corrosion and water absorption and are electrically conductive. Have the highest load capacity of metal-backed bearings and are well suited for rotary and oscillating motion. </TD></TR></TBODY></TABLE></TD></TR><TR><TD class=featureHeadCell>Length</TD></TR><TR><TD class=featureCell><TABLE cellSpacing=0 cellPadding=0><TBODY><TR><TD class=ListFeatureImageCell></TD><TD class=ListCell><NOBR>1/2"</NOBR> | <NOBR>5/8"</NOBR> | <NOBR>3/4"</NOBR> | <NOBR>1"</NOBR> | <NOBR>1-1/4"</NOBR> | <NOBR>1-1/2"</NOBR> | <NOBR>3"</NOBR> </TD></TR></TBODY></TABLE></TD></TR><TR><TD class=featureHeadCell><TABLE cellSpacing=0 cellPadding=0><TBODY><TR><TD>Performance — Selecting the right bearing</TD></TR></TBODY></TABLE></TD></TR><TR><TD><TABLE class=mfcTable><TBODY><TR><TD class=mfcFeatureCell>Load (P Max) 1,600 2,000 4,000 20,000 </TD><TD class=mfcFeatureCell>Speed (V Max) 225 750 1,000 1,200 </TD><TD class=mfcFeatureCell>Load at Speed (PV Max) 35,000 40,000 50,000 75,000 </TD></TR></TBODY></TABLE></TD></TR><TR><TD class=featureHeadCell><TABLE cellSpacing=0 cellPadding=0><TBODY><TR><TD>Operating Temperature</TD></TR></TBODY></TABLE>Select the level of low and high temperature resistance that best approximates your need. Before purchasing a product, verify that the operating temperature range is suitable for your application. These selections are meant only as a general guide. </TD></TR><TR><TD><TABLE class=mfcTable><TBODY><TR><TD class=mfcFeatureCell>Lowest Temperature Range 0° to +10° F -99° to -1° F -399° to -300° F </TD><TD class=mfcFeatureCell>Highest Temperature Range +201° to +300° F +401° to +500° F +501° to +600° F +601° to +700° F </TD></TR></TBODY></TABLE></TD></TR></TBODY></TABLE> These 29 products match your selections <TABLE style="WIDTH: 445px" id=ItemListTable cellSpacing=0 cellPadding=0><TBODY><TR style="POSITION: absolute; TOP: 1193px; LEFT: 11px" id=HeaderRow class=ListHeadRow><TD style="BORDER-LEFT: #ffffff 0px solid; WIDTH: 46px" class=ListHeadCell onmouseover="this.className = 'ListHeadCellHL';" onmouseout="this.className = 'ListHeadCell';" onclick="javascript:sortTable(136,'ASC',1);">Length</TD><TD style="WIDTH: 46px" class=ListHeadCell onmouseover="this.className = 'ListHeadCellHL';" onmouseout="this.className = 'ListHeadCell';" onclick="javascript:sortTable(3938,'ASC',1);">Load (P Max)</TD><TD style="WIDTH: 40px" class=ListHeadCell onmouseover="this.className = 'ListHeadCellHL';" onmouseout="this.className = 'ListHeadCell';" onclick="javascript:sortTable(3939,'ASC',1);">Speed (V Max)</TD><TD style="WIDTH: 46px" class=ListHeadCell onmouseover="this.className = 'ListHeadCellHL';" onmouseout="this.className = 'ListHeadCell';" onclick="javascript:sortTable(3941,'ASC',1);">Load at Speed (PV Max)</TD><TD style="WIDTH: 106px" class=ListHeadCell onmouseover="this.className = 'ListHeadCellHL';" onmouseout="this.className = 'ListHeadCell';" onclick="javascript:sortTable(1266,'ASC',1);">Temperature Range</TD><TD id=PartNumberHeadCell onmouseover="this.className = 'ListHeadCellHL'" onmouseout="this.className = 'ListHeadCell'" onclick="javascript:sortTable('PN','ASC',1);"></TD><TD id=PriceHeadCell