need info on Dodge flathead 6
Discussion in 'The Hokey Ass Message Board' started by INJUNTOM, Jul 2, 2006.
  1. INJUNTOM
    INJUNTOM
    are there freeze plugs at the rear of the block in the bell housing area?
    if so, are they the same as the plugs on the side of the block?
    the ones on the side of the block are leaking, and i'm sure the ones at the back would be leaking as well.
    Thanks in advance, Tom
  2. INJUNTOM
    INJUNTOM
  3. Bugman
    Bugman
    Dunno. I didnt think to take any pics of the back of my block when it was out. Let me do some more checking around...
  4. i dont recall seeing andy when i had my engine out 2 months ago
  5. Bugman
    Bugman
    Here's a pic I pulled off another forum I belong to. I think the top plug is a freeze plug, the bottom is the cam bore. Anyone agree/disagree?
  6. INJUNTOM
    INJUNTOM
    thanks for the pic.
    what is the other forum?
    is it for early mopars?
    Thanks, Tom
  7. Chuckles Garage
    Chuckles Garage
    Alliance Vendor
    im pretty sure the top is the freeze and the bottom is for the cam. i have one of these motors from a 36 dodge pickup too....if anyone wants it, i'll sell it for free-fifty-free.
  8. Skattruggles
    Skattruggles
    from Dixon, CA
  9. INJUNTOM
    INJUNTOM
    good info :D
    when i poured water into the flatty, i had water running out the plugs in the side of the block, and seemed like a small amount coming from the seam between the block, and trans on the driver's side - i figured there was a plug that is right at the edge of the trans mounting surface of the block....
  10. INJUNTOM
    INJUNTOM
    really sux because i just bought a new carb, and got it running on it's own...put it in gear and moved it back and forth in the yard.
    gotta get it to hold water to be able to run it down the street.
  11. FOURLUG
    FOURLUG
    Yes Bugman is correct, The one at 12 o'clock is a freeze plug and the one at 2 o'clock is for the cam. Unfortunately there is no easy way to get to it with the engine in the car.
    James
