Projects Need help on wheels
Discussion in 'Traditional Customs' started by fosno1, Dec 17, 2015.
  1. I
    1 vote(s)
    50.0%
  2. I
    1 vote(s)
    50.0%
  1. fosno1
    fosno1
    What's happening everyone? Needing help in fitting some supremes on my 56 210. I bought 15x8 rims w 215x70x15 tires. The rims are direct for so I'll need adapters to go from 5x4.75 to 5x5 which are 1.25 thick. Now my tire is way to wide now without adapters. I really wanna use these rims, any suggestions on how to make them fit like other tire size or changing something else? Thanks
  2. squirrel
    I have a pair of old chrome slots, 15x8, that I had on the back of my 55 Chevy for a while. But the rear in my car is narrowed about 2".
    I hate to say it, but you really do need to plan this stuff out ahead of time....either buy rims that fit your car, or modify the car to fit the rims you want to use.
    have you looked at how much material is available on the axles, to redrill them for the larger bolt pattern?
    1927graham and Hnstray like this.
  3. Hnstray
    Hnstray
    from Quincy, IL
    get narrower wheels (15"x 6" max) with the correct bolt pattern. your 210 had 15"x 5" wheels originally. trying to fit 8" wheels with typical back spacing is tough enough, especially if the back spacing is incorrect, and isn't helped any by the tire width.
    Ray
    lothiandon1940 likes this.
  4. porknbeaner
    porknbeaner
    LOL I voted but I am not sure what I voted for.
    You could use olds axles cut to fit and brakes. LOL
    Your current bolt pattern is 5 on 4.75 I would suggest that you take a look at the axle flanges and see if they can be drilled to 5 on 5. I'll bet that there is enough meat to do that. or heaven forbid, maybe there is enough room on the wheel flange to slot them and make them like a universal wheel, I'll just about bet if you look on the mounting face of the wheel there is actually a pattern showing that they can be made universal. Don't do wither of these at home by the way, you will need a machine shop and a rotary table at the very least.
    I just changed my vote. LOL :D
  5. ^^^^What Jim said^^^ Why exactly did you not buy wheels with the proper bolt pattern?
    porknbeaner and Hnstray like this.
  6. What Ray and 'Beaner said as well.:D
  7. bonzo-1
    bonzo-1
    Redrill the axle and brake pattern to 5 x 5.
  8. squirrel
    Another way to fix it is to cut the wheel openings.
    No pictures of the car....so we can't really see what the look is that you're going for
  9. porknbeaner
    porknbeaner
    Given the wheel choice I would have to guess that custom is the drill.
    But if the wheel openings are reshaped to match the front wheel openings that is about as custom as it gets. Think Nomad sedan here. :cool:
    Hnstray and lothiandon1940 like this.
  10. fosno1
    fosno1
    I got them so cheap with brand new tires i couldn't pass. plus if i couldn't make them work i would sell them. but it seems to be to much to get them to work. Thanks
  11. fosno1
    fosno1
    Not to sure what i fat fingered on the voting thing lol my bad
  12. fosno1
    fosno1
    ill get pics loaded up from home this evening
  13. fosno1
    fosno1
    Damn thats narrow, i know when i lay old wheels w new wheels together its a 2" difference
  14. fosno1
    fosno1
    thought made they were 15x7's
  15. Jalopy Joker
    Jalopy Joker
    just put the "deal wheels" up For Sale, and start over.
  16. .................That may be the best approach.
  17. porknbeaner
    porknbeaner
    They were still using 6" wheels in the mid '60s. It was your basic across the board American made wheel. You could buy a car with wider wheels but it was seldom a low end sedan.
    No offense to the model that you own intended.
  18. fosno1
    fosno1
    No offense taken bro I think it's pretty sweet now compared to 1956.
  19. chevy57dude
    chevy57dude
    Sell 'em and get a set that fits your car. Sometimes the ''best deal'' is cost prohibitive.
  20. low budget
    low budget
    from Central Ky
    They probably slide over your studs and go on but not enough room for lug nut shanks?
  21. low budget
    low budget
    from Central Ky
  22. fosno1
    fosno1
  23. oldolds
    oldolds
    I doubt 15x8 rims are going to fit comfortably on a 56 Chevy. It will involve the right wheel offset and some creative use of a 2 lbs. hammer.
  24. Thor1
    Thor1
    Ha ha! I voted too.
    The wheel adapters aren't helping you out at all either. Their thickness is eating up room under your fenders as well.
    The old carpentry saying definitely could apply here - measure twice and cut once.
  25. fosno1
    fosno1
    Heck I put them up for sale. Thanks everyone
  26. falcongeorge
    falcongeorge
    from BC
    Democracy in action...:p
    Thor1 likes this.