onmouseover="this.className = 'ListHeadCellHL_prc'" onmouseout="this.className = 'ListHeadCell_prc'" onclick="javascript:sortTable('PRC','ASC',1);"><NOBR>Each </NOBR></TD></TR><TR style="BORDER-BOTTOM: #999999 1px solid" class=ItemListGroupHeadRow><TD colSpan=11>Alloy 932 (SAE 660) Bronze </TD></TR><TR class=ItemListRow onmouseover="this.className = 'ItemListRowHL';" onmouseout="this.className = 'ItemListRow';" onclick="ItmLstRow_Click('psearch.asp?FAM=sleevebearings&FT_158=168168&FT_101=3902&FT_9208=319915&FT_135=631&FT_1019=154363&FT_555=325244&FT_424=64442&FT_136=2864&FT_719=43621&FT_3938=171788&FT_3939=171795&FT_3941=171855&FT_3994=266636&FT_3995=266630&FT_1266=325165&ppe=29&session=desc=Bushings;sleevebearings;158=168168;101=3902;9208=319915;135=631;M;I');"><TD style="PADDING-LEFT: 9px">1/2"</TD><TD>4,000</TD><TD>750</TD><TD>75,000</TD><TD>-350° to +450° F</TD><TD class=PartNumberCell>6381K546</TD><TD class=PriceCell><NOBR>$4.99</NOBR> </TD></TR><TR class=ItemListRow onmouseover="this.className = 'ItemListRowHL';" onmouseout="this.className = 'ItemListRow';" onclick="ItmLstRow_Click('psearch.asp?FAM=sleevebearings&FT_158=168168&FT_101=3902&FT_9208=319915&FT_135=631&FT_1019=154363&FT_555=325244&FT_424=64442&FT_136=3059&FT_719=43621&FT_3938=171788&FT_3939=171795&FT_3941=171855&FT_3994=266636&FT_3995=266630&FT_1266=325165&ppe=29&session=desc=Bushings;sleevebearings;158=168168;101=3902;9208=319915;135=631;M;I');"><TD style="PADDING-LEFT: 9px">5/8"</TD><TD>4,000</TD><TD>750</TD><TD>75,000</TD><TD>-350° to +450° F</TD><TD class=PartNumberCell>6381K547</TD><TD class=PriceCell><NOBR>5.24</NOBR> </TD></TR><TR class=ItemListRow onmouseover="this.className = 'ItemListRowHL';" onmouseout="this.className = 'ItemListRow';" onclick="ItmLstRow_Click('psearch.asp?FAM=sleevebearings&FT_158=168168&FT_101=3902&FT_9208=319915&FT_135=631&FT_1019=154363&FT_555=325244&FT_424=64442&FT_136=977&FT_719=43621&FT_3938=171788&FT_3939=171795&FT_3941=171855&FT_3994=266636&FT_3995=266630&FT_1266=325165&ppe=29&session=desc=Bushings;sleevebearings;158=168168;101=3902;9208=319915;135=631;M;I');"><TD style="PADDING-LEFT: 9px">3/4"</TD><TD>4,000</TD><TD>750</TD><TD>75,000</TD><TD>-350° to +450° F</TD><TD class=PartNumberCell>6381K548</TD><TD class=PriceCell><NOBR>2.03</NOBR> </TD></TR><TR class=ItemListRow onmouseover="this.className = 'ItemListRowHL';" onmouseout="this.className = 'ItemListRow';" onclick="ItmLstRow_Click('psearch.asp?FAM=sleevebearings&FT_158=168168&FT_101=3902&FT_9208=319915&FT_135=631&FT_1019=154363&FT_555=325244&FT_424=64442&FT_136=980&FT_719=43621&FT_3938=171788&FT_3939=171795&FT_3941=171855&FT_3994=266636&FT_3995=266630&FT_1266=325165&ppe=29&session=desc=Bushings;sleevebearings;158=168168;101=3902;9208=319915;135=631;M;I');"><TD style="PADDING-LEFT: 9px">1"</TD><TD>4,000</TD><TD>750</TD><TD>75,000</TD><TD>-350° to +450° F</TD><TD class=PartNumberCell>6381K171</TD><TD class=PriceCell><NOBR>2.48</NOBR> </TD></TR><TR class=ItemListRow onmouseover="this.className = 'ItemListRowHL';" onmouseout="this.className = 