Need help Roll down rear window
Discussion in 'The Hokey Ass Message Board' started by bskustoms, Feb 10, 2013.
  1. I've lost the thread on how to install a Model A roll down rear window. There was a link somewhere on the ,but being "dumb" I erased the link.
    I would appreciate help in findinding it again.
    Thanks
  2. wuga
    wuga
    If your coupe didn't come with a roll down window, you can get everything to install one from Mac's Model A in Buffalo NY. I have a Tudor which wasn't offered with a roll down but I wanted that rear ventillation. Also, I did not want to climb back to roll it down so I built a power window and it was real easy. If you have a wood kit installed in the coupe, then the frame is there to mount the felt tracks. I installed a track from the side window to the botttom of the rear window. I installed a linear actuator mounted to the inner body frame below the window and used a two way switch mounted on the dash. The top is chopped so I cut the glass to match. It works perfectly. A picture of the install can be seen at this website, unfortunately, the actuator is behind the gas tank.
    http://www.flickr.com/photos/52296758@N06/
