Need help with body flex
Discussion in 'The Hokey Ass Message Board' started by Merc0Matic, Jun 7, 2014.
  1. Merc0Matic
    Merc0Matic
    from california
    I have a 52' mercury two door hardtop no post and the body flexes really bad when turning and the passenger door will swing open. I've adjusted the door and the door catch at least a couple dozen times and it never stays closed. Is there any way to fix this easily? Do I need to weld in braces? I'm at a loss at this point. Thanks
  2. Blue One
    Blue One
    from Alberta
    Sounds to me like you might have a bigger problem like major body structural rust or a frame issue. :eek:
  3. Merc0Matic
    Merc0Matic
    from california
    There's no rust anywhere on the body or frame and what kind of frame problem could there be?
  4. aircoup
    aircoup
    somethings movin under there ,,,,,,,,check closely had a 70,s vette that when put on a rack would flex so badly that the door gaps would open up almost to a half inch , hate to be the bearer of bad news but thats a scary issue look closer ,,,
  5. Merc0Matic
    Merc0Matic
    from california
    Any idea what to look for?
  6. Merc0Matic
    Merc0Matic
    from california
  7. Blue One
    Blue One
    from Alberta
    Broken or loose frame cross members, loose bolts or rivets :confused:
  8. Merc0Matic
    Merc0Matic
    from california
  9. Blue One
    Blue One
    from Alberta
    Maybe loose or broken body mounts ? By the way your car is NOT a uni body car.
    I assure you it has a full frame under it.
  10. T Fritz
    T Fritz
    You could have a body mount rubber that has collapsed under the B-post. The latch/ striker could be worn out.
    Fritz
  11. Merc0Matic
    Merc0Matic
    from california
    Wrong thread my bad and alright thanks I'll definitely take a look
  12. Merc0Matic
    Merc0Matic
    from california
    Brand new door strikes I bought two just to be sure
  13. fordcragar
    fordcragar
    from Yakima WA.
    A 52 Mercury is not a unibody, it has a full frame under it. I would replace the door strikers and latches, check the hinges too (there might be a bunch of slop in them).
  14. Merc0Matic
    Merc0Matic
    from california
    I know it's not a uni body that was supposed to be posted in a different thread