'ItemListRow';" onclick="ItmLstRow_Click('psearch.asp?FAM=sleevebearings&FT_158=168168&FT_101=3902&FT_9208=319915&FT_135=631&FT_1019=154363&FT_555=325244&FT_424=64442&FT_136=2865&FT_719=43621&FT_3938=171788&FT_3939=171795&FT_3941=171855&FT_3994=266636&FT_3995=266630&FT_1266=325165&ppe=29&session=desc=Bushings;sleevebearings;158=168168;101=3902;9208=319915;135=631;M;I');"><TD style="PADDING-LEFT: 9px">1-1/4"</TD><TD>4,000</TD><TD>750</TD><TD>75,000</TD><TD>-350° to +450° F</TD><TD class=PartNumberCell>6381K55</TD><TD class=PriceCell><NOBR>2.67</NOBR> </TD></TR><TR class=ItemListRow onmouseover="this.className = 'ItemListRowHL';" onmouseout="this.className = 'ItemListRow';" onclick="ItmLstRow_Click('psearch.asp?FAM=sleevebearings&FT_158=168168&FT_101=3902&FT_9208=319915&FT_135=631&FT_1019=154363&FT_555=325244&FT_424=64442&FT_136=987&FT_719=43621&FT_3938=171788&FT_3939=171795&FT_3941=171855&FT_3994=266636&FT_3995=266630&FT_1266=325165&ppe=29&session=desc=Bushings;sleevebearings;158=168168;101=3902;9208=319915;135=631;M;I');"><TD style="PADDING-LEFT: 9px">1-1/2"</TD><TD>4,000</TD><TD>750</TD><TD>75,000</TD><TD>-350° to +450° F</TD><TD class=PartNumberCell>6381K549</TD><TD class=PriceCell><NOBR>3.07</NOBR> </TD></TR><TR class=ItemListRow onmouseover="this.className = 'ItemListRowHL';" onmouseout="this.className = 'ItemListRow';" onclick="ItmLstRow_Click('psearch.asp?FAM=sleevebearings&FT_158=168168&FT_101=3902&FT_9208=319915&FT_135=631&FT_1019=154363&FT_555=325244&FT_424=64442&FT_136=994&FT_719=43621&FT_3938=171788&FT_3939=171795&FT_3941=171855&FT_3994=266636&FT_3995=266630&FT_1266=325165&ppe=29&session=desc=Bushings;sleevebearings;158=168168;101=3902;9208=319915;135=631;M;I');"><TD style="PADDING-LEFT: 9px; BORDER-BOTTOM-WIDTH: 0px">3"</TD><TD style="BORDER-BOTTOM-WIDTH: 0px">4,000</TD><TD style="BORDER-BOTTOM-WIDTH: 0px">750</TD><TD style="BORDER-BOTTOM-WIDTH: 0px">75,000</TD><TD style="BORDER-BOTTOM-WIDTH: 0px">-350° to +450° F</TD><TD style="BORDER-BOTTOM-WIDTH: 0px" class=PartNumberCell>6381K11</TD><TD style="BORDER-BOTTOM-WIDTH: 0px" class=PriceCell><NOBR>13.74</NOBR> </TD></TR><TR style="BORDER-BOTTOM: #999999 1px solid" class=ItemListGroupHeadRow><TD colSpan=11>SAE 841 Bronze </TD></TR><TR class=ItemListRow onmouseover="this.className = 'ItemListRowHL';" onmouseout="this.className = 'ItemListRow';" onclick="ItmLstRow_Click('psearch.asp?FAM=sleevebearings&FT_158=168168&FT_101=3902&FT_9208=319915&FT_135=631&FT_1019=40255&FT_555=325224&FT_424=64442&FT_136=2864&FT_719=43621&FT_3938=171779&FT_3939=171801&FT_3941=171852&FT_3994=266624&FT_3995=266626&FT_1266=168291&ppe=29&session=desc=Bushings;sleevebearings;158=168168;101=3902;9208=319915;135=631;M;I');"><TD style="PADDING-LEFT: 9px">1/2"</TD><TD>2,000</TD><TD>1,200</TD><TD>50,000</TD><TD>+10° to +220° F</TD><TD class=PartNumberCell>6391K256</TD><TD class=PriceCell><NOBR>$1.13</NOBR> </TD></TR><TR class=ItemListRow onmouseover="this.className = 'ItemListRowHL';" onmouseout="this.className = 'ItemListRow';" onclick="ItmLstRow_Click('psearch.asp?FAM=sleevebearings&FT_158=168168&FT_101=3902&FT_9208=319915&FT_135=631&FT_1019=40255&FT_555=325224&FT_424=64442&FT_136=3059&FT_719=43621&FT_3938=171779&FT_3939=171801&FT_3941=171852&FT_3994=266624&FT_3995=266626&FT_1266=168291&ppe=29&session=desc=Bushings;sleevebearings;158=168168;101=3902;9208=319915;135=631;M;I');"><TD