Need info on SW Tachometer
Discussion in 'The Hokey Ass Message Board' started by Ralph Moore, Jun 18, 2013.
  1. Ralph Moore
    Ralph Moore
    I have a Stewart Warner tach with 765JG4 and insp 1951 stamps on the back.
    I want to use it in my coupe, but I am unsure how to hook it up. It has two terminals on back, both unmarked, and being from 1951 I'm assuming it's 6 volt.
    How would I hook this up to a 12 volt system? Use a voltage reducer?
  2. Ralph Moore
    Ralph Moore
    Anyone delt with this before?
  3. Andy
    Andy
    Pics would help. You may have a tach that used a signal generator.
  4. Ralph Moore
    Ralph Moore
    I'll try to load a picture, for some reason it won't work from my I phone.
  5. It needs a sender.
  6. Canuck
    Canuck
    Sender is required, do not hook up without one.
    For 12V senders, check Stude Hawks in early 60s.
    This one is going into my 30 coupe.
    Canuck
  7. Ralph Moore
    Ralph Moore
    Where does this sender hook up to, the coil? And is there a pos/neg to the terminals?
    Does anyone deal with these senders new or aftermarket? I'm on a different computer, here are pics.
  8. wagoon78
    wagoon78
    Hopefully these photos work. Wiring mine up this week and this is what i found.
  9. alchemy
    alchemy
    Ralph, that's not a 1951 tach. Check the next date for that code.
  10. Ralph Moore
    Ralph Moore
    Thanks that diagram helps alot, I was going by the stamp, SW INSP 1951 as far as the date. Does the part no cross to a certain year?
  11. Canuck
    Canuck
    The sender and wiring diagram poster by Wagoon are for a different model tach.
    The sender for a 765 is a rectangular metal box with the wires coming out of a bedding compound in the bottom. One connection on the side of the box to select 6/8 cyl. Sorry don't have a picture on computer, if I find one will post it.
    Search e-bay and Stude sites using the model number.
    The correct wiring diagram is:
  12. Canuck
    Canuck
  13. alchemy
    alchemy
    The G4 on the end of the paint stamp is the date code. Means April 1963 or 1987 (I'd say the 1963).
    See the chart that I gave Dave Mann here: http://www.roadsters.com/sw/
  14. Ralph Moore
    Ralph Moore
    Yea, I would go with the 63 as well. Good, now I just have to find the box.
  15. Ralph Moore
    Ralph Moore
    Talked to a Studebaker guy here and he referred to Studebaker International, their catalog shows a repop rectangular sender for 62-64 hawks
    Pn 800009. Anyone tried one of these? I wrote them, but they could not cross-reference the SW part number on the tach.
    Sorry Canuck, I just looked at your post again and saw that you posted the link for them earlier. It looks like they have the part I need.
