Technical need help on repairing old aluminum heads
Discussion in 'Traditional Hot Rods' started by 3desotos, Dec 11, 2013.
  1. 3desotos
    3desotos
    i have a set of old weiand aluminum flatheads i am using on a 1952 v8 in my '30 ford roadster. around the coolant ports in the heads, there is some wear due to the coolant. i brought them to a welding shop today,and he tried to weld a couple different ways. mig,tig. neither seemed to be penetrating. anyone have any ideas on how i can clean these up? they are not real bad,i just dont want any leaks. he suggested jb weld, then have them resurfaced. he has done that before with aluminum,and has had great success. any help would be greatly appreciated. thanks, 3desotos
  2. rottenleonard
    rottenleonard
    Could you post a picture so we can see what your up against?
  3. williebill
    williebill
    Hope your guy didn't ruin your heads. Clean them up really well, grind out any blobs he left behind, and take them to a different guy. Or ask on here for a recommendation for qualified folks near you.
  4. Bruce Lancaster
    Bruce Lancaster
    Post a picture if you can, one of the surface and one with the gasket laid on it...
    There are some areas exposed to coolant that are not really clamping area...
  5. 3desotos
    3desotos
  6. 3desotos
    3desotos
    having problems loading photos. i will keep trying..
  7. 3desotos
    3desotos
  8. 3desotos
    3desotos
    he didnt ruin the heads. i cannot figure out why i cant post pics. i have done it before.
  9. SleightsburghMC
    SleightsburghMC
  10. SleightsburghMC
    SleightsburghMC
    Seen guys run way worse. You could use a dab if jb weld and smooth it out. Use a sacrificial anode in the coolant with aluminum heads to prevent this.
  11. 3desotos
    3desotos
    guys, sleightsburghmc posted a pic of one of my heads for me.
  12. alchemy
    alchemy
    Those are practically brand new. Run them as is.
  13. SleightsburghMC
    SleightsburghMC
  14. oldolds
    oldolds
    J B weld., sand smooth, have fun. Just like they said above.
  15. Andy
    Andy
    X2 Worked for me