style="PADDING-LEFT: 9px">5/8"</TD><TD>2,000</TD><TD>1,200</TD><TD>50,000</TD><TD>+10° to +220° F</TD><TD class=PartNumberCell>6391K257</TD><TD class=PriceCell><NOBR>1.00</NOBR> </TD></TR><TR class=ItemListRow onmouseover="this.className = 'ItemListRowHL';" onmouseout="this.className = 'ItemListRow';" onclick="ItmLstRow_Click('psearch.asp?FAM=sleevebearings&FT_158=168168&FT_101=3902&FT_9208=319915&FT_135=631&FT_1019=40255&FT_555=325224&FT_424=64442&FT_136=977&FT_719=43621&FT_3938=171779&FT_3939=171801&FT_3941=171852&FT_3994=266624&FT_3995=266626&FT_1266=168291&ppe=29&session=desc=Bushings;sleevebearings;158=168168;101=3902;9208=319915;135=631;M;I');"><TD style="PADDING-LEFT: 9px">3/4"</TD><TD>2,000</TD><TD>1,200</TD><TD>50,000</TD><TD>+10° to +220° F</TD><TD class=PartNumberCell>6391K258</TD><TD class=PriceCell><NOBR>1.14</NOBR> </TD></TR><TR class=ItemListRow onmouseover="this.className = 'ItemListRowHL';" onmouseout="this.className = 'ItemListRow';" onclick="ItmLstRow_Click('psearch.asp?FAM=sleevebearings&FT_158=168168&FT_101=3902&FT_9208=319915&FT_135=631&FT_1019=40255&FT_555=325224&FT_424=64442&FT_136=980&FT_719=43621&FT_3938=171779&FT_3939=171801&FT_3941=171852&FT_3994=266624&FT_3995=266626&FT_1266=168291&ppe=29&session=desc=Bushings;sleevebearings;158=168168;101=3902;9208=319915;135=631;M;I');"><TD style="PADDING-LEFT: 9px">1"</TD><TD>2,000</TD><TD>1,200</TD><TD>50,000</TD><TD>+10° to +220° F</TD><TD class=PartNumberCell>6391K259</TD><TD class=PriceCell><NOBR>1.50</NOBR> </TD></TR><TR class=ItemListRow onmouseover="this.className = 'ItemListRowHL';" onmouseout="this.className = 'ItemListRow';" onclick="ItmLstRow_Click('psearch.asp?FAM=sleevebearings&FT_158=168168&FT_101=3902&FT_9208=319915&FT_135=631&FT_1019=40255&FT_555=325224&FT_424=64442&FT_136=2865&FT_719=43621&FT_3938=171779&FT_3939=171801&FT_3941=171852&FT_3994=266624&FT_3995=266626&FT_1266=168291&ppe=29&session=desc=Bushings;sleevebearings;158=168168;101=3902;9208=319915;135=631;M;I');"><TD style="PADDING-LEFT: 9px">1-1/4"</TD><TD>2,000</TD><TD>1,200</TD><TD>50,000</TD><TD>+10° to +220° F</TD><TD class=PartNumberCell>6391K208</TD><TD class=PriceCell><NOBR>2.33</NOBR> </TD></TR><TR class=ItemListRow onmouseover="this.className = 'ItemListRowHL';" onmouseout="this.className = 'ItemListRow';" onclick="ItmLstRow_Click('psearch.asp?FAM=sleevebearings&FT_158=168168&FT_101=3902&FT_9208=319915&FT_135=631&FT_1019=40255&FT_555=325224&FT_424=64442&FT_136=987&FT_719=43621&FT_3938=171779&FT_3939=171801&FT_3941=171852&FT_3994=266624&FT_3995=266626&FT_1266=168291&ppe=29&session=desc=Bushings;sleevebearings;158=168168;101=3902;9208=319915;135=631;M;I');"><TD style="PADDING-LEFT: 9px">1-1/2"</TD><TD>2,000</TD><TD>1,200</TD><TD>50,000</TD><TD>+10° to +220° F</TD><TD class=PartNumberCell>6391K207</TD><TD class=PriceCell><NOBR>1.63</NOBR> </TD></TR><TR class=ItemListRow onmouseover="this.className = 'ItemListRowHL';" onmouseout="this.className = 