Technical Need help to ID leaf spring supplier.
Discussion in 'The Hokey Ass Message Board' started by Ralph Moore, May 27, 2019.
  1. Ralph Moore
    Ralph Moore
    I just had a good friend give me a pair of leaf springs marked 35 to 48. He gave them to me as I plan on putting parallel leaves on my 35 coupe. But I have none of the frame mounting brackets to install the springs. If I knew who made them I might know where to go for the kit. One end has a bushing, the other does not, and the only markings I can find is on the Spring clamps it says Betts.
    Now the Internet tells me Betts is a spring manufacturer[​IMG], but I’m sure these were part of someone’s kit. They also have anti-squeak pads built-in. [​IMG][​IMG]
  2. 42merc
    42merc
    Measure the springs.
    If the eye to eye measurement is a nominal 48" and the dimension from the bushed end to the center bolt is a nominal 24", with the width at 2-1/2" , Then a Chassis Engineering or a TCI mounting kit would work.
    The bushed end goes forward.
  3. Ralph Moore
    Ralph Moore
    47-1/4 is what I get. Thanks 42Merc!
    Looks like that is what I have, a little over 24” to center.
  4. 42merc
    42merc
    If the other dimensions are close, the mentioned kits will work.
    I believe the spring manufacturers use broken yardsticks for measuring.
    My TCI springs measured about that. Plus the center bolts varied a 1/4" .
  5. drtrcrV-8
    drtrcrV-8
    Betts Spring Mfg./ 2843 S. Maple Ave. / Fresno, CA 93725/ 559-540-8265 I hope that's enough, & no, I don't know the foreman's name. LOL!
  6. jerry123
    jerry123
    chassis engineering
