History Need Help to Identify these parts!!
Discussion in 'The Hokey Ass Message Board' started by RodLouvers, Apr 24, 2018.
  1. RodLouvers
    RodLouvers
    Can anyone help to identify these parts.
    One looks like it is a truck step but it says Buick on the tread?? I didn't know Buick made any trucks
    The other is a cast exhaust manifold with cooling ribs cast in.
    I haven't been able to find any info on these anywhere
    Thank you in advance
    Dave
    RodLouvers
    Deuces likes this.
  2. studebakerjoe
    studebakerjoe
    Buick did make trucks in the early years. You can see the steps in this pic. Not a great pic but hope it helps. 151dbc100.jpg
    Squablow, Deuces and Hnstray like this.
  3. Hnstray
    Hnstray
    from Quincy, IL
    The exhaust manifold is from the era that used sheet metal jackets on manifolds to send heated air to the carb to aid in smoother running after a cold start. The fins served to warm the air passing by better than a smooth suface. Sort of like like finned heads on a flathead......better heat transfer.
    The 'banana' shaped manifold is also smog era tech...see the small port...that is for EGR (Ehaust Gas Recirculation) has 6 ports....maybe Ford 240/300 or Mopar
    Deuces likes this.
  4. SR100
    SR100
    Joe & Stray beat me to it. Try googling the number on the manifold to find the make.
    Deuces likes this.
  5. RodLouvers
    RodLouvers
    Wow Thank you for the quick response and the pic....
  6. Deuces
    Deuces
    Very cool!..... :cool:
  7. RodLouvers
    RodLouvers
    I can't find any part numbers on the manifold hoping someone might recognize it
  8. Those same kind of steps were also on buggies, not sure if Buick made buggies.
    Probably early car or truck access steps.
    I think Hnstray has the manifold figured out.
  9. RodLouvers
    RodLouvers
    I found the numbers...still can't find it thanks
  10. egads
    egads
    Same manifold in all 4 pictures? That's not a late model smog manifold. Early high end car's had porcelain coating on the exhaust, {teen's, twenty's and thirty's) Might want to ask over on the aaca site.
  11. Hnstray
    Hnstray
    from Quincy, IL
    Good catch on the porcelain......I missed that....:oops:
    Ray
  12. Squablow
    Squablow
    So..., didn't feel like posting the numbers that you found?
  13. RodLouvers
    RodLouvers
    Sorry the number is 29205