'ItemListRow';" onclick="ItmLstRow_Click('psearch.asp?FAM=sleevebearings&FT_158=168168&FT_101=3902&FT_9208=319915&FT_135=631&FT_1019=40255&FT_555=325224&FT_424=64442&FT_136=994&FT_719=325222&FT_3938=171779&FT_3939=171801&FT_3941=171852&FT_3994=266624&FT_3995=266626&FT_1266=168291&ppe=29&session=desc=Bushings;sleevebearings;158=168168;101=3902;9208=319915;135=631;M;I');"><TD style="PADDING-LEFT: 9px; BORDER-BOTTOM-WIDTH: 0px">3"</TD><TD style="BORDER-BOTTOM-WIDTH: 0px">2,000</TD><TD style="BORDER-BOTTOM-WIDTH: 0px">1,200</TD><TD style="BORDER-BOTTOM-WIDTH: 0px">50,000</TD><TD style="BORDER-BOTTOM-WIDTH: 0px">+10° to +220° F</TD><TD style="BORDER-BOTTOM-WIDTH: 0px" class=PartNumberCell>6391K11</TD><TD style="BORDER-BOTTOM-WIDTH: 0px" class=PriceCell><NOBR>23.26</NOBR> </TD></TR><TR style="BORDER-BOTTOM: #999999 1px solid" class=ItemListGroupHeadRow><TD colSpan=11>Graphite SAE 841 Bronze </TD></TR><TR class=ItemListRow onmouseover="this.className = 'ItemListRowHL';" onmouseout="this.className = 'ItemListRow';" onclick="ItmLstRow_Click('psearch.asp?FAM=sleevebearings&FT_158=168168&FT_101=3902&FT_9208=319915&FT_135=631&FT_1019=325162&FT_555=325205&FT_424=328575&FT_136=2864&FT_719=43621&FT_3938=325171&FT_3939=171798&FT_3941=325176&FT_3994=266625&FT_3995=266634&FT_1266=204169&ppe=29&session=desc=Bushings;sleevebearings;158=168168;101=3902;9208=319915;135=631;M;I');"><TD style="PADDING-LEFT: 9px">1/2"</TD><TD>1,600</TD><TD>1,000</TD><TD>40,000</TD><TD>-30° to +700° F</TD><TD class=PartNumberCell>9368T71</TD><TD class=PriceCell><NOBR>$1.02</NOBR> </TD></TR><TR class=ItemListRow onmouseover="this.className = 'ItemListRowHL';" onmouseout="this.className = 'ItemListRow';" onclick="ItmLstRow_Click('psearch.asp?FAM=sleevebearings&FT_158=168168&FT_101=3902&FT_9208=319915&FT_135=631&FT_1019=325162&FT_555=325205&FT_424=328575&FT_136=3059&FT_719=43621&FT_3938=325171&FT_3939=171798&FT_3941=325176&FT_3994=266625&FT_3995=266634&FT_1266=204169&ppe=29&session=desc=Bushings;sleevebearings;158=168168;101=3902;9208=319915;135=631;M;I');"><TD style="PADDING-LEFT: 9px">5/8"</TD><TD>1,600</TD><TD>1,000</TD><TD>40,000</TD><TD>-30° to +700° F</TD><TD class=PartNumberCell>9368T187</TD><TD class=PriceCell><NOBR>1.23</NOBR> </TD></TR><TR class=ItemListRow onmouseover="this.className = 'ItemListRowHL';" onmouseout="this.className = 'ItemListRow';" onclick="ItmLstRow_Click('psearch.asp?FAM=sleevebearings&FT_158=168168&FT_101=3902&FT_9208=319915&FT_135=631&FT_1019=325162&FT_555=325205&FT_424=328575&FT_136=977&FT_719=43621&FT_3938=325171&FT_3939=171798&FT_3941=325176&FT_3994=266625&FT_3995=266634&FT_1266=204169&ppe=29&session=desc=Bushings;sleevebearings;158=168168;101=3902;9208=319915;135=631;M;I');"><TD style="PADDING-LEFT: 9px">3/4"</TD><TD>1,600</TD><TD>1,000</TD><TD>40,000</TD><TD>-30° to +700° F</TD><TD class=PartNumberCell>9368T72</TD><TD class=PriceCell><NOBR>1.36</NOBR> </TD></TR><TR class=ItemListRow onmouseover="this.className = 'ItemListRowHL';" onmouseout="this.className = 