I need a power steering box for a '63 Riviera. Can someone look it up and tell me what interchanges? I have a book, but it only goes back to '65.
#654 #5689662.........59 le sabre w/std trans,late 59 w/at,59 electra 225 w/at,60-63 all except buick special////hope this helps
actually later boxes DO interchange. i don't know specific years, but "later 60s" buicks at least, have a similar box that mounts with 4 bolts instead of three, but otherwise is a direct swap, you just don't use the fourth hole*. i did the swap several years ago so i don't remember what the donor was, but it was some late 60's buick full size car. * the fourth hole hangs below the frame. if you can it would not be a bad idea to fab up a bracket and use it.
