need help with 50 lincoln windshield in stall
Discussion in 'The Hokey Ass Message Board' started by 50lincolnsport, Jul 15, 2009.
  1. 50lincolnsport
    50lincolnsport
    i have no idea what to do here. do i use a sealant of some sort ? i have the original two piece glass and center bar. i am going to the midnight mass the 25th and need to get it done before so i can drive it on the freeway without eating bugs, i mean i am not scared. i use to have a rock buggy i would drive on the roads at 75 mph. Thanks.
  2. 50lincolnsport
    50lincolnsport
    HELP ! ! ! ! need info glue type ? seals ?
  3. 50lincolnsport
    50lincolnsport
    ok i got a seal from sac vintage ford it is supposed to be for 49-50 mercury and it does not fit it is to big. whats the deal ? any one had any issue's like this before ? thank you ;)
  4. old beet
    old beet
    49-51 Merc and "Baby Lincoln" use the same glass and seal,,,Except Merc station wagon, it is about 2 inches taller?????? Wrong seal?????
  5. blubaja
    blubaja
    from NJ
    I work for an autoglass place. Never done anything before 70's. You prolly have a gasket seal tho. Not too bad to install with a little patience, and finesse. You SHOULD just contact your local autoglass shop and see if they can help you out.
  6. a little soap and a small rope will get it done