'ItemListRow';" onclick="ItmLstRow_Click('psearch.asp?FAM=sleevebearings&FT_158=168168&FT_101=3902&FT_9208=319915&FT_135=631&FT_1019=325162&FT_555=325205&FT_424=328575&FT_136=980&FT_719=43621&FT_3938=325171&FT_3939=171798&FT_3941=325176&FT_3994=266625&FT_3995=266634&FT_1266=204169&ppe=29&session=desc=Bushings;sleevebearings;158=168168;101=3902;9208=319915;135=631;M;I');"><TD style="PADDING-LEFT: 9px">1"</TD><TD>1,600</TD><TD>1,000</TD><TD>40,000</TD><TD>-30° to +700° F</TD><TD class=PartNumberCell>9368T73</TD><TD class=PriceCell><NOBR>1.61</NOBR> </TD></TR><TR class=ItemListRow onmouseover="this.className = 'ItemListRowHL';" onmouseout="this.className = 'ItemListRow';" onclick="ItmLstRow_Click('psearch.asp?FAM=sleevebearings&FT_158=168168&FT_101=3902&FT_9208=319915&FT_135=631&FT_1019=325162&FT_555=325205&FT_424=328575&FT_136=2865&FT_719=43621&FT_3938=325171&FT_3939=171798&FT_3941=325176&FT_3994=266625&FT_3995=266634&FT_1266=204169&ppe=29&session=desc=Bushings;sleevebearings;158=168168;101=3902;9208=319915;135=631;M;I');"><TD style="PADDING-LEFT: 9px">1-1/4"</TD><TD>1,600</TD><TD>1,000</TD><TD>40,000</TD><TD>-30° to +700° F</TD><TD class=PartNumberCell>9368T188</TD><TD class=PriceCell><NOBR>2.10</NOBR> </TD></TR><TR class=ItemListRow onmouseover="this.className = 'ItemListRowHL';" onmouseout="this.className = 'ItemListRow';" onclick="ItmLstRow_Click('psearch.asp?FAM=sleevebearings&FT_158=168168&FT_101=3902&FT_9208=319915&FT_135=631&FT_1019=325162&FT_555=325205&FT_424=328575&FT_136=987&FT_719=325222&FT_3938=325171&FT_3939=171798&FT_3941=325176&FT_3994=266625&FT_3995=266634&FT_1266=204169&ppe=29&session=desc=Bushings;sleevebearings;158=168168;101=3902;9208=319915;135=631;M;I');"><TD style="PADDING-LEFT: 9px; BORDER-BOTTOM-WIDTH: 0px">1-1/2"</TD><TD style="BORDER-BOTTOM-WIDTH: 0px">1,600</TD><TD style="BORDER-BOTTOM-WIDTH: 0px">1,000</TD><TD style="BORDER-BOTTOM-WIDTH: 0px">40,000</TD><TD style="BORDER-BOTTOM-WIDTH: 0px">-30° to +700° F</TD><TD style="BORDER-BOTTOM-WIDTH: 0px" class=PartNumberCell>9368T189</TD><TD style="BORDER-BOTTOM-WIDTH: 0px" class=PriceCell><NOBR>2.97</NOBR> </TD></TR><TR style="BORDER-BOTTOM: #999999 1px solid" class=ItemListGroupHeadRow><TD colSpan=11>PTFE/Oil-Lubricated SAE 841 Bronze </TD></TR><TR class=ItemListRow onmouseover="this.className = 'ItemListRowHL';" onmouseout="this.className = 'ItemListRow';" onclick="ItmLstRow_Click('psearch.asp?FAM=sleevebearings&FT_158=168168&FT_101=3902&FT_9208=319915&FT_135=631&FT_1019=325166&FT_555=325207&FT_424=325249&FT_136=980&FT_719=43621&FT_3938=171779&FT_3939=171801&FT_3941=171852&FT_3994=266624&FT_3995=266626&FT_1266=168291&ppe=29&session=desc=Bushings;sleevebearings;158=168168;101=3902;9208=319915;135=631;M;I');"><TD style="PADDING-LEFT: 9px; BORDER-BOTTOM-WIDTH: 0px">1"</TD><TD style="BORDER-BOTTOM-WIDTH: 0px">2,000</TD><TD style="BORDER-BOTTOM-WIDTH: 0px">1,200</TD><TD style="BORDER-BOTTOM-WIDTH: 0px">50,000</TD><TD style="BORDER-BOTTOM-WIDTH: 0px">+10° to +220° F</TD><TD style="BORDER-BOTTOM-WIDTH: 0px" class=PartNumberCell>1688K25</TD><TD style="BORDER-BOTTOM-WIDTH: 0px" class=PriceCell><NOBR>$1.20</NOBR> </TD></TR><TR style="BORDER-BOTTOM: #999999 1px solid" class=ItemListGroupHeadRow><TD colSpan=11>SAE 863 Bronze </TD></TR><TR class=ItemListRow onmouseover="this.className = 'ItemListRowHL';" onmouseout="this.className = 'ItemListRow';" onclick="ItmLstRow_Click('psearch.asp?FAM=sleevebearings&FT_158=168168&FT_101=3902&FT_9208=319915&FT_135=631&FT_1019=168298&FT_555=325224&FT_424=64442&FT_136=2864&FT_719=30215&FT_3938=171788&FT_3939=171771&FT_3941=171850&FT_3994=266624&FT_3995=266626&FT_1266=168291&ppe=29&session=desc=Bushings;sleevebearings;158=168168;101=3902;9208=319915;135=631;M;I');"><TD style="PADDING-LEFT: 9px">1/2"</TD><TD>4,000</TD><TD>225</TD><TD>35,000</TD><TD>+10° to +220° F</TD><TD class=PartNumberCell>2868T167</TD><TD class=PriceCell><NOBR>$1.22</NOBR> </TD></TR><TR class=ItemListRow onmouseover="this.className = 'ItemListRowHL';" onmouseout="this.className = 'ItemListRow';" onclick="ItmLstRow_Click('psearch.asp?FAM=sleevebearings&FT_158=168168&FT_101=3902&FT_9208=319915&FT_135=631&FT_1019=168298&FT_555=325224&FT_424=64442&FT_136=3059&FT_719=30215&FT_3938=171788&FT_3939=171771&FT_3941=171850&FT_3994=266624&FT_3995=266626&FT_1266=168291&ppe=29&session=desc=Bushings;sleevebearings;158=168168;101=3902;9208=319915;135=631;M;I');"><TD style="PADDING-LEFT: 9px">5/8"</TD><TD>4,000</TD><TD>225</TD><TD>35,000</TD><TD>+10° to +220° F</TD><TD class=PartNumberCell>2868T168</TD><TD class=PriceCell><NOBR>1.23</NOBR> </TD></TR><TR class=ItemListRow onmouseover="this.className = 'ItemListRowHL';" onmouseout="this.className = 'ItemListRow';" onclick="ItmLstRow_Click('psearch.asp?FAM=sleevebearings&FT_158=168168&FT_101=3902&FT_9208=319915&FT_135=631&FT_1019=168298&FT_555=325224&FT_424=64442&FT_136=977&FT_719=30215&FT_3938=171788&FT_3939=171771&FT_3941=171850&FT_3994=266624&FT_3995=266626&FT_1266=168291&ppe=29&session=desc=Bushings;sleevebearings;158=168168;101=3902;9208=319915;135=631;M;I');"><TD style="PADDING-LEFT: 9px">3/4"</TD><TD>4,000</TD><TD>225</TD><TD>35,000</TD><TD>+10° to +220° F</TD><TD class=PartNumberCell>2868T169</TD><TD class=PriceCell><NOBR>1.22</NOBR> </TD></TR><TR class=ItemListRow onmouseover="this.className = 'ItemListRowHL';" onmouseout="this.className = 'ItemListRow';" onclick="ItmLstRow_Click('psearch.asp?FAM=sleevebearings&FT_158=168168&FT_101=3902&FT_9208=319915&FT_135=631&FT_1019=168298&FT_555=325224&FT_424=64442&FT_136=980&FT_719=30215&FT_3938=171788&FT_3939=171771&FT_3941=171850&FT_3994=266624&FT_3995=266626&FT_1266=168291&ppe=29&session=desc=Bushings;sleevebearings;158=168168;101=3902;9208=319915;135=631;M;I');"><TD style="PADDING-LEFT: 9px">1"</TD><TD>4,000</TD><TD>225</TD><TD>35,000</TD><TD>+10° to +220° F</TD><TD class=PartNumberCell>2868T171</TD><TD class=PriceCell><NOBR>1.76</NOBR> </TD></TR><TR class=ItemListRow onmouseover="this.className = 'ItemListRowHL';" onmouseout="this.className = 'ItemListRow';" onclick="ItmLstRow_Click('psearch.asp?FAM=sleevebearings&FT_158=168168&FT_101=3902&FT_9208=319915&FT_135=631&FT_1019=168298&FT_555=325224&FT_424=64442&FT_136=2865&FT_719=30215&FT_3938=171788&FT_3939=171771&FT_3941=171850&FT_3994=266624&FT_3995=266626&FT_1266=168291&ppe=29&session=desc=Bushings;sleevebearings;158=168168;101=3902;9208=319915;135=631;M;I');"><TD style="PADDING-LEFT: 9px">1-1/4"</TD><TD>4,000</TD><TD>225</TD><TD>35,000</TD><TD>+10° to +220° F</TD><TD class=PartNumberCell>2868T172</TD><TD class=PriceCell><NOBR>2.40</NOBR> </TD></TR><TR class=ItemListRow onmouseover="this.className = 'ItemListRowHL';" onmouseout="this.className = 'ItemListRow';" onclick="ItmLstRow_Click('psearch.asp?FAM=sleevebearings&FT_158=168168&FT_101=3902&FT_9208=319915&FT_135=631&FT_1019=168298&FT_555=325224&FT_424=64442&FT_136=987&FT_719=30215&FT_3938=171788&FT_3939=171771&FT_3941=171850&FT_3994=266624&FT_3995=266626&FT_1266=168291&ppe=29&session=desc=Bushings;sleevebearings;158=168168;101=3902;9208=319915;135=631;M;I');"><TD style="PADDING-LEFT: 9px">1-1/2"</TD><TD>4,000</TD><TD>225</TD><TD>35,000</TD><TD>+10° to +220° F</TD><TD class=PartNumberCell>2868T173</TD><TD class=PriceCell><NOBR>2.54</NOBR> </TD></TR><TR class=ItemListRow onmouseover="this.className = 'ItemListRowHL';" onmouseout="this.className = 'ItemListRow';" onclick="ItmLstRow_Click('psearch.asp?FAM=sleevebearings&FT_158=168168&FT_101=3902&FT_9208=319915&FT_135=631&FT_1019=168298&FT_555=325224&FT_424=64442&FT_136=994&FT_719=43697&FT_3938=171788&FT_3939=171771&FT_3941=171850&FT_3994=266624&FT_3995=266626&FT_1266=168291&ppe=29&session=desc=Bushings;sleevebearings;158=168168;101=3902;9208=319915;135=631;M;I');"><TD style="PADDING-LEFT: 9px; BORDER-BOTTOM-WIDTH: 0px">3"</TD><TD style="BORDER-BOTTOM-WIDTH: 0px">4,000</TD><TD style="BORDER-BOTTOM-WIDTH: 0px">225</TD><TD style="BORDER-BOTTOM-WIDTH: 0px">35,000</TD><TD style="BORDER-BOTTOM-WIDTH: 0px">+10° to +220° F</TD><TD style="BORDER-BOTTOM-WIDTH: 0px" class=PartNumberCell>2868T174</TD><TD style="BORDER-BOTTOM-WIDTH: 0px" class=PriceCell><NOBR>39.60</NOBR> </TD></TR><TR style="BORDER-BOTTOM: #999999 1px solid" class=ItemListGroupHeadRow><TD colSpan=11>Steel-Backed PTFE-Coated Bronze </TD></TR><TR class=ItemListRow onmouseover="this.className = 'ItemListRowHL';" onmouseout="this.className = 'ItemListRow';" onclick="ItmLstRow_Click('psearch.asp?FAM=sleevebearings&FT_158=168168&FT_101=3902&FT_9208=319915&FT_135=631&FT_1019=168269&FT_555=325408&FT_424=325409&FT_136=980&FT_719=30215&FT_3938=200135&FT_3939=171798&FT_3941=171852&FT_3994=266636&FT_3995=266632&FT_1266=168271&ppe=29&session=desc=Bushings;sleevebearings;158=168168;101=3902;9208=319915;135=631;M;I');"><TD style="PADDING-LEFT: 9px; BORDER-BOTTOM-WIDTH: 0px">1"</TD><TD style="BORDER-BOTTOM-WIDTH: 0px">20,000</TD><TD style="BORDER-BOTTOM-WIDTH: 0px">1,000</TD><TD style="BORDER-BOTTOM-WIDTH: 0px">50,000</TD><TD style="BORDER-BOTTOM-WIDTH: 0px">-328° to +536° F</TD><TD style="BORDER-BOTTOM-WIDTH: 0px" class=PartNumberCell>60695K5</TD><TD style="BORDER-BOTTOM-WIDTH: 0px" class=PriceCell><NOBR>$4.29</NOBR> </TD></TR></TBODY></TABLE>
Looks like you are already hooked up...I was going to suggest turning down a manual transmission pilot bearing. I think 3/4 ID is pretty common.
As far as 3/4" i.d. and 7/8" o.d bronze bushings go, just head down to an Ace hardware store - most of them have them in their container stock. Ace is always an overlooked asset to builders, even in small towns with almost no industrial supply I always seem to find what I need if they have an Ace.
